Jahvon09
- Oct 2, 2011
Yeah, that's the core for this adjacent project:Looks like an elevator shaft.![]()
However, he suggested that the Medford branch’s opening — already delayed from this December until May 2022 — would likely be delayed as well.
At some point we have to recognize the Zeno's parodox nature of these delays. Each delay is of a shorter duration than the last, but each is still a delay.
When your critical path is delayed there's not much point in spending more money rushing the non-critical path jobs because they have increased float. You can offset some of the cost of the increased timeline by reducing spend on the non-critical paths, but not so much that they then become the critical pathIt's weird, since they made the announcement in June, work near me, which had been proceeding at a decent rate, immediately slowed to an absolute crawl. So yea, supply chain issues, substation issues, but why the instant slow down in actually building out the rest of the project.
Seems to me, if the substations are the issue, they could finish the rest of the project on schedule and at least open the community path.
Maybe but the path is probably the way the construction folks move equipment and materials into place. It would suck to have to close the path often and regularly to finish construction.It's weird, since they made the announcement in June, work near me, which had been proceeding at a decent rate, immediately slowed to an absolute crawl. So yea, supply chain issues, substation issues, but why the instant slow down in actually building out the rest of the project.
yea, I think that’s the case but I’m talking about opening the path when the rail system goes in to testing. Past the phase of needing it for heavy equipment/ materials access. I’m also not suse if completing the path by may would require overtime as the hold up has nothing to do with its construction.Maybe but the path is probably the way the construction folks move equipment and materials into place. It would suck to have to close the path often and regularly to finish construction.
There’s been a lot of reasons given as to why they can’t keep the path on schedule but as far as I can tell it would come down to cost, even tho the contractor was bragging about coming in under budget. Any access during testing could be provided during night hours or even with temp closures.Just because the rail line is in testing doesn't mean that the need for access goes away. Especially since there's no guarantee that they're not going to identify something that needs replacement during testing. Especially since the Medford branch is opening second, there's no guarantee that the Union branch passing the testing phase means that the Medford branch will be fault free.
Ironically, the path will need its lighting turned on before they open it... and that will require completion of all that electrical work.yea, I think that’s the case but I’m talking about opening the path when the rail system goes in to testing. Past the phase of needing it for heavy equipment/ materials access. I’m also not suse if completing the path by may would require overtime as the hold up has nothing to do with its construction.
