Seems like GLX terminating at Rt 16 is the furthest it will likely go for a long while. Bridging the Mystic doesn't seem to make sense for a +1 West Medford extension. The farthest afield that probably makes any sense for GLX would be to Wedgemere to replace the Commuter Rail stop, but I wonder if there would ever be enough ridership demand from the neighborhood to justify that. Can't easily go farther than that because a tunnel under Winchester Center would be needed.
Looking wayyyy off there could be a complete hrt takeover of the Medford GLX branch that takes over all/most Commuter Rail stops up to Anderson, but that's getting into "choose your own adventure" territory.
When it's time to grade separate West Medford there'll be opportunity to consider extending. The ROW would be sunk in a 4-track width cut coming off the Mystic bridge, with Canal St. overpassing the descending cut on a new bridge, High St. passing over the point of maximum depth, and a slow rise back up through Playstead Park after the platforms. If everything from the side of the Ride Aid building to the Playstead Rd. sidewalk (75-80 ft.) were framed by retaining wall, there would be room down in the pit for both modes side-by-side and any one mode (but not both) to have a platform. Even if only doing it for Lowell Line RER the cut wouldn't be any narrower than this, since any opportunity to build 100-year allowances non-invasively within existing property lines is going to take full advantage of all available width to bank TBD track expansion regardless of which mode uses it.
If that gets built, then it's really not that large a cost justification to consider widening the Route 16 and Mystic River arches to hook it up. Though in this case the extension may as well keep going to Winchester Ctr. because the ROW room is readily available and the wooded areas bordering the tracks through Playstead Park and Mystic Lakes are non-wetlands and easy to widen out. GLX tracks would be traveling along the westerly side of the ROW. To go further you'd need to:
- Cut trees and track-shift within the property lines.
- Widen Grove St. overpass.
- Widen Aberjona River and Bacon St. overpasses @ current Wedgmere Station. Note on Google how the Aberjona bridge has ancient footings for expanding >2 tracks, so shouldn't be a big EIS'ing deal to rebuild within that footprint.
- Keep widened tree cut on ROW on Ginn Field side north of Bacon St. to stay away from adjacent homes. At start of Winchester Center incline, keep CR on viaduct as today and send GLX stubbing out into the west parking lot. Install pocket track on approach for mini-yard.
That's pretty much all of the buildable segments of the 1945 GLX plan, since the Woburn Branch forking off Winchester Center is now obliterated. Winchester Ctr. wasn't grade separated until the mid-50's, either; the Lowell Line used to just split through the middle of the rotary with grade crossing hilarity. So stubbing out in the parking lot and calling it a day without considering Woburn at the moment is perfectly fine.
Basic, non-invasive, and single-most expensive piece of infrastructure is the non-optional grade separation of West Med that is going to have to be done anyway just for the Lowell Line. So while getting GLX through Somerville was an exercise in torture, further progress--so long as it follows in the footsteps of an RER-initiated grade separation--isn't a big deal. There's also some benefits for CR in eventually whacking all stations south of Winchester, in that under future electrification it's plausible that an EMU could hit 90 MPH on the 3.5 miles between Somerville Junction and Mystic Lakes without West Med being on a stop schedule. And then there might be another short stretch of >80 MPH possible to hit if they played some curve-straightening and/or superlevation games between the Lakes and Winch Ctr.
