Nexis4jersey
- Mar 2, 2012
Whats the Blackstone line?
If the passing track is constructed at Kingston, Regional Amtraks started stopping at TF Green, and commuter rail service was extended to Kingston and Westerly, wouldn't it make sense to convert Kingston to a commuter-rail-only station? It seems to me that Amtrak making 4 stops in RI would be overkill, and slow Amtrak trips unnecessarily. If Kingston had CR service and Westerly had a transfer to and from Amtrak, Westerly, TF Green and Providence would be plenty of stops for Regionals with Express trains only stopping at Providence.
Why is the Pawtucket infill stop part of a Woonsocket extension? Seems like a desirable project all on its own.
Kingston's a Top 50 station in Amtrak ridership, so I very much doubt they'll ever give that one up. There's likely to be some shifts of ridership away from it to T.F. Green which may affect how many trains stop there, but it won't go CR-only. If Shore Line East gets extended to Westerly to meet RIDOT, then Mystic is almost certainly going to get dropped from every Amtrak schedule and go CR-only. With Westerly probably getting much-reduced (but probably not totally dropped) service. That recalibrates enough that they wouldn't have to drop many trains stopping at Kingston to accommodate T.F. Green. I would imagine it's just going to be wholesale load-shifting across the Regionals schedule re: what stops where east of New London and south of Providence. Everything will give and take a little to balance out the demand and travel times across the schedule.
That having been said, Kingston has far more room to expand than Westerly does - three tracks is a definite go here but four or even five tracks is possible if the adjacent industrial parcel and PW are amenable to working a deal out. Westerly is never getting four tracks.
That's not RIDOT's goal with the instate service. They put in bright lights that they want four-fifths of the state's population to be within 10 miles of a commuter rail station, a feat accomplishable by that one contiguous line tracing between Woonsocket and Westerly. How the service patterns overlap and serve the overlap areas of higher density is going to be forever negotiable and forever changing. There is no "One True Terminal" to be had anywhere. That's no longer true of Providence. It won't even be true of Woonsocket forever if they have Worcester in their long-term sights. Such a rigid construct just doesn't exist here because it's not one end-to-end service pattern. It can flex and breathe and overlap. So it's faulty logic to pin the word "terminal" on any one stop.Kingston sits at the bottom end of one of the only two Class 9 track segments on the Northeast Corridor, and Westerly is pinched up against a rather severe curve. Actually, if you've ever been on a Regional stopped at Westerly, the entire train is tilted slightly - it's rather trippy and (for me at least) discomforting.
Westerly's travel patterns and demands are far more heavily skewed in the direction of CT/NYC, with the Airport and Providence being a strong secondary market and Boston being a tertiary one. At Kingston, Providence could become the primary market and demand for travel towards Boston is far heavier.
Kingston outperforms Westerly in ridership by about 500% - that Kingston gets a little bit more than double the service Westerly does explains some of this but not all of it.
Again, I'm biased, but I don't really like making the connection point between Amtrak/Shore Line East/RI Rail Westerly nearly as much as I would like to see it in Kingston, which has plenty of room to grow into a proper terminal that just isn't present in Westerly, and the fact that Westerly's station is 'downtown' and spitting distance from the CT border doesn't rate highly enough to make it worth the additional challenges inherent in trying to build out the station there.
3 tracks is Amtrak's tippy-top buildout for Kingston in their NEC Infrastructure Master Plan. Arnold's Lumber is a big local business and reliable freight customer, and I think there's a microbrewery that's taken up residence in one of the warehouses on the adjacent parcel behind Unilock. State's not interested in playing God with a site that's already contributing well to the local economy. If the lumber business were to die out, then it's of course fair game for TOD redevelopment. But that's pretty unlikely to happen before commuter rail service is a decade or more into being firmly established here.
The Amtrak renovations have also been slowed up by lots of invasive utility relocation on the yard side that have to be moved before they can build the 3rd track/platform. Underground pipelines and other mission-critical stuff. So it's not a wide-open parcel free for the trains' taking. The kind of utility relocation required to do something more substantial than park a few boxcars there is stuff better left to TOD developers digging a big foundation, not commuter rail.
Some other track capacity issues to keep in mind as well. . .
