Brattle Loop
- Apr 28, 2020
I'll freely concede that future developments could well end the need for freight service to Everett/Chelsea. (Though, out of curiosity, is the produce market being redeveloped?)Within 20 years, there will be nothing to deliver freight to in Everett /Chelsea. Development is already started and won't end until 40-50k people live and work there
And for the one train that goes there, a gauntlet track with a middle of the night run would do the job
Time separation is a non-starter unless the trackage rights granted to B&M and subsequently inherited by CSX allow the T to restrict freight operations to a specific time (and my understanding was that that is not the case). Attempting to unilaterally force that is illegal, and CSX is not likely to limit themselves (at least, not cheaply).
What's the ceiling on throughput for a RR-mode (even with tunnel) Eastern Route? I have a hard time seeing how it's going to be similar, capacity-wise, to HRT. Every so often, people have suggested BLX would be rendered unnecessary without explaining how an un-screwed-up North Shore bus system can properly feed into the transit pipeline, because base-ER-Regional Rail isn't sufficient in terms of frequencies to match HRT's capacity. Are you saying that the tunnel-ER will be able to do that? (Because, if not, and if it's not close, BLX absolutely is still necessary.)BLX is not needed with a cross harbor runnel. There is absolutely no reason for North Shore residents to go anywhere on BL except Logan and the CBD. The job density is non-existent and population density is mostly to the West of the ER.
