winstonoboogie
- Dec 8, 2012
Yes. There's no way it can handle 90/hr. at current speeds. The shitty pavement and D St. traffic light bottleneck are parts of it. But the tunnel itself has permanent speed restrictions that most definitely were not in the original design, and which aren't going to be lifted. The articulateds didn't end up being nimble enough to take tunnel curves at top speed like they'd hoped. There's no signal system, and their initial assumptions about BRT dispatching being as exacting as LRT dispatching didn't pan out so it's unlikely that adding Green Line-like signals would do a whole lot to meaningfully improve performance in such a short tunnel.
There's a lot that could improve here, but it's incremental gains. Much of it rolling back the gradual decay in speed that's afflicted the Transitway over the course of its first decade. It is never going to reach full design potential under BRT. There were too many things they didn't adequately take into account about trying to make a busway act as a real subway.
That said, 40-50/hr. with additional routes utilizing it is certainly realistic and wouldn't cost the kind of money that requires fundamentally changing it. More vehicles, fix the @#$% pavement, fix the @#$% D St. light. That's all that's really necessary to give it a pretty healthy headway boost.
Here is a link to the original South Boston Piers Transitway Environmental Impact report from 1993:
http://archive.org/details/southbostonpiers00usde
Within it, it states that the as designed top speeds for the tunnel are 10 MPH on segments with curves, and 30 MPH in the straight section under the channel. It was designed from the start to have low speeds with no signals, and given the short distance between stops and the station dwell times no matter the speed, higher speeds with signals would not make much difference in travel time. The slow speeds on curves were planned from the start and aren't because "the articulated buses didn't end up being nimble enough"
In order to achieve 89 buses per hour (I rounded up to 90 before), three buses at a time would have to simultaneously load and unload at each of the underground platforms. The platforms are designed for this, and Silver line Way is set up so three buses at once can switch from diesel to electric power. They have never come close though to ever attempting to operate that level of service, however the original assumptions assumed the present speeds in their calculations.
Here is an archive.org archived pdf of the 2005 Silver Line schedule which shows a running time in the peak of 4 minutes from South Station to World Trade Center in the tunnel:
http://web.archive.org/web/20050530....com/traveling_t/pdf/bus/routesilverwater.pdf
Here is the present 2013 schedule which still shows a 4 minute running time from South Station To World Trade Center:
http://www.mbta.com/schedules_and_m...ction=O&timing=W&RedisplayTime=Redisplay+Time
Where is the evidence that there "has been a gradual decay in speed" during the first decade of operations?
