stellarfun
- Dec 28, 2006
Could someone clarify for me so I don't have to go back and read everything?
They were going to "replace" the bridge, right? Like, totally gut and redo? This is a "repair", no?
Meaning, will this have to be redone at some point in the near future?
Basically replacing all the steel, not the granite.
The primary objective of the proposed rehabilitation is to address the bridge's current structural deficiencies, upgrade its structural capacity, and bring the bridge up to modern code. In particular, the structural steel elements supporting the bridge deck have deteriorated and require upgrading, and the abutments will have to be modified slightly to allow the sidewalk approaches to meet Americans with Disabilities Act (ADA) accessibility guidelines. At the same time, the bridge's ornate pedestrian railings will be restored or replicated, its masonry elements will be cleaned and conserved, and an appropriate new bridge lighting system will be designed. Areas on the riverbanks disturbed by the project will be carefully landscaped to tie the bridge into its historic setting.
