Actual curved glass? Fancy.
i'm still super excited for 1 dalton, but just doing minimal research on that one ^^^ (50 west street) it's hard not to get jealous.
Interesting that the Globe has it as 742' and the third tallest.
Im still extremely interested to see what this antenna is going to look like. I believe its only 100 feet so it may just look the hancock where you dont even really notice its there.
I dunno, I think the triangular shale of 1 Dalton is going to give the edge.
...Maybe looking head on at a triangular point where you can see two sides it'll look a touch wide.....
I actually think it looks its thinnest from the corners. Since it has 60 degree angles instead of the typical 90, it doesn't splay out as far as a more standard shaped building.
It must be some sort of optical illusion then, because looking at directly at the corner would produce the widest possible view of an equilateral triangle (the entire side).
The thinnest possible viewing angle would be looking perpendicular to the bisection of one of the corners (ie, at at 30 degree angle to one of the faces). From that angle you would see the height of the triangle, which is sqrt(3)/2 or 86.6% of one of the faces.
/math nerd
Did you take into account that this "triangle" is actually somewhat rounded, with rounded corners and bubbling out a bit on the sides? Thus you don't get the full view of either side when directly facing a corner because they round back inwards at their other 2 corners.
The rounding/bubbling would increase the apparent width from all angles.....