Central Falls where the P&W mainline converges to T.F. Green is going to be continuous unbroken 3-track. All stations between Providence and Wickford are due to be built as 4-track turnouts for 2 platformed outer tracks and 2 Acela + freight center passing tracks. The continuous tri-track has to end where it does because the ROW gets squeezed by a series of 2-track only bridges, close-abutting development, and wetlands for a long stretch in Warwick around Apponaug Cove. For this whole stretch it has similar characteristics as the unexpandable Shoreline in CT: adjacent water, adjacent dense waterfront property, and too much wetlands for plausible expansion.
Second, the reason for doing 4-track stations with 2 middle passing tracks here but not at Kingston is because of those monster freight trains that run from Port of Davisville to Central Falls en route to Worcester. The Acelas have to overtake 25 cars worth of autoracks in the mid-afternoon here every single day of the week. It's the 7th largest auto shipping port in the country. They don't have to do that south of there. The only freight whatsoever between Davisville and Groton is a light move to Arnold's Lumber every week or so that doesn't have to be time-specific. So 4-track turnouts at Kingston does nothing for the Amtraks when the cap on their service density is all on the unimprovable CT Shoreline. Building one would be little more than a cosmetic waste of land acquisition; there's no real capacity gains from it.
The only place there has to be a bureaucratic "terminal" is Westerly. Because the MBTA doesn't have a cross-state subsidy agreement with CTDOT like it does with RIDOT and can't cross the state line. And CTDOT doesn't have one with RIDOT and is unlikely to pursue one. But that doesn't mean Westerly has to unsatisfactorily be the Capital-T "Terminal" when there's enough flex to overlap the densest areas of the state with any combination of service.
Their own scoping reports talk about 3 overlapping service patterns: Westerly-Providence with maybe a +1 poke north to Pawtucket, Woonsocket-T.F. Green and some indeterminate reach a little bit south, and DMU service in the middle. The only things that really limit the imagination there are:
-- Westerly, the big-ass centrally located MBTA yard in Pawtucket, and Woonsocket are the places with the planned layover yards. Elsewhere (including Kingston) there either isn't room for one or the prospective sites have major complications.
-- Woonsocket-Westerly is definitely too far and doesn't serve an end-to-end constituency.
-- There are southern limits to how far you can over-extend the Providence Line schedule, and we may already be demographically past that point. Also, service on that massive a scale just can't roam too many stops south of humongous Pawtucket yard without starting to feel an equipment pinch.
-- CDOT is never ever ever going east of Westerly. That is the end of their instate constituency, since it is the backdoor neighborhood stop for the Pawcatuck area of Stonington. It's just dumb luck that it happens to be 500 ft. over the state line, happens to have a layover yard, and happens to have a transfer to RIDOT by virtue of T-logoed Purple Line trains not legally being able to cross the CT state line. Happy coincidences all.
That draws some fuzzy boundaries. Nothing fully cross-state or interstate is going to push more than 2-3 stops beyond the huge Pawtucket facility before it has to wrap up its journey out of practicality. There's your practical southern limits for Woonsocket and the Providence Line, and Westerly commuter rail won't ever be pushing into Massachusetts. There's your east limit for Shore Line East; Kingston is far too many miles from the nearest layover to turn back, and the interstate political hurdles combined with no natural CT constituency in the density cavity east of Westerly gives CTDOT no motivation to self-choose to go further.
Where did I say TOD development? I'm not out to get rid of the lumber business and/or try to aggressively up-zone in the middle of a small town with the kind of small-town politics that makes adding a grocery store on the main street a controversial suggestion.
The kind of utility relocation required to park a few boxcars is also the kind of relocation required to park a turning commuter rail train on an 800' turnout track that can feasibly be added between where Track 3 is going in and the freight siding getting refurbished. It doesn't actually need to be connected to anything further south/west if Kingston is a terminal station (and even if it is connected at the other end it doesn't need to be longer than around 1000' at most - no need to deal with the 138 overpass), and there's massive quality of life improvements inherent in being able to walk transfers across a platform and tie up one of the side tracks with a five/ten minute layover which you probably won't be able to do at Westerly.
No, there isn't. Amtrak studied the everloving shit out of this for 25 years, and determined there isn't. Trace the ROW yourself on Google Maps. The 3rd track is already in place south of Providence. You can't fit 4 unbroken tracks, space on the side of ROW for catenary poles, electrical boxes, etc. the entire distance without blowing up half the bridges and doing a lot of land acquisition. There are broken stretches of 4th track space to tap by gobbling up space that was used for extinct freight sidings...but that's exactly what they are doing at all these infill stops including max-build Green and Wickford. This is the max build. And it's plenty good.There's absolutely room for continuous four-track between Providence and Warwick and there's probably long-term demand for it too. South of Apponaug I agree is problematic but there's zero good reasons not to push hard for the unbroken fourth track at least as far as T.F. Green. An Apponaug Station on the other side of the Cove (where Arnold's Neck is) would be a nice-to-have, but not required.
