It's got the Urban Ring, too.Java King found quite a detailed document on proposals for a Green Line to Nubian (and Mattapan), in his post here.
You raise compelling points about how "beefy" of a Comm Ave subway is needed to make this whole thing work. I would argue we can simplify things a bit, though:Riverside said:
For example, the Commonwealth Subway would be highly valuable for increasing speed and reliability, but isn’t critical to any particular project.
I actually think that in a full-build GLR, the Commonwealth Subway will be more important than shown here. Depending on build configuration, up to 4 branches may traverse the stretch at what's now BU Central: Boston College, Oak Square, Harvard, and Grand Junction. That's the same number of branches as present-day Copley-GC (which is already a bottleneck on today's Green Line), but even worse, running at street level for 0.7 miles with no grade separation and possibly no signal priority.
To make things worse, each of the 4 branches will likely involve some street-running, with the possible exception of Harvard. Especially BC/Oak Sq, and especially if Grand Junction service originates all the way from Chelsea or Airport. That's a huge reliability concern that may be even worse than today's Green Line (since the D has full grade separation).
As I've alluded to above, I think the Aldgate junction at BU Bridge only needs to point in three directions: Cambridgeport, West Station, and one direction south (e.g. Park Dr). Packards Corner doesn't need service from anywhere other than Kenmore, and as I've argued above, I think Grand Junction <> Kenmore is a poor investment. (A non-revenue connection could be operationally valuable, although I don't think it would be make-or-break.) In some ways, I'd rather settle on a design for the Urban Ring stuff first, and then add a Comm Ave subway as a secondary priority.Another consideration here is the BU Bridge junction. You need the junction to enable services to Packards Corner, West Station and Grand Junction. A surface intersection at the current BU Bridge junction doesn't make the cut to me given the existing traffic patterns, and a viaduct may have difficulty descending onto the BU Bridge ROW. So you need a tunnel for the junction even in a smaller build - and if that's the case, it may be an additional argument for just building the full Commonwealth Subway once, instead of in two stages (and disrupting traffic and B branch operations twice).
I was trying to leave this corridor open-ended on exact route/alignment, because I agree there are problems with using Park Dr, though probably I should've erred on the side of more expensive estimates, and treated it like a "tunnel" segment. At "tunnel" costs (which probably are also a vaguely decent estimate for elevated costs), it's a little less than $1B. But, as mentioned above, to me it'd be a no-brainer to reallocate those Comm Ave subway costs to build a connector like this.I'm assuming you're using a street-running route via Mountfort St and Park Dr. It can work in a minimum build, but I'm concerned about reliability, given traffic, several signalized intersections, and the low likelihood of getting any dedicated ROW. This is in addition to adding even more complexity to the BU Bridge junction - now you have two possible directions on the southeast side.
Yeah I wasn't super clear here, I didn't really mean to suggest that SL3x/SL6 would make LRT appear less necessary, but more that we will have a more precise understanding of the needs along this corridor. (And I continue to maintain that the SL3x/SL6 numbers need to be understood in the context of the current utterly awful connectivity between Sullivan and Kendall where literally your only option is the CT2, which has garbage headways of 20min peak/60 min off-peak. Chelsea LRT may still be required even with Sullivan <> Kendall LRT, but the justification will very likely look different.)We'll see how ridership evolves after SL3 extension and SL6 are implemented, but if they're huge successes, it may be an argument in favor of LRT conversion. LRT does miss out on Glendale and Upper Broadway in Everett (and has less convenient pedestrian access from Sweetser Circle), but the Silver Line alternatives analysis mentioned that the Glendale-Kendall alternative and Chelsea-Kendall alternative have similar projected ridership, so there's good potential for LRT and BRT to complement each other on this corridor.
I agree that it is good to periodically revisit the question of a Longwood subway. And to your point, using the very coarse measurements I'm using here, the tunnel mileage is likely shorter via Longwood proper anyway. One thing to note, however, is that (as @The EGE noted on his map) you need to find someplace to terminate your Urban Ring services; I'm using the Fenway Branch to Brookline Village to do that, but a Longwood subway would probably require provisions for terminating operations at the "LMA Central" station (unless you want to introduce a capacity pinch by interlining circumferential Urban Ring services with radial Huntington services).I know you probably didn't include any southside Urban Ring infrastructure towards the GLR cost estimations (e.g. Nubian to Huntington), but I think it might be a good time to revisit The EGE's idea of a D-E connector via Longwood instead of Brookline Village.
One thing you illustrated well here is how "expensive" a subway D-E connector is - about 0.9 miles from LMA station to Brookline Village. Tunneling via Longwood Ave (or Francis St but I'm doubtful on that) is even shorter on paper at 0.7 miles. Of course, a Longwood subway will be much more expensive due to building mitigations, but I think this is where a full cost-benefit analysis is needed.
