I think we need to create some type of plan now, to address the pike being covered in the future, and detail the steps that need to be taken to ensure that projects going up around the pike work towards whatever the final goal is. I think, like many people, that we should put a greenway down this section of decked pike and move marginal st over the pike so the lots that are on land can be developed. I also think that this greenway makes a lot of sense to be connected to the southwest corridor park.
If we do decide that we are going to have a greenway down this corridor, then projects like the hancock garage redevelopment should be done in a way to facilitate the connection between this and the southwest corridor park. If the hancock garage is going to be redeveloped anyways, we have a chance to add this connection into that plan. Id rather have an idea of this plan now, then spend millions redeveloping the station and wish later on when the pike is covered that we had thought about this before. They line up too perfectly not to consider it.
Idk what steps would need to be taken, but I think this is extremely important in the larger picture of protected bike lanes, cycle tracks, and walking paths, where this could create an extensive protected cycle/pedestrian route all the way from Roxbury to North Station. From there it can tie into other cycle tracks and the harbor walk as well. I think its obvious.
Theres only a small section of the station to remove.
The southwest corridor park, station, and pike corridor all line up perfectly.
If/when the pike is decked Id imagine that a greenway will be a part of it. These parts line up too well to not consider connecting them. Then at the top tie this into the rk greenway, south end park, fort point etc, and the southern portion can be extended over the tracks later if desired.
So built out there would be a path from North Station down canal st, across new chardon in front of gov ctr to the greenway, around the greenway to the leather dist., links up with the pike decking, decked up to back bay station, crosses dartmouth st, continues down southwest corridor park to mass ave. From there continues as far as you wanna deck, could even go to arborway if the will was there. This is within the realm of possibility. To Ruggles or Roxbury crossing would be pretty reasonable.
*sorry for the shyte quality, I downloaded some crappy app where u can draw over apple maps..
