While the 501 and 504
(not 503) will likely be much less necessary in a world with quality service at Newton Corner...
I don't know why people are talking about scrapping the 57???
- The 57 is the only bus route along most of its corridor, and even at places where it intersects with other bus routes (64, 65, 66, 86), the 57 is the most frequent or at least one of the most frequent (in any timeline, past, present or future).
- The area around Newton Corner has one of the lowest riderships along the 57's route. As seen from its route profile below, Tremont St (just south of Newton Corner) has extremely low ridership by the 57's standards. Newton Corner itself does a bit better, but is still only equivalent to a single, average stop east of Oak Square. The bulk of its ridership is from Oak Square and points east, and the comparison is not remotely close. Losing Newton Corner riders won't siphon off much demand from the 57, if any.
- The 57's main service area -- Brighton -- is not even close to the B&A. Even an infill station won't make everyone walk there.
- The 57's corridor, particularly towards BU, is a well-established transit corridor that has motivated people to live here specifically for the BU connection. Even for someone living near Newton Corner, you'd need a lot of heavy lifting for Worcester Line to be a true replacement for the BU connection. The Brighton-BU connection is simply irreplaceable. (Similar to the 39 and Huntington.)
- The 57 also serves local connections between numerous points in Watertown, Brighton and Allston. Such trips are rarely replaceable by subways, much less commuter rail.
- Even in a world with quality service at Newton Corner CR station, it arguably makes the 57 more important, not less. It will obviously be the primary feeder bus from Watertown to Newton Corner. You will probably get people from Oak Square (and even Brighton Center) to connect to Newton Corner too, if rail service there is faster than the Green Line.
Also, the 501 and 504 have
15-min frequencies during rush hours, both today and in BNRD. It will take a long, long time for Newton Corner CR station to receive this kind of service. So you may argue that scrapping the 501 and 504 too early will still result in a service downgrade, until
true regional rail is implemented on the Worcester Line.
Original post discussed the 502, which was a typo. Its probably just easier to write it as 50x or 5xx routes.
The rationale is that if you RUR-ize Newton Corner (and Faneuil), you can massively increase frequency on the 64, 65, and 86 to increase crosstown connectivity in Brighton Center, where 25 - 70 minute frequencies on the 86, 64, and the 65 buses are insufficent for the needs of the neighborhood. The 64, 65, and the 86 need 8 - 13 minute frequencies in order to provide alternatives for Brighton Center residents instead of depending on their cars. B & A with
urban rail frequencies and
urban rail stop spacing is the only way that will achieve that. 15 minute frequency is only the bare minimum. TM has discussed a Faneuil infill station alongside Newton Corner and Beacon Yards. It is about the maximum possible number of stations that can fit on
commuter rail, before a dedicated rapid transit line becomes necessary in order to add additional stops.
Source:
TransitMatters.
In addition, Faneuil is within the city of Boston, unlike Newton Corner. This allows the station to be in Zone 1A, like Forest Hills, Oak Grove and West Medford, and would put the station better positioned within Boston's hands, instead of Newton's eyes. It would provide faster trips to Downtown Boston with a closer location. Increased frequency on the 64 (or rerouting the route as needed), can pick up Faneuil Station on Brooks St and Parsons St and extend frequent bus service from Faneuil Station to Market St, Boston Landing, Union Square, and Central Square in Cambridge.
Urban rail service on the B & A is the best bet for improved crosstown bus connections in Allston-Brighton, since by freeing up buses consumed by the 57, 501, and 504, they can be redistributed to improve connections across the Charles to Cambridge and points north, and with Longwood Medical and Ruggles.
The 57 consumes a ridiculous amount of buses. 7 buses just to get 15 minute frequency during Weekday interpeak and Saturday, running the 57 every 4 - 7 minutes requires something on the order of 15 buses. Insane.
This is from the
2014 blue book, so it doesn't even reflect worsening road conditions that occurred between 2014 and 2018, prior to COVID-19. The runtimes are longer and the frequencies are lower now.
The 57 bus route is just simply far too long to be managable in one go. It's a contributing factor why the 57 bunches relentlessly due to the length of the route. That's why we should have been charging distance based fares for longer bus routes (the 57 is a good candidate for distance based fares). (The 69 and the 89 are much easier to run, even a GLX dinky from Medford to North Station isn't this costly and expensive. You can run 3 shuttle trains back and forth for 15 minute frequency, ditto the 69, 89, and SL5)
If the 57 consumes this many buses, it is no wonder the 64, 65, and the 86 are left with leftover scraps with measly 25 - 70 minute frequencies, even under BNRD.