As I've recently learned myself, there are indeed a few academic buildings right at Kenmore. Some buildings may also be closer to Kenmore than a combined BU station with a Comm Ave subway or BLX. And of course, an option to transfer to the B or the 57 is always there. BU East and BU Central stations are still the biggest destinations, and should be prioritized as much as possible; but if Kenmore is the best we can do (for both Urban Ring and BLX), it may be workable.Kenmore station cannot terminate trains from Comm Ave without a significant/total rebuild, and is not itself an employment or residential destination -- both BU and Longwood are much larger hubs.
From the BU Master Plan (which someone posted here a while ago), BU does have air rights over Mass Pike, and plans to put a few buildings over it. Realistically, a street-running approach may end up having to run on Mountfort.(And, assuming we can leverage Mass Pike air rights to avoid actually running at-grade along Mountfort, I don't actually think we need to be quite so pessimistic about Park Dr. Close the northernmost block [between Mountfort and Buswell] to public traffic, reclaim the western half of the street between Buswell and Fenway station [easier said than done, true], and traverse one traffic light. That's not ideal, but that doesn't seem impossible to me.)
Given how narrow Longwood Ave is, I doubt there will be space for terminating operations. And a Longwood subway will likely interline with Huntington services anyway, since in a build similar to The EGE's, it will serve both Riverside-LMA-Symphony trains and GJ-LMA-Ruggles trains. There will also likely be no space at the Huntington/Longwood intersection, so it's either a flat junction (welp), or stacked tracks for both Huntington subway and Longwood subway here. (You may end up needing to stack the tracks for Longwood subway anyway given its width.)a Longwood subway would probably require provisions for terminating operations at the "LMA Central" station (unless you want to introduce a capacity pinch by interlining circumferential Urban Ring services with radial Huntington services).
Gotcha, yeah this makes a lot of sense and I think I agree with all of it. That's an interesting idea to have a "zig-zag" that runs east on Comm Ave until (e.g.) Blandford, cuts under the Pike via TBM (including a Lansdowne subway station?), and hooks into the Fenway Branch clear of Beacon Junction. (Probably has been thrown around up thread, though I can't call it to mind right now.)Re: BU and Commonwealth Ave Subway
I think there's a bit of confusion arising from my somewhat subjective initial comment, so let me clarify things:
I do agree there are mainly two trunks in this corner of the system:
My comment about possibly having 4 branches through Comm Ave was envisioning the worst case, where Trunk 2 also uses the same ROW as Track 1 along Comm Ave (surface or subway) through part of the route, regardless of whether it goes to Kenmore. I've been brainstorming my own proposal for Trunk 2, which I'll hopefully post at some point, but my current thought involves also going under Comm Ave and turning south just before Kenmore. I think there are a few reasons why having Trunk 2 use Comm Ave may be desirable, the biggest of which being that it serves BU directly - I'd argue that Urban Ring users need access to BU just as much as Blue Line riders.
- Oak Sq and Boston College - Comm Ave and BU - Kenmore (a more traditional streetcar route)
- Grand Junction and West Station - Somewhere around BU - Highland Branch or LMA (or, in the worst case, Kenmore) (a more Urban Ring-oriented route)
Of course, this is not the only way for Trunk 2 to play out, and with any other alignment that doesn't involve using the same ROW along Comm Ave as Trunk 1, there wouldn't be a huge need for a Comm Ave subway at all (in which case it would be only for Trunk 1). Thus, I agree that the biggest priority here is to build whatever infrastructure that allows Trunk 2, and in some but not all cases, it may end up being a Comm Ave subway that also allows Trunk 1 to benefit.
Yeah, if the Mass Pike isn't available then the Park Dr surface option likely isn't viable -- I think that short surface segment could be swung, but unless Mountfort is closed to traffic it really isn't viable. I increasingly like your idea of tunneling across near Blandford -- make the bored segment as short as possible, leverage the wide ROW of Comm Ave, and take advantage of the Fenway Branch as a landing point.From the BU Master Plan (which someone posted here a while ago), BU does have air rights over Mass Pike, and plans to put a few buildings over it. Realistically, a street-running approach may end up having to run on Mountfort.