If Amtrak's studies show that the NEC in Massachusetts gets its 2035 Amtrak and Providence Line congestion solved by tri-tracking from Readville to Attleboro...how does RIDOT need quad tracking to avoid its trainmageddon? That makes no sense. Everything Davisville-north is already going to be a 4-track station because of the turnouts. That's way more cushion than Mansfield and Sharon and Canton Jct. are getting. And the Providence Line is simply not capable of sending a full-blast schedule nearly 75 miles from home before its own equipment and schedule cushioning needs start choking off supply of frequencies, so the # of Boston schedules continuing past Green will always have to drop off a cliff. Where does one come up with enough service demand in RI on intrastate runs + whatever small % of Providence Line stragglers do super-extended runs on the schedule...to end up with more service density at Kingston than inside I-495? That doesn't make sense.There are real capacity gains from it - for RI intra-state service. Just because Amtrak is capacity limited by CT doesn't mean RIDOT has to be or should be.
They are the same capacity gains you get from placing a 'strategic turnout' anywhere else in the area but with the added quality-of-life benefits inherent in having that turnout be co-located with an active station.
The population density difference pretty much ensures it'll never happen. Providence Line is not the New Haven Line. Never was, never will be. The New Haven Line is 3 or more Providence Line's worth of demand on one route, with EACH service pattern bringing in the same or greater haul. It's a stratospheric difference that doesn't compare.Two points:
1) We absolutely are past the cutoff line in terms of Providence Line extensions and have been since trains started running to Wickford Junction. When commuter rail starts running to Kingston/Westerly, it'll be as a RI train no matter what shape the RI service ends up taking - the MBTA will not be running any trains direct from Kingston to Boston.
Personally, I think that's a mistake, and I think that we should be looking to some of the things that Metro-North does emphatically right to model Boston's commuter services - most pointedly, regular operation of local-then-express runs, with the changeover point being Providence. But that's probably not going to be happening any time soon.
^This is an unhinged statement. It is. Unhinged. Calm down.2) It doesn't matter if it's 500 ft, 50 ft, or 6 inches over the line - it's over the line, and therefore there needs to be an agreement in place to operate across the state line. If CTDOT really has no interest in pursuing an agreement to operate over the state line, then they by definition also have no interest in operating to Westerly, which we know for a fact is not the case at all. Conversely, any scenario in which they are operating as far as Westerly is one in which they can and should be operating to Kingston.
So I don't get why there needs to to be visual confirmation of idling trains in a layover yard or the aesthetic satisfaction of counting 1-2-3-4 tracks every time you glance out the train window. Amtrak's own math says the capacity meets or exceeds the wildest growth the state's own population density can muster for the next 30 years. And that by the time anybody needs more local slots they'll have their Inland 2040 HSR built and be prying more of their trains off the Shoreline instead.
They showed their ops math. You're going to need to show yours if you insist all their track capacity assumptions are wrong.
And while this cross-state subsidy agreement the T has with RIDOT is making all this intrastate expansion happen, it is not an integrated two-state agency like Metro North is. The T still has a primary responsibility to its in-district constituents and at maximizing the revenue intake from them. And that does place priority on sending the Providence Line where it's going to enrich Massachusetts' coffers the most. That means a dense and locals-heavy schedule without too many runs skipping a Canton, Sharon, Mansfield, or one or both Attleboros. And not too far a reach where the farebox recovery to a Wickford and a Kingston isn't being put back into to MA's coffers on the return trip. At a certain threshold of Providence Line boarders that far south using it as an extra intrastate train on the schedule, it loses enough in-district value to not be in the T's best interests to do. And most definitely not in their interests to accommodate by dropping any revenue from the MA stops for the sake of more expresses deep over the border. That's where the limits of the Purple Line's interstate integration show itself; Metro North's true two-state agency charter is set up to divvy those proceeds in a way that that the parasitic (good kind) RIDOT working arrangement isn't.
How much intrastate vs. interstate travel is too big a reach for the Providence Line? Don't know. But as you suggest and the early results suggest, we're probably already past that diminishing returns point and need to firm up the outer limits of the T district for everyone's good. Future Providence Line service enhancements depend on that continuing to be the highest-margin in-district run, and if denser intrastate schedules are what Kingston needs more than a Boston direct every half hour...fill the slots with what they need the most.
