San Francisco high-rise sinking, tilting
Poolio
But not completely unprecedented:
The Harmon in Las Vegas is another interesting story. "Completed" in 2009 but never occupied. It was originally intended to be 49 stories but cut back to 28 when construction defects were found. It was deemed unsafe anyway though, and they ended up demolishing it just a few years later.
theSil
Excellent video trending on YouTube explaining the construction of Millenium Tower and how they're trying (and failing) to right it now. Probably nothing eye-opening if you've been following closely or are in the construction trades, but extremely interesting as a layperson.
One thing I still don't understand is that at 5:32 the video states that the building has settled 17 inches, more than 3 times than what was expected over the building's lifespan, and is out-of-plumb by over a foot. Yet, the narrator says that one probably wouldn't notice this with their naked eye. How can a building settle about a foot more than expected, unevenly, and it not be noticeable to someone on the sidewalk? Is there not a step-down created? I must be misunderstanding something.
393b40
Geometry. Think about a right angle, now think if you make it an acute or obtuse angle... the top of the line will be much much further out than the bottom depending on the height of the line.
theSil
You're describing the building being out-of-plumb by a foot. I understand how that would be imperceptible from the sidewalk because for a 600-foot tower like this one, that means it's now making an 89.9-degree angle with the ground.
What I don't understand is how a building settling 17 inches into the ground , about a foot more than expected, is imperceptible. Wouldn't there be 12-inch step down when entering the building now? Do engineers design buildings of this size with the expected amount of settlement "built-in", such that it will be level with its surroundings once finished?
bigpicture7
Presumably because the surrounding ground was impacted by the sinking as well. You'd have to look at the true horizontal level of the sidewalks/roads before and after. I would bet that their localized slope is different now.
nomc
How would that not cause visible cracking, at least in some locations?
I bet theyre going to have to de-construct the tower. It feels inevitable at this point. After the few examples so far in nyc and other cities its not as crazy as it once was. Theyre now saying that the sewer/water lines are going to fail and the added piles are actually making it worse so theyre adding much less. Theres really no other option but to declare it a total loss and take it down. Of course theyre going to keep bandaging it up in the mean time, but its coming.
Johnnyrocket891
Wonder who takes the hit on this?
stellarfun
Tilt at the NW corner is now 29 inches. If it reaches 40 inches, then the safety of the building's systems is compromised.
The $100 million retrofit project – partially paid for by taxpayers as part of a resolution of litigation – was supposed to keep the building from sinking and tilting more and stabilize property values. But since work began on installing support piles in May of last year, the problems have gotten worse, not better. To stem the damage, engineers opted to cut the number of new foundation support piles from 52 to 18.
While the city has yet to sign off on that scaled back plan, new problems emerged when engineers began the digging needed to construct underground shoring walls to allow the foundation to be extended. Monitoring data showed the tower had listed another 2.75 inches west, toward Fremont Street, in just the first half of the year – and the building’s tilting hastened in May when digging began for the underground wall on Fremont Street.
https://www.nbcbayarea.com/investigation/millennium-tower-tiling-fix/2945803/
KentXie
At what point will they deconstruct the tower a la The Harmon I'm Las Vegas
I already called it before but Im going to call it again theres a 100% chance this ends up being deconstructed. The refits so far are already massively expensive and actually making the problem worse. So now the plan is to only go half way.. So its tilting without the refit and tilting with the refit. Its toast.
