So the solution is do nothing?
I'd see HOT [snip]. . .
I wish I had an electric shocker every time HOT's got cited as some deux ex machina congestion solution. No...just, no. Kill it with fire. Same goes for that managed lane nonsense on 3 as a realistic solve for replacing the should-be-illegal breakdown lane travel. If you're going to solve a problem, do it right...not with gimmicks. An HOT over the bridges would do nothing for that location. It would introduce yet another merge on the sides of the bridge where there's already a crowding problem with those and end up undoing a lot of the approach improvements. There also isn't an inbound/outbound schedule that you can set a clock to like a CBD's rush hour cycle. It's frequently crowded in both directions because of the fucked traffic patterns miles out, and Saturdays during peak season can run pretty close to par on departures/arrivals from folks shifting their beach weekend early or bouncing between Cape and mainland on day trips. Plotting utilization to a schedule is going to be fugly at best; reversible lanes with inexact decisions on when to reverse, unidirectionals meandering between over/under-capacity too easily. And it's space-intensive on a water crossing, which needs to stick to the basics to be buildable in budget.
4 lanes, AASHTO-standard geometry, and a bikeway sidewalk. That's it. Take
enormous pains to get standards-compliant merging over with on the mainland even if that means nipping at property acquisition to ensure it gets done right. And for the love of god end this willful blindness to the deplorable configurations of 6 & 28 a full ten miles out and eat your peas on those modernizations so this project has a fighting chance to do its job.
As for commuter rail, we've already got
good data on that. The only thing standing in its way is South Coast FAIL sucking all the oxygen out of the room. The studied proposal specs:
- Full-schedule extension of Middleboro Line to Buzzards Bay, with intermediate stop at Wareham Crossing (495/195/28 interchanges + shopping center). The current Cape Flyer stop at Wareham Village wasn't considered in the last study because of concerns that the platform sits in an unmetered local parking lot that would be difficult to regulate...but attitudes may have changed now that the Flyer's been good for downtown.
- Doable with existing equipment if all rush-hour Middleboro consists ran as 6-car all bi-levels instead of mixed consists.
- 74 minute BB-Boston travel times using no intermediate stops between Middleboro and BB as a measuring stick...+3.5 min. for every intermediate added (so ~82 min. if you include Wareham Crossing and Wareham Village as probable intermediates).
- No layover required at BB as shift-changing trains will deadhead back to Middleboro (which has expansion space if needed). Add'l cost for daily deadheading offset by not having any cost for staffing/equipping/powering a new layover. 1 pocket track west of the Academy Dr. in what was once the 'old' layover is sufficient for onsite storage.
- Signalization from Middleboro to the Canal, lengthening of 1-2 existing passing tracks south of Braintree, 1-2 passing tracks south of Middleboro (mostly refashioned from existing ones).
- Deduct from study cost estimates all Cape Flyer-related upgrades, which have already taken care of all necessary crossing upgrades, most necessary bridge upgrades, and nearly all necessary running-rail upgrades. Yes, it will cost less than the study because we already paid so much forward on the Flyer.
- Construction of 800-ft. full-high platform at Buzzards Bay (tricky spacing allowances between Academy Dr. and bridge-tender shack, but doable). The study kvetched to excess about parking capacity, but let that be the locals' problem to figure out.
- (if included as station stop) Reconstruction of Wareham Crossing wood full-high as 800-ft. permanent structure, + misc. station facilities.
- (if included as station stop) Construction of Wareham Crossing at Main St. grade crossing behind shopping center. Public-private TOD considerations should be in the funding mix, as the study suggested.
Nothing too fancy or controversial. Though it does not cross the Canal it defrays lots of traffic swarming the area from Mattapoisett, Marion, Rochester, mainland Bourne, and the southern expanse of Plymouth which instantly helps the bridge situation.
From there you can look at super-extending a couple express trains to Hyannis in each commute direction. You are allowed to run 8 daily trains in unsignalized territory without triggering the PTC mandate. LIRR's Greenport Scoot does this into Penn Station every day. Allowances for the M/W/F trash train may require that total get cut down to 6 passenger trains (Cape dinner train only runs weekdays on days the trash train doesn't, so is a non-factor). So you could schedule 3 AM inbound and 3 PM outbound Hyannis trips daily making stops at Hyannis, Sandwich, West Barnstable, and Bourne/Sagamore (wherever the permanent stop that replaces temporary Flyer stop Aptucxet ends up getting sited), then skip-stopping on the mainland Buzzards Bay, Middleboro, Brockton, Quincy Center to make up time. The only infrastructure requirements would be closing out all Flyer-related upgrades to the Cape Main tracks for consistent 59 MPH speed and equipping Cape Cod Central's Hyannis Yard with layover equipment (you could even live with Sandwich & Barnstable as low platforms for now since they've got full ADA mini-highs). You can set the bar there and see how ridership performs before making any decisions about negotiating more bridge openings, signalizing some/all of the Cape, and so on. I think it's got a good shot of overperforming on ridership despite the extremely long travel time, but doing just the couple extened runs off an otherwise BB-focused full extension means you don't have to stick your neck out very far at all to capture some extra value.
If you've got those nuts-and-bolts in place, then Cape Cod Central is conveniently there to pitch in with the Falmouth Branch. They have a Budd RDC and the wherewithal to get more, and the Falmouth Branch is slated for thorough upgrades which should eventually ramp it up to an even 30 MPH passenger. Next big item on the wish list is land acquisition at Cape Jct. to carve out an east wye leg so Falmouth trains don't always have to cross the bridge to BB and the dinner train can make a complete Hyannis-North Falmouth circuit ($$$ in it for them, because the Falmouth Branch has some of the best scenery of any rail ride in New England and they're dying to tap more of that). Cut deals for use of the existing station buildings at Monument Beach and Catumet and erect inexpensive 1-door ADA ramps (more like what the Mattapan Line has for front-door access than a ful-blown T mini-high), then throw some skeletal platform access at the former Pocasset and North Falmouth station sites. Run a commuter dinky to transfer at BB a couple times per day (Cape Jct. is signalized by the bridge-tender so it would not waste any Hyannis slots in dark territory) for a smidge of Falmouth-side congestion relief at a homeless-man's cost threshold that CCCR can a quick buck on.
That's a lot of good spread around a very low barrier to entry. Too bad the SCR M'boro Alternative has pretty much shot this entire sane-n'-sensible package to hell.