Good thoughts with all of these including the build sequences.Re: D-E connector and Huntington Subway
Yes, this is what I've landed on: terminating (northside) UR services at Brookline Village simplifies ops and maximizes capacity. And yes -- any zigzag via Brookline Village (or any stretch along Huntington -- e.g. between Longwood Medical Area station and MFA station before turning to Ruggles) interlines with Huntington services, and I think that would have an outsized impact on capacity and reliability for a Huntington Subway (which otherwise could be completely isolated from surface services). Given that it would be an inelegant indirect zig-zag service anyway, the interlining doesn't seem worth that cost.So a Brookline Village alignment for UR is significantly less complicated operations-wise - but only if you completely disconnect the two halves of UR and isolate them from Huntington subway. This means terminating northside UR services at Brookline Village, and making southside UR either BRT or LRT that terminates without crossing Huntington. The moment you want to run some zigzag patterns via Brookline Village to connect the two halves, you're interlining with Huntington services again.
I can definitely see reasons to do that, since few passengers will want to go through the BV zigzag... But let's just say it's a lot less elegant
...is just very true. It's either expensive or inelegant -- pick your poison.(Honestly, it's just hard to come up with proposals for the southern half of Urban Ring from LMA to Seaport and even to Airport, especially compared to the northern half. Perhaps BRT is what we'll eventually have to settle on, but I worry about ridership and reliability, especially given the ongoing discussion about LRT vs BRT ridership for the Silver Line.)
Found it. It was an idea from @vanshnookenraggen that is pretty similar to what we're discussing now. He argued in favor of a D-E connector under the Brookline Avenue Playground as a way to make a "wraparound" from the current Longwood station to a subway station at Brigham Circle more palatable:Gotcha, yeah this makes a lot of sense and I think I agree with all of it. That's an interesting idea to have a "zig-zag" that runs east on Comm Ave until (e.g.) Blandford, cuts under the Pike via TBM (including a Lansdowne subway station?), and hooks into the Fenway Branch clear of Beacon Junction. (Probably has been thrown around up thread, though I can't call it to mind right now.)
A question we should consider is: Is there a need for a zigzag service, or more accurately, a complete SW Urban Ring that doesn't split northside and southside services in segments?
Thinking about it again, I can definitely see some demand for it. I think the main service pattern here is: Ruggles and Nubian - BU and Kendall.
Both Ruggles and Nubian are major bus hubs, and the former is also a major Commuter Rail transfer station. Both BU and Kendall (plus MIT) are major employment centers. Yet, even in a post-BNRD world, the only reliable bus routes that's remotely close to an OSR between any of the origin-destination pairs are: T1 from Nubian to MIT, T28 from Nubian to Kenmore, and T47 from Ruggles to bus stops in the BU Bridge vicinity. All of them are just a little bit away from where most jobs actually are. The 85 gives a direct Ruggles-Kendall OSR, but it's an infrequent route with 30-min peak frequency.
Commuters that live along the T28 do get two-seat rides to BU by transferring at Kenmore. Commuter Rail riders can transfer at South Station for a two-seat ride to Kendall, but that takes up capacity downtown - and one of Urban Ring's main objectives is to prevent or at least mitigate that. Aside from those, for anyone starting their journey from a Commuter Rail stop or a bus route south of Nubian, they need 3-seat rides (some of which still involve two surface routes or a downtown transfer), or in some cases, 2-seat rides plus walking.
A successful zigzag Urban Ring route turns all these into 2-seat rides from each commuter's origins, or 1-seat rides from Ruggles and Nubian.
I suppose the question becomes:
Note that, as I've shown before, a UR station at Washington/Melnea Cass (plus Ruggles) does almost as well as Nubian proper for capturing the Nubian bus routes.
- Is the demand enough to justify the cost (particularly if Ruggles and Nubian can't both be served with a single UR service pattern, or if the infrastructure can't be combined with a D-E connector)?
- Is the OSR's travel time to BU and Kendall competitive enough? (Especially compared to CR-South Station-RL-Kendall)
- My opinion is that, even if the travel time is longer but not too bad, it will still draw enough non-CR commuters to switch to the OSR due to convenience
I also intentionally omitted Harvard from the discussion. Even though a Harvard-Nubian Urban Ring OSR is quite doable, a downtown transfer to the Red Line becomes more attractive here, due to the longer distance and the UR Harvard branch possibly involving street running.
This might be a questionable assumption if the western half of the Watertown Branch involves street running.Assuming 16 mph average (which I think is what the Medford Branch does right now), it would take 30 minutes to go from Watertown Square to Government Center.
Two other factors that go against the T70:At 8 mph (comparable to today's C, E, or SL4/5), the T70 would take 30 minutes just to get to Central, and then it's another 9 minutes (plus transfer time) to Park Street.
There are some plans for bus lanes on Western, or even turning it into a dedicated transitway. But you're right, there are some higher traffic areas along Western the plans don't cover (which seems backwards)Western Ave and River St near Charles River can often have a lot of traffic. I'm not sure how easy it is to implement dedicated bus lanes in the area.
