ryblogs
New member
- Aug 22, 2017
Wow. It looks like they might almost hit their date for reopening Washington St.
Which is? I heard conflicting reports of May 20th and May 31st.
In my opinion, they completely missed the opportunity to widen this underpass so the lanes dont squeeze from 2 to 1 and back to 2 again on the other side.
Those secondary abutments are temporary. See Street View here for an earlier pic of the construction staging when west half of the bridge was new and east half was old. And then here from the other side in slightly earlier view from when the old bridge was chopped in half but the west-half new span had yet had to have its permanent abutments poured.
The new-pour concrete conjoined to the old stone blocks appears to be some sort of construction staging platform, as you can see from the first Street View it was ramped-up with rock ballast that's now mostly been scooped away. Those, along with the now-disused old stone abutments from the west half of the old bridge, should be removed pretty soon. Resulting undergrade width will then be about 1/3 wider than the old span and 2 ft. taller.
Oh, that's a good point. So they build up the berm, install the pilings and then dig away the berm and the existing slope. Clever. I assume the pilings do an OK job holding back the soil before the concrete panels are installed.Also they need a level platform to sit on. Most of the drilled shafts on the southwest side of the corridor are getting installed through what is an existing slope. Imagine a right triangle - and trying to drill straight down while you're perched on its hypotenuse at a 45 degree angle.
next time i think i see you i'm just gonna yell "javier!" and see if the photographer turns around. for reference (and so as not to scare you), i'd be the skinhead walking the min-pin and holding a thermos of "coffee" -- usually around the HS/city hall/winter hill area, but sometimes union, ball, magoun, or inman square (or, more rarely, central).
I've never been so excited about being totally inconvenienced by the T closing a station...
Year-long Green Line service change begins Sunday
Green Line service between Lechmere Station and North Station is being replaced with shuttle buses every day beginning Sunday. The change will last for about one year, the MBTA said.www.wcvb.com
I honestly think that the red-blue connector is a real possibility in the next ten or so years. Might be pushed back a bit because of how much corona has decreased revenue coming in.As much as we complain about no red-blue, blue-lynn...etc, rightfully so, this is still a huge deal that the green line is getting a major grade separated expansion like this. These dont come around every day. Im very excited to see if this can spur some of those other projects once people see how successful this is because people havent seen a new transit line like this in decades. Cant wait to see this succeed massively.
