The Delta lounge looks excellent, and I'm very happy to see the Delta international expansion at Terminal E. I wonder if there is any thought from Massport to provide a secure (Behind TSA Screening) Connection from Terminal A to Terminal E via a skybridge across Central parking or Airside Shuttle Service? I should know this, but I don't. Can you even get from Terminal A to Terminal E without passing outside through security and back in via Terminal A to B to C to E?
I've been on a number of international flights with domestic connections first, and the connections seem much better than at Logan. For instance, I took American from Boston down to Dallas, and then on to Auckland, NZ. Coming back was United from Brisbane, Australia to Los Angeles and then on to Boston. Los Angeles was a real mess where you did have to exit security and transfer to a different terminal for the domestic flight back to Boston. It seems like most International to Domestic connections overseas have you go through Customs, then another security checkpoint/scanning before you continue to a Domestic connection. Although that additional security checkpoint/scanning is different than if you arrived at that same terminal to take the domestic flight. I guess what I'm trying to say is that the additional checkpoint screening seems well-integrated into the International Arrival and connection process, rather than completely exiting the secure area and re-entering as if you just arrived at the airport. For someone arriving into Boston from a Delta International flight, they would first go through Customs, and they would exit Terminal E and take the Massport shuttle over to Terminal A and then go through check-in and security as if that was their first flight.
Maybe I'm overthinking this? Maybe Delta International flight to Logan don't drive domestic flight connections like some other airports?
