Don't overcomplicate. Straightest shot and least ops-compromised routing is Blue. Even the original Riverbank plan didn't try to fuss it that much.
Of course, the original plan brings up another crazy idea: Riverbank as a branch(?) of the Red Line.
I'm basically kidding (if it ain't broke, don't fix it), though the idea has the benefit of being, well, crazy. (Although I must admit that I can't really think of any other benefits!)
There's also the possibility of running a Riverbank service as a shuttle, between Gov't Center or Park (or Haymarket or Charles or whatever) and Kenmore or Allston or Longwood. I don't think it's a particularly great idea, but maybe if it were built as an HRT line on a partially reclaimed Storrow, between Charles and Kenmore, it could then later be linked up with a Blue-Red Connector.
Again, I'm not sure why you would do a Riverbank shuttle first, before a B-R connector, but sometimes politics makes things happen like that. *shrug*
When did Leverett Circle enter this conversation? Riverbank-as-Green doesn't even get close to Leverett.
Beacon Hill is age-old terra firma and we have a pretty good idea of everything potentially lurking in the dirt down there. Back Bay fill isn't touched, the Boston Common trap isn't touched, neither of the graveyards constraining Park-Gov't Center are touched.
Total amount of tunneling required, end-to-end, 3765 feet - about 1900 of that is under a one-way, low priority back street and another 600 is directly underneath state-owned land.
I should note that even if you don't like that routing (in fairness, it would require nontrivial reconfigurations to Park Street to connect the new platforms that would need to be built there), that's far from the only routing possible.
I like this alignment, though I agree that it's problematic in how you would need to reconfigure Park. (And I worry about digging under the State House!) It frees the Blue Line up to either terminate at Charles (or at a transfer station on the Riverbank subway), or do other crazy stuff, like head south to Huntington Ave (not super crazy about that idea), the South End (could be worse) or over to Cambridge, which I like best, though then you run into the problem of how to cross the Charles. Assuming you can run Blue on Red tracks (is the voltage the same and all that?), you still have to deal with reconfiguring Charles to serve both lines (limited platform extensions that only extend when a Blue train arrives? gauntlet tracks?). But I digress.
I decided to have some fun and expand on the repercussions of this alignment. See here.
The big points:
-Green converted to HRT partially south of Park, completely to the north
-Green HRT uses outer tracks between Park and Boylston, and then runs south through the old Tremont Street Subway to a transfer station at Oak Street, where LR from Dudley and points south (and possibly Southie) transfer (there is the possibility of a sub-subway between Oak and Boylston, allowing direct LRT access to downtown, though I don't know the feasibility of this)
-Green HRT shares trackage with Orange from just south of Oak to Back Bay, before skipping over to a newly extended Huntington Ave subway to Riverway; where it goes after that, I didn't decide
-Green LRT continues to run in Boylston Street Subway from Kenmore to Park, using the middle tracks between Boylston and Park, and turning at Park
-Green LRT also runs in a subway to South Station before surfacing and serving the Greenway, North End and North Station
-Green HRT continues north of Lechmere, probably in two branches (Porter and Medford Hillside-ish); a few LRT lines terminate at Lechmere Transfer (most unmarked on this map)
-Green HRT in the Riverbank subway runs to Kenmore Transfer; after that, I didn't decide
-Blue is extended to Charles/MGH-West*, and possibly down to the Riverbank**
-Instead of reconfiguring Park, I added a whole new station at Beacon Hill***
-"Transfer" in a station name indicates a major terminus for LRT lines and therefore a transfer point
*MGH is huge, geographically speaking (among other things) and I predict it will only get larger. Therefore, I've renamed Charles/MGH to Charles/MGH-West, and have created a newly relocated and renovated station to replace Bowdoin, named Staniford/MGH-East, located to better serve the eastern end of MGH's campus.
**Someone here (CBS? davem?), I believe, once proposed that the Blue Line should terminate downtown as a matter of principle, arguing that it has a unique purpose of connecting opposite sides of the Harbor. While this argument has its appeals, I'm not sure I agree with it. Still, I'm experimenting with some of its ramifications right now, so I've curtailed the Blue Line around Beacon Hill.
**I'm not crazy about this: I toyed with having "Park Street North" for the Riverbank line be somewhere around Bowdoin Street and then have a long walkway to Park Street. But that's still a looong pedestrian tunnel, and Park Street North wouldn't really serve any new areas. The Beacon Hill stop at least would serve more new people. (Though I hate to slow down the Red Line yet more.)
Hell, it probably isn't even the best routing! This alternative, which would require provisioning Red-Blue for four tracks but is otherwise Blue-eats-D in reverse, (and cuts the required tunneling down to 700 feet instead of 3700) de-emphasizes the extreme amount of transfer pressure in the downtown core by providing a nearby transfer nexus between Red, Blue, and HRT Green at Charles/MGH. (This might even validate Bowdoin's continued existence as a Blue/Green transfer to mitigate bypassing Gov't!) As an added bonus, it's great prep work for if we ever decide, some great many years in the future, to pursue a system closer to New York's in the sense that we can run branches and alt routings from one line to another without too much issue.
I'm less crazy about this alignment, though I admire its creativity. Part of my problem is that, while MGH is a huge employer and destination to be sure, this would seem to route the Green Line away from most of downtown. And I'm not sure that's such a great idea.
Although I suppose in some ways, it's the same model with have now, just with some of the locations changed around.
What route were you planning the Blue Line to have in this arrangement?