"500 ft. across the state line" is not crossing some international border. It is the only place CT can tie up their instate service in a bow. Shore Line East cannot turn at Mystic station as the end of the line. Can't. There isn't so much as a crossover within miles for switching back onto the correct track, because the Acelas wouldn't be able to tilt if switches were placed too close to the numerous curves and bridges. Non-negotiable for Amtrak. Shore Line East also cannot turn at Mystic or Stonington unless there's a layover yard out past New London. 2 movable bridges separate that end of the line from New London, massive amounts of P&W and NECR freight coverges on either side of the Thames, and there's no available land clear of the drawbridges to build out because of abutting residential or unbuildable wetlands.
Go to Westerly...or they wash their hands of Groton and the Mystic and Pawcatuck halves of Stonington forever and SLE never goes any further than New London. Now, would you argue that RIDOT do this if the shoe were on the other foot? If "Pawcatuck" station a block over the state line were the literal difference between having any commuter service west of Kingston or not? No, of course not. You're arguing the exact opposite for all things RI. Don't be selfish. People in CT want the same things from their DOT as you want from yours, and it's not your call to tell them who's more worthy.
CT has a self-interest in serving its riders. They will gladly pay for 500 ft.'s worth of subsidy and a layover yard rental when most of the walkup ridership is theirs. This is no different than what the T is attempting to do tying up its district in a bow in Plaistow and Nashua to ease the parking crunch at Lowell and Haverhill and build bigger layovers for bigger schedules on each line. That's not "New Hampshire" commuter rail. Nor was the Providence Line "Rhode Island" commuter rail in all the years up till the last 5 when RIDOT was barely paying in. They're the non-kludgiest ways to serve the borders of the district without forfeiting service within the district or dumping too many interstate park-and-riders in lots where they shouldn't be.
As for SLE to Kingston. . .
CT has no self-interest in serving Kingston. That is not revenue that's going to be repaid to them on the return trip east...not revenue that's going to be repaid to them by a large constituency transferring to Metro North. It is RI intrastate commuter rail and making CTDOT run RI's own service west of Kingston so you can selfishly get more Boston service to Kingston. Didn't we just establish that the T has little self-interest in over-serving areas south of Providence? And that...yeah, some of that's legit. So why are we sticking "can and should" dictates on CTDOT about running even further afield for RI's sole benefit.
Why? Because fuck Connecticut, I want my stuff! Don't be hypocritical. You know RI is not in a position to be making those kinds of demands when it has to live vicariously through Massachusetts to get the service it's currently rolling out. They are getting a plenty sweet deal exploiting the areas of common interest. It is the height of arrogance to demand some other state give them satisfaction when CT has none of the self-interest in serving RI that MA and the MBTA do.
That's a hell of a lot of bridge work and property taking for a project that seems to be of marginal value versus station passing tracks.
That's a metric assload of bridges. Which Amtrak says is not needed for their capacity or commuter rail capacity. And which they are planning to bypass entirely in 30 years.Bridges that would need to be destroyed:
- Coronado Road overpass.
- RI-37 extended offramps to Post Road/US-1. Necessary destruction as part of an unrelated medium-term project anyway (reconfiguring the ungodly mess of the RI-37 terminus) and therefore net-neutral with regards to quad-tracking.
- Reservoir Avenue (RI-2) overpass might need support reconfiguration.
- Magnan Road overpass.
- Cranston Street overpass & Niantic Avenue. RI-10 over-overpass here might need to be reconfigured.
- Union Avenue overpass.
- US-6 overpass, Westminster Street and Broadway Overpasses (mitigated by Olneyville - Broadway / Westminster Station). Only necessary because of stupid Track 3 placement, could be avoided if Track 3 is ripped out and repositioned to provide the necessary room for Track 5.
- Harris Ave. onramps to US-6. Could simply be eliminated outright.
That is a lot of affected properties. Do width dimensions make this any easier when EVERY homeowner and private property owner on those strips needs to be dealt with?Property takes necessary:
- About 4-6 feet of backyard on abutting residential in Hillsgrove between Coronado Road and the former Ann & Hope Complex. Residential takes combined with the overpass might be too challenging, but this is less than 0.6 miles of quad-tracking that could be forsaken.
