Portlander
- Apr 14, 2010
TC, there was no mention of any party not wanting to do this. I've planted the seed and these changes take time and I don't see anything happening until the baggage claim improvements are nearing completion. The grey painting of the exterior trim (to replace the blue) on the front of the terminal near baggage claim still has not been finished and that "minor" project has been going on for over a year. There is no such thing as an easy fix in today's world!
No, I am not. I'm simply showing something ideal. Never, would anything like this be built in Portland, ME. Portland, OR did because of their substantial rainfall, I'm assuming. I'm saying that covering the complete area outside of baggage claim is good for passenger comfort and a good first impression for visitors. The same goes for car rentals. Portland gets it right. In Bangor, you have to pick up your car in an outdoor parking lot, and in winter, brush all the snow off of it. The driver side outside baggage claim in Portland is somewhat exposed to the elements. And if getting a cab, it's uncovered for the passengers needing a ride.It's beautiful TC, but you are comparing the 33rd busiest airport in the country to the 95th.
A related Jetport pet peeve of mine is that the exit up the escalator directly to the garage level 3 (which puts you out by TSA) is often closed very early in the evening so you have to walk allllll the way to Gate 1 and then around rather than a quick exit to the garage.Compared to some of those others, PWM is a slight step above. The departure drop-off section has a lot of coverage from the security wing and a pretty fair awning over the spaces that aren't under that. Baggage claim is the real issue, at least to me, since the internal configuration of the Jetport has changed enough that the two large awnings that connect the terminal entrances to the garage now handle entrances that are far-less used; one leads to the Big Empty Zone and the other is probably mainly used by passengers who don't have checked luggage (come down the escalator and straight out the door). I'd have a fresher handle on it if my flight home hadn't gotten cancelled in May leaving us to book new tickets to Boston instead.
