Funny, I actually avoid the Boston side of the river because, as bad as Memorial Drive "shared use path" is, it's better IMO. Also you can't get from BU Bridge to the Esplanade, without going around the long, long way, and that's what I usually need.
Regarding taking the lane, what cden4 said. Generally, the biggest danger comes from lack of visibility. Hugging the side hurts you in two ways: it gives you no chance when someone opens a door in your path because you can't see them and they might not look for/see you; it is more difficult for someone coming up behind you to see you and they also might not give you much passing space.
Fact is, as long as you have a rear-light or it's daylight outside, your chances of being outright rear-ended are minimal. The biggest dangers come from right-hooks, door openings, and dangerous passing. Taking the lane is a way to mitigate all three of those dangers at once. Hugging the side exacerbates all three of those dangers instead. I know that you don't want to be "that guy" holding up everyone, but, do yourself a favor, on city streets -- take the lane, save your own life.
Wait until you find a safe stretch and then you can pull over to let people go by, if you really feel it is needed.
