Sounds about right. Current station spacing is about 230 meters, which is about half of what it should be.
When they rebuild that section of Comm Ave in 2015, they need to drop two lanes (from 6 down to 4, matching the BU East stretch of Comm Ave) and then establish proper left-turn lanes at each intersection (instead of the mixed left/thru lane that currently exists). The remaining platforms should be split across the intersections with far-side platforms, this co-exists well with left-turn lanes, and fits well with signal-priority which should be implemented in the new traffic control system. Then the platforms can be widened considerably, provided with amenities, ADA-compliant slopes, and two means of egress each, as required by law.
Matthew -- If I was doing the planning related to Comm Ave. -- I would:
1) Bury the B Line tracks from the beginning of the incline out past Pleasant St.
2) Build one underground station for Eastern / Central BU
3) Build one underground station just west of BU Bridge
4) Build one underground station at Agganis Arena / student village
5) Build the last underground station at Packards Corner
6) build the incline up from there to the first surface stop @ Harvard Ave.
Let the students, faculty and staff walk -- it would be good for them and by drastically reducing the surface stops the line will be significantly speed-ed-up
Yes, if that had a chance in hell of happening, I would like to see something like that too.
But it's not, so, improved surface conditions it is.
And where will the MBTA get the billion dollars or so to put the B Line underground? Ah yes! The taxpayers.
The three-stops-on-East-campus is going to remain as long as you have to pay at the farebox. All three stops get 2500 to 2900 riders daily - that is, 30% of B Branch ridership gets on in the half-mile east of the BU Bridge. Try to push those 85-- riders onto two stops - one of which is Blandford Street which is basically unexpandable - and you have both massive overcrowding and huge dwell times, even worse than with 3 stops.
Until you have POP and can board all-doors - especially if Blandford can then go center-island to give whichever direction is peaking at the moment more space - it would be unwise to eliminate any of the 3 east campus stops.
Babcock, Pleasant, St. Paul, and BU West combine for 4600 riders, which can be split between two stops without wholly unworkable dwell times. One of Pleasant or St. Paul Street grade crossings is necessary for BU bus operations, but closing one of those and possibly Babcock Street would help a hell of a lot as well.
If they ever do a Grand Junction urban ring there will need to be a station at BU Bridge so it can tie into the system. That of course, would also require the burying of the B to at least the BU Bridge. So it's out of the near-term realm anyway.
