Why didn't Louisville build a few garages instead of tearing down all those buildings for surface lots?
Land was obviously cheap enough that garage parking would not be competitive.
because louisville is in the south and as we all know southerners hate density and are allergic to multi-level parking structures.Why didn't Louisville build a few garages instead of tearing down all those buildings for surface lots?
The amount of lost time and pollution caused by traffic congestion and nimbyism does no one any favors.
But you advocate expanding a system that perpetuates lost time and pollution cause by traffic congestion.
Southern Cal built freeways to try to accommodate growth. It didn't prevent congestion. It convinced everyone they needed a car to live there. But our differences are probably ideological. You don't think that's a bad thing. I do.
No, you are not alone. There is a small but growing number of people on the board who want to see a return to 50's era highway building.
- The Middle Circumferential Loop running from Norwell to Boxford, crossing the Pike in Natick
- 290 Extension to 128, with a connection to the Middle Circumferential Loop in Sudbury
- I-84 extension to Manchester NH
- Pike bypassing Worcester and Route 2 not being divided to I-91
fixed it.The Middle Circumferential Loop running from Norwell to Boxford, crossing the Pike in Natick
290 Extension to 128, with a connection to the Middle Circumferential Loop in Sudbury (probably could have connected to the Inner Belt as well)
I-84 extension to Portland, Maine via Manchester
The closest distance between two points is a straight line (natural barriers aside). If you look at the major populations centers in Mass - Greater Boston, Lowell, Worcester, Brockton, Fall River/NB, there are not direct connections between any of them. You snake around and indirectly connect in some instances. The SW Xway and Inner Belt would have for the most part achieved that. I believe in efficiency, not waste, which is what I think most of our roads here are, wasteful in design. But need not worry, there will never be any new highways built here.
I don't agree with the comments implying that neighborhood squares or transit are a thing of the past, but I don't think they're sufficient in and of themselves for the future either. I think they'll thrive either way. It's not a zero-sum game. If that list of projects were done, we'd all experience the benefit of a more prosperous region.
No, but I do think it can be improved to be more efficient. I do not believe in totally ignoring the problem and I am not advocating the Southern California solution either. The closest distance between two points is a straight line (natural barriers aside). If you look at the major populations centers in Mass - Greater Boston, Lowell, Worcester, Brockton, Fall River/NB, there are not direct connections between any of them. You snake around and indirectly connect in some instances. The SW Xway and Inner Belt would have for the most part achieved that. I believe in efficiency, not waste, which is what I think most of our roads here are, wasteful in design. But need not worry, there will never be any new highways built here.
