TallIsGood
- May 30, 2006
Adam Vaccaro said:One year after the state extended the Silver Line to Chelsea, officials are now planning additional new service into Cambridge, Charlestown and beyond.
A coalition of state, municipal, and regional agencies this week said they were planning to extend the route of the Silver Line from Chelsea to Sullivan Square and beyond, along two courses: one would go to North Station in Boston; the second would course through Somerville, ending at Kendall Square.
While the new service might not be in a Silver Line bus, the routes would likely run within their own roads for much of the trip, similar to the dedicated busway in Chelsea, before moving onto bus-only lanes on local streets to complete the trip. And both would have stops at the new Encore Boston Harbor casino in Everett, scheduled to open this spring.
Finally! Crucial part of the urban ring.
Would like it to be heavy or light rail if possible, though.
Would be pretty straight forward to convert the Chelsea busway to LRT and hookup to the Green Line system west of the Boston Engine Terminal and send to the Grand Junction. It's been discussed in many threads in the "Design a Better Boston" forum.
Biggest issue is the Logan tunnels. Though some sort of dual mode bus/rail route might work.
Last I heard it was only a weekend long pilot to test it out, that results indicated that while helpful to journey times it needed minor work to fix visibility and acceleration concerns. It also got a short term allowance during the Sumner tunnel closure.Sorry for bumping...
Was thinking about the Silver line extension options.
What ever happened to the Silver Line Way pilot findings? I never found the final decision, but can see that it was taken back out of use on googlemaps... https://www.boston.com/news/local-news/2019/05/21/silver-line-ramp/
All I can see is:
View attachment 44481 View attachment 44483
I'd say in general it's just because the rest of the MBTA has gotten so much worse, that optimizing the Silver Line (including the D Street light) just kind of falls by the wayside at this point. Totally agree, though, that the Silver Line still has low hanging fruit like using Silver Line way, and it should still be front and center as easy wins that have real meaningful impact on service.But that is a point - why aren't we talking about this anymore? It's not as if it isn't still a very good idea.
It appears that the T themselves have effectively given up on the idea, as the Bus Network Redesign calls for both SL1 and SL3 to skip Silver Line Way station and use D St to and from the Transitway portal:Sorry for bumping...
All I can see is:
Well the buses are actually hybrid with extended-range battery for the transitway and SL3 in Chelsea plus the 5 battery electric buses we previously had before the DMAs got replaced.It appears that the T themselves have effectively given up on the idea, as the Bus Network Redesign calls for both SL1 and SL3 to skip Silver Line Way station and use D St to and from the Transitway portal:
This makes sense, because even if you can use the ramp outbound to shorten travel times, there's no equivalent inbound and you're stuck with the WTC-SLW-WTC loop-de-loop. Removing Silver Line Way station at least makes the loop shorter, and now that Silver Line is using a full fleet of battery electric buses, there's no need to change mode at SLW anymore.
It still sucks that elimination of SLW station reduces service to one of the only three Transitway stations (and a decent one at that, with 30% of total weekday ridership among the three stations), but it's also true that stopping at SLW holds SL1 and SL3 back.
