I question the need for a stop at each terminal. If Massport builds the Logan people mover (monorail), than you would only need one light rail stop. Unless Logan and the MBTA can work togeather to combine the people mover and light rail to Chelsea and Cambridge.
The PM proposal isn't exactly fleshed out with any substantive details, so any other project attempting to leverage it through co-opting or transfer it's little more than dart-throwing at this point. What's certain is that any Urban Ring NE quadrant will go at least as far as Blue Line-Logan. Maybe it's hookable into the PM. Or maybe they don't do a PM in the traditional sense but rather a multi-use busway for SL1, Logan Express, and the trolleys. Could be literally anything.
We don't even know if it's technically feasible to lay another cross-Harbor tube that close to the Ted, so that's more a "Complete Unknown" Transit Pitch than even a Crazy Transit Pitch. It's 99.9% likely that ship sailed when they decided to make the Ted 2 roadway bores instead of 2 road + 1 transit = 3 bores nearly three decades ago.Also not "resonable" per say, but I think a tunnel to connect the Seaport portion of the green and the Chelsea portion of the green would be a good investment.
Keep in mind, BL-Kenmore only exists as a project as a transit trade-in settlement for tearing down Storrow Drive, in the same project area as the parkway teardown. The mechanics behind it getting advanced to design-build are wholly different/alien to anything else in the transit Universe of Projects. It doesn't advance on "build A before B" project priority logic like most others because the catalyst for kicking it off is so very different.I'd build that before I'd build the Blue Line out to Fenway. With a NSRL, there will likely be enough capacity for Blue Line riders to switch to Regional Rail to Back Bay/Yawkey or the Green Line. With that the Blue line would be redundant.
It would be plenty magnificently utilized, however. The options for thru-routing Green Line service from the Urban Ring or the E-to-D connection increase exponentially once Blue vacuums up Kenmore crowd-swallowing duties. The kickstarter mechanisms for the build may be different, but the fundamentals and multimodal coattails are solid.
Upper Eastern Ave. is hurt by being in an oil tank farm and Logan Air Freight wasteland. The SL3/future-Green stop @ Eastern and the buses out of Chelsea hugging Broadway are where the riders are. Near the 1A/16/145 ramp-a-palooza the density is better (this was the only place there ever was a historic station in Revere), but ROW accessibility is in no-man's land surrounded by all those high-speed roads. All points north of 145 it's too close to Revere Beach or Wonderland to attempt anything.Also with electrification speeding up stops on the Regional Rail, I think an infill Revere station would work. Not a wonderland stop, but maybe something near the Revere Chelsea border.
Unfortunately it's either ridership famine or accessibility famine on any of the candidate sites.
No, but the bridges suck monkeyballs year-round and have their own A.M./P.M. rush hours. Some people do indeed commute all the way to Boston from Falmouth, Sandwich, etc. RER-level service I agree has no business extending past Buzzards Bay on the mainland, but there is most definitely demand for a few commuter extras with last-mile connections into what's generally a pretty robust CCRTA bus network. So...maybe a few peak-period Hyannis trains running skip-stop, at most 90-120 min. headways off-peak in the offseason, and slightly more step-up in-season on the off-peak but still no more than 75 mins. or so.I also question the use of a year round regional rail service to Cape Cod. It isn't a terribly dense area, like Fall River or New Bedford.
RIDOT is serving up Cranston as a planned infill. Olneyville was proposed but deferred because of uncertainty over 6-10 Connector rebuild options serving up the station space. I guess we'll know when the highway project is shovels-in-ground whether that one can go back on the radar.I also think a couple of more infill stations in Providence between PVD station and TF Green would be nice. I think most riders south of PVD use the rail to get to Providence not Boston, therefore more infill urban Providence station would increase ridership a good bit.
Nashua is what the MBTA needs, because it needs a layover yard for the Lowell Line in the worst possible way. And the station catchments UMass-Lowell to South Nashua are very much an in-district constituency. What NHDOT plans to do north of Nashua is their business. However, if they did manage to hold to going all the way to Concord, service was envisioned to be split from Lowell/Nashua locals and run as a wholly additional semi-express service layer...i.e. the Concord trains would run local in NH but stop only at Lowell and Anderson in MA, while Lowell/Nashua would keep running simultaneously as an all-local service. The split saves time to Boston from deeper in NH and saves seats for NH commuters who'd get crowded out on the locals.Also I think moving the Purple all the way up the Lowell line to Manchester would be nice, although I think that NH is too fiscally conservative for that to happen.
So for RER purposes the Nashua turns would fit the mold at :30 min. bi-directional headways, while the Concord runs would probably be a traditional peak/off-peak split with significantly wider headways (whatever that adds up to). And the Concord runs would probably always be turning at North Station surface, never going in NSRL...since its only job upon crossing state line is delivering NH commuters to Boston's doorstep in timely fashion, and it would be a brutally difficult schedule to attempt to pair-match. There'll no doubt be a select number of run-thru Concord NE Regionals on Amtrak for the folks who need to get all the way down the coast.
