MBTA Buses & Infrastructure
How does the new routing align with the BNRD proposals?
The BNRD interactive map has been updated to reflect this reroute, but the static PDF map (which has not been updated) shows that the routing was originally expected to be mostly unchanged, except that the route would be revised to (somewhat controversially, IIRC) bypass Sullivan to go directly to Assembly. The update to the interactive map shows that they now plan to maintain service at Sullivan (probably because getting from Washington Street to Assembly requires going right past Sullivan anyway.)
As noted in an aside by Teban54 above, this reroute means that all of Cross Street will lose bus service once the BNRD is fully implemented. The portion between McGrath Highway and Pearl Street will still be served by the 80 for the time being, but the portion of the 80 east of Powderhouse Circle is slated for elimination under the BNRD as it essentially duplicates the GLX. However, most people who currently use the buses on Cross Street will likely be able to use buses on Broadway (89 and 101) or Washington Street (rerouted 90 and 109*) instead. Under the BNRD, the 101 is slated to become a frequent route and the 109 has already been made a frequent route in Phase 1.
*The 91 and CT2 also currently serve this segment of Washington Street, but those routes are also slated for elimination under the BNRD.
The Bus Network Redesign (BNRD) interactive Remix map has been quietly updated to the Summer 2025 version. No major changes.
Here are some minor changes based on what I remember from the Summer 2024 version. Unfortunately, the 2024 version was not archived. (An archive of the original Revised Bus Network Map in 2022 is here; only minor changes were made in 2024 and 2025.)
Route 85
Recall that BNRD's Route 85 is essentially today's Route CT2 south of Ruggles, but with an entirely new alignment between Union Sq (Somerville) and Assembly. This section was changed in 2025:
  • Amended to McGrath Hwy, skipping Cross St; likely for the same reason as Route 90 above
  • No longer makes a loop in Assembly Row via the Orange Line station, instead using Grand Union Blvd in both directions
    • This means the 85 no longer connects to OL
  • In the Union Square area, southbound 85 (to Ruggles) uses Somerville Ave and Webster Ave again (as per today's CT2), instead of straight through Prospect St in both directions (as per BNRD 2024)
    • Unclear if this was due to community feedback
    • The Somerville Ave @ Western Ave stop is closer to most destinations in Union Square and transfers to more buses
    • However, transfer with GLX Union Square becomes less convenient
    • Northbound 85 (to Assembly) still use Prospect St northbound, stopping directly at GLX Union Square station
    • Also note that the 47 remains unchanged and uses Prospect St in both directions, even though its predecessor, the 91, uses Somerville Ave southbound
(Note: Don't take the lack of stops on McGrath Hwy at face value. New stops on roads that do not currently have MBTA buses have not been finalized as of the current maps.)
(Inbound)
Route 90
As @alewife mentioned above, the 2025 BNRD map basically makes the 90's route in the East Somerville-Assembly area identical to the Summer 2025 changes via Washington St.
Previously, the 2022 BNRD map suggested two changes to Route 90 below. Neither appear in the 2025 map, which now uses Washington St instead of Cross St and Broadway.
  • The 2022 proposal called for Route 90 to skip Sullivan Square, heading directly between Broadway and Assembly.
  • The 2022 proposal also called for Route 90 to make a loop in Assembly Row via the Orange Line station, just like the 85.
    • This means the 90 also no longer connects to OL Assembly, but it retains the OL connection at Sullivan (which is more popular)
Note: Route 113, the last of the three Assembly routes, has not yet been changed on the Summer 2025 map, and still makes the loop via Assembly OL. As the 113 comes from Chelsea and Everett, it also serves Sullivan. I think the 113's Assembly loop is also unlikely to last, but for the moment, there's no official evidence of this.
(Outbound)
Routes 66 and 86
Originally, in the 2022 Revised Network Map, the 66 and 86 were planned to make the loop around (and layover at) Waterhouse St north of Harvard Square, similar to what the 71 and the 73 did when they used trolleybuses until 2022.
This change no longer appears in the 2025 BNRD map. Now, it calls for the 66 and the 86 to maintain the status quo:
  • Northbound buses terminate at Harvard Upper Busway, then makes a non-revenue turn to Dawes Island and layover there.
  • Southbound buses pick up at Dawes Island as the first stop.
It's unclear why the Waterhouse St loop was suggested in the first place. Unlike the 71 and the 73, the 2022 map didn't even have the 66 and the 86 use the lower busway for boarding; it also didn't have the 66 use the upper busway for alignting. If it did, we could have suspected that they wanted the 66 and the 86 to use left-door buses, but now that's moot.
Perhaps they were initially concerned about Dawes Island's ability for 2 routes to layover? Now that the 86 has been truncated for half a year, they may have decided that it's no longer an issue.
Longwood Notice
A new textbox has been added to Longwood Medical Area:
Routes 66 and 86
Based on my observations, the 66 and 86 currently loop around Cambridge Common via Waterhouse Street to lay over after alighting in the upper busway, as the 71 and 73 did in the trackless trolley era (and are planned to when left-door-equipped BEBs enter service at North Cambridge).
However, unlike the 71 and 73, those routes do not serve any of the stops on the loop (Garden St/Mason St and Waterhouse St/Mass Ave), which is likely why it doesn't appear on the map.
Hmm, the 66 and 86 still had their layovers at Dawes Island as of Q1 2025 when I last visited there. Perhaps that was a more recent change?
The Waterhouse and former Dawes Island layovers also have space on Mass Ave south of Waterhouse now: these parking spaces: https://maps.app.goo.gl/Yjgax8HRhADaYWgd7
They're trying to address bus layover in active stops because a bus laying over at Dawes Island for example blocks accessible boarding for other routes.