In theory, these problems could both be solved by judiciously applied paint (whether on roads, signs, etc). The question in both cases is how easily that could be done.Two other factors that go against the T70:
- Western Ave and River St near Charles River can often have a lot of traffic. I'm not sure how easy it is to implement dedicated bus lanes in the area.
- Taking the T70 at Central is not very intuitive. Inbound is fine, but outbound T70 boards on Green St, which requires a short walk and crossing Mass Ave from the outbound Red Line platform. I've often seen people getting confused here. It's also a somewhat sketchy area.
Yeah -- I think it makes a lot of sense to run trains to Watertown from Porter. The part I'm fuzzier on is where should the trains go after Porter. Is the route too roundabout to take up slots in the Central Subway? (Until yesterday, I had thought "yes", and now I am pondering.) That's one reason I've considered sending these trains to Sullivan instead, so they can pull double-duty by linking Porter + Union with Sullivan as a circumferential service. (Of course, doing so loses you the OSR to Lechmere. Easy single platform transfer at Union, but still.)Another argument in favor of the Watertown branch -- it connects three life science hubs (East Watertown, Alewife and East Cambridge, near enough to Kendall).
RE: Porter, instead of going under the CR for the segment where the ROW necks down, what about going elevated above? Seems much less impactful to CR ops during construction in addition to likely being much cheaper. If the GL could cross Beacon St at grade on the road bridge (I’m assuming the existing bridge would have to be demolished and reconstructed to accommodate this), an El wouldn’t even be visually intrusive since it would be at the same elevation of Somerville Ave. Could even cheap out and slap some north station style fare gates to bring the CR platforms into fare control so only vertical circulation between Green/ CR platforms would be needed to access the RL.
@F-Line to Dudley's thinking on this a couple of years ago was to put the Green Line tracks immediately under the commuter rail tracks. I haven't looked particularly closely at it myself. As I read it, the Green Line tracks would be accessed via the commuter rail platform (I think).This brings up a concern I've started to have about schemes to run the Green Line through Porter: How on earth are you going to connect it to the existing Red Line station, and offer a behind-the-fare-gate transfer?
On the latter, I guess I can accept waving away the question of rotating the line of fare gates 90 degrees or so (assuming the smaller number of gates still has the necessary throughput) courtesy of some yet-to-be-developed universal fare system. Doesn't seem that hard, AFC 2.0's travails aside.
But the former seems a lot stickier. Consider this highly sketchy sketch of the arrangement of the Porter ticket hall and commuter rail tracks:
The CR ROW is too narrow to quad-track things, so you'd need to run the GL trains underneath. But the CR platform is only about 1 story above the ticket hall floor level. It seems like you're left with one of two fairly expensive propositions: A) digging the GL tunnel even deeper, below the floor level of the ticket hall, or b) digging the ticket hall down so its floor level is below the GL tracks. It looks like far more than a simple cut-and-cover job, right? Or does the fact that the GL tracks would effectively be at only a "sub-basement 2" level thanks to the CR tracks already existing in a trench make it less daunting?
If it were up to me, I would just elevate the GLX extension over Beacon Street and Mass Ave, centered above the existing RL Porter Sq headhouse that spans the Fitchburg Div. The elevated structure alignment would be right above the Fitchburg Div tracks. Its touchdown points would be east of Beacon Street and west of Mass Ave. An elevated line would be the cheapest and least disruptive of any option for a line continuing further west from Porter Sq.I love this idea in all ways except one: it makes a future extension beyond Porter much less feasible.
With an indefinite terminus of Porter, though, it works great, in my estimation. No need to fare-gate the Green Line platform, if the other GLX stations are already not fare-gated. You could even build a new headhouse and vertical transportation at Somerville Ave opposite Mossland for better GL and CR access for Spring Hill.
Yeah, I really don't know about the logistics of building the platform. I haven't been to Porter in a while, but I was able to find diagrams from the original 1977 EIS:I saw that, but is that really workable? That'd force all pax to go up to street level to change between the three lines that would be intersecting there because those GL tunnels would wipe out the lobby-level connection to the Red Line.
Alternately, I suppose you could make the transfer via a Park Street GL northbound-style level crossing for pedestrians, but I'd worry you'd have to set the platform height too low. You don't have a lot of distance between the Red Line ticket hall and the notional Green Line tracks to transition from one floor level to the other at an ADA-compliant slope. I guess the two key questions are: Do the Porter CR tracks need to be lowered at all to add catenary for those trains, and what do the foundations look like for the substation that hangs over the CR tracks? Are those foundations set up to allow you to send a ramp (light blue, below) parallel to the GL tracks down to whatever level you need? And is that ramp wide enough to allow an adequate flow of passengers?
EDIT: This discussion is making me wonder if it would have been better if the T had decided to serve Union with regional rail instead of a branch of the Green Line![]()
