Equilibria
- May 6, 2007
Presumably because of exactly the issue you identify; MassDOT's plans are perpetually stalled. I'm guessing that they figured this was small enough that it could get done quickly and cheaply (though the "get done" part was probably the motivator) without having to wait the three thousand or so years for MassDOT to finally do something about the cloverleaf. (That consideration, however, concerns motivation behind pushing the proposal, not whether or not it's a good idea. Sometimes quick, cheap, and 'easy' make for bad projects. Odd how that tends to generate fewer complaints than slow and expensive projects that ultimately work well.)
The problem with their logic is that you still need MassDOT's approval and help to build an onramp to an Interstate. You can't just sneak it in there like Mayor Daley carving up a runway.
