Is there anything stopping us from, alongside or in place of the BU Bridge crossing, starting a branch or two of the Green Line out of North Station? I agree with Henry that there's a lot more value in building short spurs that could later be connected to each other.
Something like a phase one GLX to Chelsea, phase one Urban Ring over the bridge, then extend Union Square Green Line to Porter, connect Porter to the BU Bridge Spur and reroute those trains over to Chelsea. BLX to Lynn, Urban Ring to Lynn, and presto - you're done.
Absent or independent of that, the Orange Line doesn't need to be spurred. If we're going to do anything with the Orange Line, we should grab another five trainsets and double our headways on that line.
The Urban Ring doesn't have a clear integrity of concept. The city needs better radial distribution...great. The city's ideal radial distribution patterns and demand overlap on a map in a distinct ring area around downtown roughly conforming to the UR route...great. But since when did a one-seat radial ride become a necessity? How many people would actually ride this thing nearly end-to-end? That's where this falls part...where it gets force-fitted into the T's everything-must-be-a-one-seat-ride philosophy. People are going to ride this thing in segments, but there won't be much overlap of folks riding the SE quadrant in Southie and the NW quadrant between MIT and Lechmere. A 1-transfer ride on the subway will beat the one-seat roundabount every time. The T is severely overestimating the value of the one-seat and not taking into account that a line that doesn't reach any of the big half-dozen central transfer stations serves a fundamentally different purpose than the 4-1/2 lines that do. That error in logic is driving all the design decisions here.
Same as with the Silver Line. Why do people need rapid transit to Dudley so badly? Because it's the system's largest bus hub. The largest % of users are going to be using it as a radial line, even though it is not ring-shaped and Washington St. does have characteristics of a rapid transit surface branch in its own right. Hardly anyone needs a one-seat direct to Southie on it, but that feature became the unifying concept of the whole SL Phase III boondoggle and all of the project's design features were force-fitted around that.
Keep it simple. If it covers a radial transfer need, then it essentially is fulfilling the goals of the UR. Spurs fulfill those goals.
-- Green to Porter from Union. Red to Green/Orange and commuter rail, links 3 bus routes at Porter (incl. the 77) to 5 more at Union and 3 more at Lechmere.
-- Green to Sullivan stub. 12 bus routes + Orange at Sullivan to 4 bus routes + 2 other GL branches at Lechmere. The Green Line historically used to have 2 branches to Sullivan via Charlestown (albeit on different routings) serving different needs than the Orange Line, so there's not a redundancy here. The tracks to the GLX maintenance yard will also get halfway to Sullivan to begin with, so it's easy to continue. And this is your jumping-off point for Chelsea and Logan.
-- Green on Grand Junction from Lechmere. Pretty obvious why this is needed. MIT/CT2 corridor.
-- Green on Grand Junction via Kenmore. If B is buried underneath the reservation out to BU Bridge to form a connection. CT2 + 47. Reconfigure Kenmore so the B/D sides can loop there and it costs about $1B+ less than the cross-Brookline fantasy tunnel while linking the 66/65/60 at Brookline Village. Add E-to-D connecting track to BV and it links JP. Fistfuls and fistfuls of transfers.
-- Green to Dudley. Of course.
-- Green to South Station via some sanely-dug tunnel (probably under NEC from South End instead of through Chinatown).
And so on. Prioritize as you see fit, but it doesn't need to be a monolith to fulfill its radial transfer integrity-of-concept. And it damn sure doesn't have to be a totally different mode to fulfill its integrity-of-monolith inside a wholly invented one-seat integrity-of-concept.
