Brattle Loop
- Apr 28, 2020
So, I mean for the outbound platform you can either walk all the way around through the storage place parking lot (might I add maybe the best looking storage place ever?), or... you could just walk down the same stairs and cross the tracks from platform to platform right there. And, yeah, OK it's about 200 yards detour, but it's a pretty big physiological detour including the issues with lightning at night I detailed above. Sure, a bit of hyperbole from me and melodrama, but, it's the third most trafficked station on the line excluding the termini at Ashmont and Mattapan, and its singular main entrance has been out of commission for years.
Also, admit that the High-Speed line is near and dear to my heart - and it is annoying after a few years now on the 'transformation' project that little has been done with the rehabs of the PCCs are woefully behind schedule with little else going on. There has been a decent amount of ToD on the line, too, which makes the T's dragging of feet all the more annoying. Plus, I personally see the line as almost the perfect guinea pig and test bed - pretty much a closed loop with only two grade crossings that the T should be using as more of a lab for things like signal priority, synchronization with the Red, hell, and even full automation. Should be a test bed for wider Green Line technology rollouts.
I'll post this here, if the discussion moves feel free to move this along with it.
It's kind of a recurring issue with the T which is both understandable on one level and absolutely infuriating on another. On the one hand, the MAAB's regulations and rulings on what accessibility modifications they need to make and what the triggers are for those upgrades isn't within the T's control, meaning that there are plenty of situations where that has the regrettable perverse outcome of leading them to not make useful improvements (and, indeed, to close parts of infrastructure like these stairs) because doing so would trigger the need to make the kind of upgrades they're not cued up to make. On the other hand, the T knows this is a thing, they either can't or won't properly provision for making these necessary upgrades, so you get situations where they have to keep these stairs closed, or they have to leave CR stations completely inaccessible, because they don't (for whatever reasons) have the budget to make the necessary changes on anything like a reasonable timetable, and they certainly don't show that they care about that fact. It's fine if the explanation is "we can't fix these, because the rules say we'd have to add an elevator, and we don't have the money to do that right now", but that's not a get out of jail free card, it's on them to get their act together and get the money, or at the very least to make it clear in their communications that they need more money from the politicians to do these things. "Not being the MTA" when it comes to things like station access and accessibility shouldn't be the standard; there's a clear "oh well" shrug here that doesn't sit well and shouldn't be acceptable, it's yet another symptom of the degree of institutional rot we're dealing with.
