WormtownNative
- Dec 7, 2014
By that logic why two stops in Boston?
And why not stop in Providence?
Don't link them. It isn't the same "we" --either in who builds it (Amtrak HSR vs MassDOT NSRL) nor the same target passenger (intercity vs "suburban" trips).I want high-speed rail, but we should connect North and South Station first.
This is trackwork to go with the new 165mph constant-tension cateneary in New Jersey, yes? (based on the tall overhead transmission lines), so the sculpture, Spirit of Freedom is in Hamilton NJ.What and where is that statue?!
This is all in New Jersey, yes? (based on the tall overhead transmission lines)
No train should ever skip Providence, for the reasons mentioned by Bigeman312. (By the way: yes, it's possible to revive Providence Union Station and the East Side Rail Tunnel, but it would require severing the connection to the existing line to the north, toward Pawtucket and Woonsocket. The curve radius would produce squeal, and the above-ground flying junction doesn't belong in the middle of a city center.)
Back Bay is actually reasonable to skip, via the Fairmount Line, which also doesn't have the sharp turn into South Station. Target speed for Fairmount should be 160 km/h, and this is about on a par with a Southwest Corridor with speed zones of 70 km/h from South Station to that sharp turn, 100 km/h through Back Bay without a stop, and 200 km/h farther south. 70 km/h into South Station would require the trains to mentally think of the station as starting one car-length farther south, and of the remainder as buffer. 100 through Back Bay depends on whether I measured the curve radius correctly on Google Earth, which isn't the easiest since it's underground there. If one of these is not possible, just go via Fairmount.
Fairmount will have the capacity for HS rail when it's running 18 minute headway DMUs?
Nexis's post suggests their from the vicinity of Levittown, PA.
