- Dec 10, 2011
And where there's ADA laws, there are fewer ways.Where there is a will there is a way
Note, for instance, that before it was permitted to extend Amtrak service to Roanoke [2017], the State of Virginia was forced to build full-highs platform.
Amtrak platform issue pits project team against federal regulators (article from 2015, when the service had been committed but the station was in question)
Most Amtrak stations in Virginia — including the last new one, Norfolk [2011], and the closest, in Lynchburg[2009] — have low boarding platforms. But they were built before the implementation of a federal rule designed to increase train accessibility. The rule says Amtrak stations built or substantially renovated after February 2012 must offer level boarding unless the track passing through the station carries “existing freight operations.” Roanoke would be the first new station in Virginia covered by the regulation.
Not directly applicable, except to illustrate the Federal RR Admin's ADA mindset: they want new things done "all in"
Virginia wanted to use Amfleet's traps on the excursion platform it had, but the FRA insisted on a full-build of a level-boarding platform capable of berthing the longest of trains.
If PennDOT went to the FRA with a ramp-kludge to accommodate the Acela 1s for 2022 to 2024 (or whatever), I suspect they'd get an answer:"just speed up your level boarding project" --which rather than facilitate the Acela 1s as a stop-gap would just end up being a case for buying more Acela 2s
