DominusNovus
- Jun 20, 2010
I haven't seen anything on this in particular, but I was browsing through Springfield's Wikipedia history page and found this proposal:
http://www3.springfield-ma.gov/plan...ringfield_TAP_Presentation_FINAL_diagrams.pdf
and this:
http://scholarworks.umass.edu/cgi/v...#search="miracle mile springfield mill river"
Basically, the gist is that running I-91 through the heart of Springfield and cutting it off from the river was 'a bad idea.' Apparently, the original plan was to route I-91 up through present day route 5, on the other side of the river, but the city figured that they wanted a highway between their city and the (then polluted) Connecticut River.
Now, looking at a map, 5 has the advantage of being mostly a controlled access highway in the applicable area (from where it joins I-91 on the South End Bridge, up to where they intersect near the Holyoke/W. Springfield line). The only problem is that, for the last mile or so, route 5 is most certainly not controlled access, and has a very sizable shopping complex that has grown up around it.
I came up with a quick plan to mitigate that problem that involves re-directing I-91 back onto route 5. Basically, I consider the shopping area on route 5 two separate sections; southern and northern.
https://maps.google.com/maps/ms?msi...&ll=42.139605,-72.626882&spn=0.01537,0.035191
The southern section has to make do with being cut in half. Many of the businesses are situated between Elm St. and Riverdale St. (Route 5), so it is a 'simple' reorientation of the district to face Elm instead of Riverdale. Several of the car dealerships are cut off completely though.
The northern section is where things get a bit more interesting. Right around where Elm St. merges with Riverdale, there's a ridge that separates the higher ground that the residential area is on and the lower ground where the commercial area is. Basically, I propose running I-91 along this ridge as best as possible, thus avoiding cutting the shopping centers to pieces. Several office parks (the kind of one story, unorganized, flotsam and jetsom that always seem to spring up behind dense suburban shopping areas) will probably feel the brunt of the bulldozer, as will several row apartments.
After that, I just re-labeled the bridge over the river to be I-391, and have it run up through Chicopee as it does presently. Everything south of the Chicopee Curve (that interchange where my re-lable stops) can be repurposed. Admittedly, I-391 does to Chicopee what I-91 does to Springfield, but thats a trickier battle.
I really quickly looked at the map and put a suggestion for a re-orientation of I-391 that might work. I'm sure that green space there in Chicopee is there for a reason, though. However, it would mitigate one of the key problems in the area: the 'Chicopee Curve' is somewhat notorious for accidents, being a bit too sharp a corner for interstate speeds.
I then included two basic alternatives for bringing I-91 back into Springfield. At the moment, I'm liking my 'alt 2' proposal as it allows Springfield to maintain some direct access to 91, cuts off very little of the river, hooks right up to the I-291 interchange, and leaves route 5 while its still controlled access, rather than demolishing a fairly busy commercial district in West Springfield.
and this:
