Absolutely, if the Grand Junction gets converted to light rail. West would be the first stop on the Harvard Branch. As covered extensively here, you do NOT need NSRL to take the line off the RR network.So even without nsrl I wonder if theyll use west station for transfers to north station on the framingham worcester line.
True but you would lose the ability to train moves easily, no?Absolutely, if the Grand Junction gets converted to light rail. West would be the first stop on the Harvard Branch. As covered extensively here, you do NOT need NSRL to take the line off the RR network.
It was in the 2015 SBW Transportation Plan...I'm sad that even on fantasy maps I can't get a Silver Line route from Andrew up D St to the Seaport.
No. Southside vs. Northside equipment independence limits the rate of swap moves such that 1-2x per week (chained onto normal Downeaster swaps) via the Worcester County detour uses about as much resources as 1-2x daily moves through Cambridge. Electrify 2/3 of the southside equipment pool under RER and you basically achieve this operating ratio. So this can be a much nearer-term target than it seems, thanks to the RER initiative.True but you would lose the ability to train moves easily, no?
Thanks for sharing, Hubman! I've let this map and other projects languish for a while now- I have a lot less free time than I used to- but I'm inspired by this thread and working on a new version. Look for it soon!Here's one originally posted by Downburst:
I'm a big fan of this one.Here's one originally posted by Downburst:
Ah yes, the good ole days of really crazy transit pitches. (Subway between Boylston and Charles/MGH, I'm looking at you.)This map by Omaja
I've been searching for the discussion on it for the past week. What is the alignment of the BL between Storrow and Kenmore? Isn't the Muddy River almost certainly an engineering money-pit waiting to happen? Also, is Kenmore getting underpinned by the blue? Or will it run tangent to the Green Line platforms? This small section seems like mission critical for the blue line extension past Charles MGH.I like the Blue Line to Watertown Square on the above map ^.
Extend the proposed Red-Blue Connector along along the south side of a narrowed Storrow DR., then through Kenmore and Comm Ave by BU in a tunnel, then on a viaduct on the south side of the Mass Pike to the proposed West Station, then on a viaduct along the north side of the Pike through Allston, then cross the Charles on a bridge west of Home Depot near Arsenal Street, then elevated on Arsenal Street to Watertown Square. All elevated route west of the BU Bridge, but something Boston metro will need to get used to for cost effective rapid transit extensions. Elevated structures now are pretty decent looking, nothing like the ones 100 years ago.
In that map B line is rerouted to GJR. So I assume would the Blue Line goes under Beacon St to Kenmore where it gets a station around the existing Westbound Green Line platforms before continuing into a tunnel under the Comm Ave median. Then C&D use the current Eastbound platforms in both direction.I've been searching for the discussion on it for the past week. What is the alignment of the BL between Storrow and Kenmore? Isn't the Muddy River almost certainly an engineering money-pit waiting to happen? Also, is Kenmore getting underpinned by the blue? Or will it run tangent to the Green Line platforms? This small section seems like mission critical for the blue line extension past Charles MGH.
The tunnel (remember: Storrow teardown an ironclad requirement) would cross diagonally between the Back St./Charlesgate East intersection to the Beacon/Charlesgate West intersection. The Muddy is doing its Bowker-era 'noodle'-shape channel here so the angle of intersection with the tunnel is pretty favorable. Hell, if the tunneling re-channeled the river once more to have a natural/non-concrete channel above and daylighted it to the Charles it would be a thousandfold improvement since the 1950's MDC channeling work on this block is an ecological disaster. As for how it slips under...probably a shield on the roof, but it's not that deep or wide a river so probably negligible added expense.I've been searching for the discussion on it for the past week. What is the alignment of the BL between Storrow and Kenmore? Isn't the Muddy River almost certainly an engineering money-pit waiting to happen? Also, is Kenmore getting underpinned by the blue? Or will it run tangent to the Green Line platforms? This small section seems like mission critical for the blue line extension past Charles MGH.
