Yes (to a degree). The air ballast on cars is adjustable. And, in fact, it does need to be tweaked at the shop from time to time when a car becomes askew from the platform lip (on a severely out-of-alignment ballast, that could be a couple inches).I understand that the T cars suspensions adjust to account for the weight of the passengers. Can this height be reset on the fly? Could the BL feed into the OL and a button pushed to raise it 4in?
24 of the BL 0600's were proposed to be rebuilt and sent to the Orange Line for fleet expansion back when they were buying the Siemens 0700 cars and were still proposing to midlife-overhaul the Orange 01200's. They would've been able to do so so long as the cars were sandwiched in the middle of the set and never leading, for signal compatibility purposes. The 0600's and 01200's were identical makes except for their line-specific differences, so would've trainlined just fine. Adjusting the ballast heights was one of the few/only mods required, and it was within the vehicles' tolerances. The only reason this plan was not pursued is because the carbodies were found to be too corroded by the salt air along the Blue Line to be feasible for rebuilding at acceptable cost.
EDIT: If by "on-the-fly" you mean interlining Blue to Orange in a single trip...no, not quite. The ballast has to be adjusted in the shop for any significant change. The only self-adjusting is hydraulic for keeping it at the same level under varying passenger loads. It doesn't change levels on-the-fly. I suppose if there were ever a need for that it wouldn't be too terribly difficult to order some Jetsons Shit floor-height changing 'active' hydraulics on factory order for brand-new rolling stock, but that's starting to get a bit kludgy and cost-adding.