Blue Hill Ave bus lane meeting tonight!
Good lord
First, these people don’t represent the “community”. It was 100 people. Second, the whole idea of community process has gone so far to the extreme… maybe urban renewal in the 60s was too extreme, but at a certain point the govt needs to make changes for the greater good and recognize that individuals never embrace the changes most needed if you ask them.
One wonders how the 28 ever had the ability to become the highest-ridership route in the entire MBTA bus system when we're told so repeatedly that every user of BHA needs a parking space and that local civilization would collapse with even 1 space's worth of reduction.:unsure:
Couldn't be reporting bias, could it?
This would be a great improvement. Similar to the Blue Hill Ave conversation, bike lanes would be a great plus (I want them as much as possible) but the bus lanes are the shining gem of that proposal.
I get a kick out of the folks who talk about not seeing bikes as a reason for not have the space for them. I'm willing to bet back in the early days of cars, the idea of building roads with asphalt that was bad for horse's feet was also looked upon poorly.
Also, you don't see many cars on dead end streets for the same reason you don't see many bikes on dead end bike lanes. Until the network is complete, connected, and goes somewhere, it will be underutilized.
Somehow they dont see the irony in claiming making all spots 15min only would fix everything but also that they themselves ignore the current 30min limit. They then claim they want people to come and stay in the neighborhood patroning their business but also want people to get ticketed for their 15min parking idea. I grabbed a sub at Brothers last week (by bus) and just getting my order in and recieved was 15min. All the other business in the area like groceries, appliance stores, and hair salons will take even longer. This is all not to mention they already did a parking analysis study that revealed only like one side of one segment had parking usage at or exceeding 100% during rush hour only. Which they accounted for in their redesign, strategically increasing spots in that area at a reduction in a less utilized area. This is all all not factoring a single 28 carries more people than every car filling every spot on one side of the existing BHA configuration.
The math doesnt math
Part of the presentation were existing or soon-to-be available citywide transportation services, starting with the EZRide shuttle bus service that began running seven days this spring in Eastern parts of the city: from 6 a.m. to 8 p.m. on weekdays and 9 a.m. to 9 p.m. on weekends. A formal start to seven-day service, with officials present for a ribbon-cutting, was June 3 at the CambridgeSide mall.
The presentation by Reker said there would be improvements from the regional Massachusetts Bay Transit Authority, though the agency has not committed to a start date.
In the next year or so, more buses would come to Massachusetts Avenue, “so that during rush hours in particular, a bus [would] come every seven minutes,” Reker said.
A new MBTA bus route may be set up to connect Inman Square, Central Square and Cambridgeport with regional connections to Boston’s Fenway and Longwood Medical Area as well as Union Square in Somerville, Reker said, but the timeframe on this is also unclear, and further out – the route is expected to become operational only in a few years.
Mayor Wu's administration has removed a dedicated bus lane from North Washington Street between Haymarket and the North Washington Street Bridge, a decision that will force roughly 15,000 daily bus riders – the vast majority of whom are lower-income and Hispanic riders – to wait in more traffic.
Last week, the City of Boston repaved North Washington Street between Haymarket and the new Bill Russell Bridge.
The paving project removed all lane markings, but a city spokesperson told StreetsblogMASS on Tuesday that the city does not plan to restore the northbound dedicated bus lane, which serves MBTA bus routes 92, 93, and the 111.
The city's decision was made without any public hearings or input.
So I would really like some input from some neutral parties here. How bad was the traffic because of this bus lane (and obviously I’m asking about rushhour)? I’m not looking to hear from anyone who’s going to show me traffic counter numbers or who just doesn’t think that any of the bus lane and bike lane stuff has caused traffic to get worse. In my opinion, I’m almost entirely for all of the lane reductions as a matter of principle, but most of the urban core areas, there is no question they have made traffic worse. I’m never in this particular area though, so I just don’t know. I guess what I want to know is not just whether traffic around here got worse because of that bus lane, but because the answer to this question sheds light on why the mayor is doing this: is it to actually reduce a traffic problem, or is it because the people who are going to see the removal of this bus lane are all redblooded townies and she’s trying to get their vote?
Theoretical maximum vehicular flow is 1800 veh/lane/hr. Assuming 40% green time at the Causeway St intersection, a continuous 22 hours of perfect traffic flow (ha) would move 15,840 cars.
Also total coincidence all but 10 of the 16,000, about-to-be-pissed daily bus riders just so happen to live East of the Mystic, unable to cast ballots in the Boston mayoral race.
Per that article, about 1/3 of the riders using it are 92/93 riders, who do live in Boston.
For the record, this was the press release when it was installed:
the bus lane was put in when the bridge was already under construction and there was only 1 NB lane going over the bridge. theory was that you didnt need 2 lanes feeding it. The bridge is now 'complete' and there are 2 lanes again. the 1 NB lane at the bridge is what caused the traffic issue, the bus lane came after. If the bus lane stayed it would certainly become the choke point and there wouldnt be anybody abiding by it (they already didnt even when there was a forced merge at the bridge).
this is a 150 second cycle intersection with 5 phases (SB advance, SB/NB, WB Commercial, Endicott St, EB Causeway). none of the approaches are getting 40%.
and all of the riders coming over the Tobin now have an inbound bus lane from the Tobin off ramp all the way to the existing N Washington SB bus lane (which is staying).
Historically, traffic outbound wasnt typically terrible, but there has only been 1 lane open outbound on the bridge since 2018 (when emergency repairs to the old bridge started). will be interesting to see how it all operates again. its been a long time
