In addition to station consolidation signal priority on the B, what about some strategic grade separation via overpasses? You wouldn't need to El the whole thing or even all the way out to Packard's Corner. I could envision a single overpass over the BU Bridge intersection being very worthwhile, and maybe another one to get through Packard's Corner itself. You wouldn't need to elevate stations in either of these cases, so it keeps the cost way lower than an El.
I recognize that you need a specific graded incline on either end of the overpass but I think there should be room for this even if it means eliminating a surface stop or through cross-traffic at an intersection here or there...
The whole bridge intersection is insane. Are you suggesting a simplification which allows left turns from the bridge into Comm Ave?
Good point Matthew. And you make another good point about pedestrian crossings. This really irks me about the B. Why can the C be 100% open crossings but the B needs the fence for its whole stretch?
This would have to be more like a signalized New England style rotary rather than a true traffic circle, for many reasons including the B Line. At that point, what's the benefit other than a smaller footprint for the intersection?
Assuming we want to keep to the circle idea, the couldn't B Line problem can be fixed with a short El instead? It can go under too, but that's probably too deep considering the Turnpike.
signal priority seems like a way cheaper way to solve 90% of this problem.
It always comes back to signal priority, and forgive me for being ignorant, but what does that mean EXACTLY?
Would it be as simple as if the T is approaching an intersection, the T gets the right-of-way and gets the green while everyone else gets red? If so, why is this not already done? Is it really expensive, because it certainly doesn't seem like it should be.
