Portlander
- Apr 14, 2010
Just prior to the construction (1976) of the Temple Street garage which shows the new street alignment you mentioned Mark.
What an awesome picture!!! ~ CPic from the sky coming in....View attachment 35541
I will say, that's probably the cleanest photo I've seen of Spring Street ending at Center. For all we talk about the changes to Monument Square, etc., that had to be the most significant upgrade: shifting Temple and pushing Spring through to create the "streets with four names" intersection where formerly only two came together.Photo from around 1972 showing the Holiday Inn under construction and the Canal Plaza parcel cleared. Spring Street Arterial has made it down to Center Street and the buildings have not yet been razed for the Temple Street garage. Who would have guessed that Maine's tallest building would eventually be built near the center of the photo 50 years later!
Also in the 1972 photo, Sears has vacated their building on Oak and Free for the climate controlled Maine Mall with Maine Blue Cross and Blue Shield renovating it for office use. The Spring Street Garage was just getting ready to open with final work still being done on the upper level. Interesting to see the dilapidated cluster of buildings that were demolished to make way for the Cumberland County Civic Center in 1976 and I'm drawing a blank on the name of the factory. Imagine the path of destruction through the Old Port if Spring/Middle continued all the way to the Franklin Arterial as originally planned.I will say, that's probably the cleanest photo I've seen of Spring Street ending at Center. For all we talk about the changes to Monument Square, etc., that had to be the most significant upgrade: shifting Temple and pushing Spring through to create the "streets with four names" intersection where formerly only two came together.
Does this imply that Congress Street was intended to be pedestrianized from Temple St. to Congress Square?? and if I'm reading the legend correctly...the blocks between Commercial and Spring / Middle *(the heart of the Old Port) were intended to be zoned INDUSTRIAL WAREHOUSE?!?!View attachment 35559
Greater Portland Landmarks
No, Congress is listed as a "Minor 2-Way Street"; i;e;, not a major traffic circulator (the proposal was for a Cumberland Avenue Arterial to mirror Spring St.) And "Industrial/Warehouse" was the historic usage pattern for much of the Old Port; I remember when the building that is now the Regency Hotel was an active C.H. Robinson paper warehouse. Hell, when I got my license it was still the norm for semis to back into loading docks on Commercial St., sticking out perpendicular into the roadway so that you had to watch out for trucks AND trains! Most of those older brick buildings on the landside of Commercial were active warehouses.Does this imply that Congress Street was intended to be pedestrianized from Temple St. to Congress Square?? and if I'm reading the legend correctly...the blocks between Commercial and Spring / Middle *(the heart of the Old Port) were intended to be zoned INDUSTRIAL WAREHOUSE?!?!
Great point. I'm wondering if the intention behind that zoning was to preserve the legacy uses within the Old Port or incentivize new / "modern" facilities in an attempt to revitalize the Port (which was experiencing a sharp decline in the 60s and 70s)No, Congress is listed as a "Minor 2-Way Street"; i;e;, not a major traffic circulator (the proposal was for a Cumberland Avenue Arterial to mirror Spring St.) And "Industrial/Warehouse" was the historic usage pattern for much of the Old Port; I remember when the building that is now the Regency Hotel was an active C.H. Robinson paper warehouse. Hell, when I got my license it was still the norm for semis to back into loading docks on Commercial St., sticking out perpendicular into the roadway so that you had to watch out for trucks AND trains! Most of those older brick buildings on the landside of Commercial were active warehouses.
I'm most amused by the idea of parking garages on Park St.
