Abysmal bus service to Kendall is something I would really like to see change with the upcoming bus overhaul. I want a limited number of overlapping bus routes that all get quality treatment and establish a transit corridor. Moving CT2, 85, and EZ Ride to Ames Street establishes a precedent for routing buses away from Kendall Station. What will similar reasoning mean for the EZ Ride or any new MBTA route servicing the relocated Lechmere and Kendall Square? Will new Lechmere have a major bus stop or will people have to walk to bus stops that make the routes work better?
How did northbound CT2 get to the Kendall subway station? Was it Ames -> Broadway -> Main -> Ames again?
Dunno if this belongs in Crazy Transit Pitches, but I personally think there's something to be said for extending the MBTA's trolleybus network. There are a few key routes that could be electrified relatively easily -- specifically the 77 (Harvard to Arlington Heights) and the SL3 Busway. Trolleybuses are zero-carbon road vehicles that use proven technology and are already in the MBTA's fleet. From a sustainability angle, they're brilliant machines.
Chelsea is really a no-brainier, as the vehicles already in service are dual-mode. The 77 might be trickier, as there wouldn't be enough space in the North Cambridge carhouse to store the additional trolleybuses needed. A few could be stored in a small yard near the Arlington Heights Loop, but it seems that for the number required for full service some portion of the Watertown carbarn yard would have to be used as a storage lot.
Yes, the 77 does cue-jump frequently, but that might happen significantly less often if the BRT-elements that were so successful on Mass Ave return.
I can't see how the infrastructure costs for catenary are at all logical when battery-electric buses are so close on the horizon.
The 77-proper might actually be a good reassignment candidate for the Silver Line dual-modes after their Transitway retirement. Ride the extended 77A wire to Alewife Brook Parkway, then change to diesel on a curb cut for the remaining trip to Arlington Heights. Would put badly-needed 60-footers on that route, allow them to route through the Harvard busway, keep them quiet and emissions-free through duration of Cambridge, but save the expense of installing a couple pricey new traction substations in Arlington that probably can't be justified.
What about Porter Square? I seem to remember reading somewhere that the geometry of that intersection meant that 60-footers couldn't be used there.
Also, I was going to look this up on my own in the old town reports, but I thought there might be the barest fraction of a chance that there would still be electrical infrastructure running under Mass Ave from back in the days the 77 was still a streetcar. If that's still in place, then trolley-stituting the whole 77 might be a bit easier.
So if the Washington El power source is still there, then I'd add the South End/Roxbury Silver Line to the list of potentially easy conversions. That would especially matter if some sort of through routing were ever figured out for the waterfront side of things.
Just noticed this news release from 1/3/19...
MBTA has placed a large order for a new hybrid electric type of bus?
https://www.masstransitmag.com/bus/...ric-hybrid-buses-to-be-powered-by-bae-systems
Is this the first of this type for Boston? How is it different from the MBTA's hybrids already on the road?
