if you're all talking about the vertical "fenway" signage on either side, yeah -- that's obviously lit-up signage. those are clearly not banners.
It's a theatre! It's in an entertainment area! Banners are festive, they add color and dimension to grab your attention the same way that neon signs and all the new LED light boards do. This is actually a perfect location for banners.
Behind the lit "FENWAY" signage:
If the banners are the biggest problem we can find with this theater, then the project's a win.
I'm not convinced those are banners anyway. They look to me more like video panels. So yes, sort of banners, but not in the traditional sense. Look at some of the larger images posted by stick n move, they look more like veins, with some three dimensionality.
Note this one, in particular:
I just saw this tweet. Does anyone have a B&T subscription? Interested in knowing which groups are squawking about the "intrusive" redesign.
Steve Adams
@SteveAdamsTweet
1h1 hour ago
Groups criticize "intrusive" redesign of @fenwaypark including loss of bleacher seats to make way for event facility, concert hall https://www.bankerandtradesman.com/groups-target-fenway-park-redesign/ …
Steve Adams
@SteveAdamsTweet
1h1 hour ago
If this is what it sounds like, then amen, go "groups."
Build the theater as proposed. Just but don't rip out the upper bleachers.
EDIT: Also, public comments are posted (pdf).
Ppl need to look at the bigger picture, if you run this thing into the ground, shitty parking lot stays, a needed theater capacity is not added to the stock of the city. Theyre not building luxury condos here... If 2 rows of nose bleeds need to go to build an ENTIRE theater, so be it.
Stick, we've been over this. The "Fenway Park Improvements" (i.e., removal of the bleachers) and the parking lot "Fenway Theater" project are entirely independent from one another. They are, in practice, two separate projects. You are framing a false choice. The theater project in no way hinges on the bleacher removal.
I was serious when I asked for your suggestions, you're an architect. Better facade design sounds more like a slap down. Or a lazy answer. Sorry to have bothered you.
