Yes! It makes a pretty good TOD stop as it is. Tightly nestled into what, in the burbs, passes for a kind of walkable density.
Really should get its own little TOD neighborhood (given that Anderson is just Acres of Asphalt and always will be)
The "walkable density" is much, much less than the sum of its parts. Yes, there is a residential neighborhood in spitting distance to Mishawum, but it's not all that it seems on Google Maps because the 128 overpass on Mishawum Rd. has no accessible sidewalk. The station is virtually useless for anyone living on the denser side of the highway unless they want to waddle in terrifying proximity to screaming traffic.
TOD-wise the station's been a longstanding failure since they've been trying to stimulate that angle ever since its 1984 opening without much success. It's got a couple hotels nearby, but Woburn Mall has never congealed into more than a bland massing of big boxes. I suspect the increase in walkup may have been tied to the bus service cuts of the last 5 years that nipped a couple infrequent-running routes that touched Mishawum, and a relatively small number of people being committed to walking slightly longer-distance.
I also think the unfinished west entrance to Anderson RTC is making Mishawum linger on where it otherwise wouldn't. There's another dense-ish residential pocket off Merrimac St. west of Anderson, and that stop could get a big boost from the locals if the 134 were able to drop off at a New Boston St. entrance rather than fizzing out near the Wilmington town line. And it's definitely inhibiting any permanent establishment of 128 biz shuttles, which in their previous short-lived incarnations couldn't take any swing through the industrial park where all the jobs were and hit the station where the service was. Finishing the west entrance + the pending reconstruction of the missing New Boston St. bridge + better bus/shuttle connecting transit centered on Anderson probably eliminates the need for Mishawum.
And you may well need to eliminate Mishawum in order to do RER worth a damn, because that stop can't be redone with full-high platforms. Freight clearance route and zero room for passing tracks at that site, so it's a mini-high forever along with the river-spanning Wedgemere platforms. All other Lowell Line stops, including a more residentially-useful Montvale Ave. infill, are or can get rigged up for level boarding non-invasively with the right touches. So Mishawum's also the very last stop you want preventing auto door use or causing unnecessary door trap flips when the time comes to start bringing Urban Rail frequencies to the due-north 'burbs.
