FormFollowsBudget
- Jan 15, 2015
$125M+ isn't no minor cost for 3 floors, really makes me wonder what they've got planned...
I wonder if any of that $125 M will go towards cleaning the exterior -- even just the little hat. a power-wash would do wonders.Fixing the Pru or at least its Topfrom today's BBJ
Time to have someplace to discuss this
$125 M is a fair size building -- this one just happens to be 50 floors up
The Pru looks grimy and can use a face-lift. I don't think the exterior has changed one iota since it opened in 64. I agree, I would hope the $125M will be used to improve the exterior, not just for the upper few floors.
If you look at the top of the Pru
The current floor of the Observatory and the space under the "Top of the Hub" [aka the Top Hat]-- make that into the Penthouse of all Penthouses -- there is room for a small balcony going all around on the floor just below the Top Hat -- this 2 story Penthouse could easily command $50M as the highest [likely for a long time] largest [at a high perch] residence with best views in Boston
Maybe -- Bob Kraft buys it for Tom and Gisselle as a birthday present -- Tom stays -- Tom returns to being Tom for one more Lombardy Trophy and one more ring
The Top of the Hub then becomes an Uber 2 story observation deck with the story of Boston's landmaking in AR/VR -- you could walk out [virtually] and stroll Boston Neck at high tide when the Brits were camped just inside Boston's City Walls [there really were city walls during the Revolution when Washington laid Siege to Boston]
The Prudential Center’s former Top of the Hub site on the 52nd floor will become an observatory that Boston Properties hopes will attract 1,000,000 visitors annually.
Boston Properties, which owns the property, plans to transform the former restaurant into a second observation deck and create a separate entrance for the attraction. The Top of the Hub restaurant closed before the start of the pandemic when Boston Properties decided to not renew its lease.
Most likely an event space. The original observatory could be used for special events, but it was awkward. The restaurant space would make a very impressive event space. And with the advantage of having part of the space open to general visitors, with part closed off for a private event.Interesting why an observation deck needs to be 3 floors, are they turning it into a museum?
Chicago's Aon (nee Amoco?) because they already had to strip the exterior and redo it ingranite when the Carrara marble started cracking and falling off? When 2/3 of the original facing was crushed and used to decorate an oil refinery, I don't know how you landmark it. And as much as I love Edward Durrel Stone, this was bascially the stretch limo of his designs.Should be illegal, idk how aon isnt landmarked.
Is it me or does $125 million seem like A LOT of money for this? I understand from the article above, it is not just "a simple renovation" but over a tenth of a billion for this????!!
That really does strike true; the UMass Du Bois Library is basically a scale model of Aon, complete with failing facade issues, and he proposed a midscale version for Volpe.Chicago's Aon (nee Amoco?) because they already had to strip the exterior and redo it ingranite when the Carrara marble started cracking and falling off? When 2/3 of the original facing was crushed and used to decorate an oil refinery, I don't know how you landmark it. And as much as I love Edward Durrel Stone, this was bascially the stretch limo of his designs.