- Some trimming of trees growing on Michigan Ave. Residential as a potential CYA measure. Optional. No actual takes required.
- Possibly up to 2 feet of abutting backyards in Norwood, no demolition required. Mitigated by Warwick - Norwood Station and/or unrelated projects to reconnect cross streets severed by the NEC in Norwood.
- One (1) actual substantial property take on the west side of the NEC, to facilitate a station house for Warwick - Norwood Station somewhere beneath Onset Street and above the RI-37 offramps. Best candidates are the property between Elm and Onset or the space behind the property off of Sargent Street. Station house could be forsaken, otherwise mitigated by the existence of the station and/or unrelated projects to reconnect cross streets severed by the NEC in Norwood.
- Two (2) actual substantial property takes on either side of the NEC, just south of Park Ave. for the Cranston - Park Ave. Station. (Relatively certain these are happening anyway.)
- A whole lotta nowhere land not technically part of the ROW might need to be acquired opposite Huntington Avenue - but this is non-complicated.
- Some problematic land acquisition near Olneyville required (mitigated by Olneyville - Broadway / Westminster Station) only because Track 3 was not provisioned to allow for a Track 5.
- Harris Ave may need to be set back a few feet. No actual land acquisition necessary.
- One (1) final actual substantial property take of a property off Harris Ave. - a storage facility.
Repeat all I said the last 2 times.Miscellaneous notes:
- There should be just enough room to squeeze Track 4 into the existing ROW as it abuts Lincoln Park Cemetery. Roughly 0.3 miles of fourth track is impossible if this is not the case (non-problematic if Warwick - Norwood Station exists.)
- Aforementioned projects to reconnect Elm, Chestnut and Sargent Streets on overpasses or underpasses across the NEC are not presently on the table. However, these are important projects that need to happen.
- Fourth track already in place in Cranston, but on the "wrong" side of the ROW. Fourth track north of Lincoln Park Cemetery could be realigned to this side of the ROW if Lincoln Park Cemetery precludes fourth track there, otherwise, shifting traffic becomes problematic. Alternative alignment that utilizes the existing Track 5 in Cranston requires one additional bridge demolition at Park Ave.
- New interlockings needed immediately north of T.F. Green, immediately north of Lincoln Park Cemetery, and (ironically enough) behind RIPTA World HQ.
- RIPTA World HQ probably the best location for Cranston - Elmwood Ave. Station. Station technically necessary to facilitate traffic shift from Track 3-1-2-4 layout south of here to Track 5-3-1-2 north of here.
- Bridge demolition is pointedly not required for the I-95 overpass or one of the two RI-10 overpasses.
See above. You're counting acreage, not landowners.You and I seem to have very different definitions for what 'a lot of land acquisition' means. I score maybe a third of the fourth track needing dedicated land acquisition and half of that is vacant land which barely counts.
See above re: Amtrak's own tome on ROW clearances.Also, I didn't keep a precise score, but I'm relatively certain that the number of bridge modifications needed is less than half.
It's also somewhat telling that the most complex portions of this - in Providence - are complicated precisely because nobody was thinking about putting a fourth track in when they put the third track in. Oops!
But, since I know you won't believe me just telling you about how there's room for the contiguous fourth track to Providence, allow me to show you that there's room.
I will tackle your other points later.
Whose interests is this serving other than your Transit OCD? There's no problem. It's been studied by everyone. They say there's no need. You, Commuting Boston Student, are the only person in the world saying there's a need for this.
My previous comment: repeat. Whose interests is this serving that make it necessary when federal gov't, state gov't, and the track owner have all concluded it's not at all necessary?
You also can't squeeze an electrified ROW out of that much buffer space everywhere. The support poles have to go in the ground somewhere. The electrical and signal boxes have to go on the ROW somewhere. The outside feeder cables have to intersect somewhere. There has to be side room somewhere for staging catenary maintenance, assembling replacement poles and masts, or just for track workers to walk alongside the ROW. And Acelas can't go in tilt mode along a retaining wall or under a bridge without some flex. Pinches are of course allowed, but electrified high-speed lines are more space-intensive and on any given mile will have several instances of misc. structures and other situational buffer space that has to be there. And doesn't have to be on some meandering diesel branchline.
Pull up some of the CAHSR technical documentation for the dimensional stanards. They're all based on Amtrak's own NEC recs for new construction, especially the parts covering electrification allowances. Amtrak wrote that book. They upgraded the Shoreline to that book. They are not throwing that book away because someone told them "fuck best practices".
