P
Patrick
Guest
I think you should look into the planning board, it looks like a good place to make your voice heard on these sorts of issues.
As far as the new Veterans bridge, they can make it look easy on the eyes using several techniques but it really can't get much higher (no towers or anything). Here's the apprach to PWM:
source
And as far as Bayside, I agree that the windows over most of the Intermed building are way to small. Larger windows would cut down on heating costs in the winter and also look much better from the outside and also from the inside. You should get out of your car and stroll around bayside, it's even worse on a pedestrian level. Plenty of room for improvement would be a positive way to describe the area.
The idea isn't so much to make it tall but to make it an effective gateway to our city, one which inspires and alludes to what the city downtown is like. Most of the people involved in its planning want it to be a gateway to both land and air travelers, meaning they are well aware of the approach you showed, and want to use it to the bridges advantage. Tall or not, this is an opportunity for our community to present Portland with its best foot forward. Think of the Zakim, the Golden Gate, the Brooklyn Bridge, even Casco bay...then compare them to vet. The thing needs to be rebuilt and this is the time to make sure its done right.
edit: But your comment is a good point
