So the enormous change in elevation between Arlington Center and the Heights doesn't correspond to geology?
Did the T just get lucky with that little spit of bedrock between Porter and Davis? What was their original plan? Or did they always know about the ability to do a very deep bore tunnel in Cambridge/Somerville?
The hard seam in Porter was well-known ever since the area was settled since it would've made digging any halfway-deep foundations a real P.I.T.A. Probably has a lot to do with why there's no particularly tall buildings around Elm. That whole area Porter & Wilson used to be the slaughterhouse district full of disposable shacks and whatnot.
As for the extension...marriage of convenience. Staying cut-and-cover and making a hard left onto the Fitchburg ROW to Alewife was one of the study options...that would've avoided the seam. Staying cut-and-cover further up Mass Ave. and hanging a hard left onto the Cutoff ROW was a study option that would've avoided the seam. But it was when they got to thinking how to shotgun-marriage Porter and Davis together that the geology ended up matching perfectly for a deep bore that didn't kill them on cost.
Fluky luck. Forces of nature just happened to be spot-on perfect for connecting the squares.
Negotiation on the same old Minuteman ROW is still going to be the least-costly and most plausible way this ever gets built. Unfortunately re-angling the tunnel out of Alewife to spit directly onto 2 now requires blowing up the entirety of the Pfizer complex before it can set itself on a westbound alignment.Sure, but I see the Green Line thread as a real solutions thread. Crazy Transit is throwing ideas on the wall. Picking them apart is great because it keeps us thinking. I'm not suggesting we put together an advocacy group to get this beast built. Just tossing out ideas based on previous ideas getting torpedoed. Maybe every idea to get to 128 via Red will get torpedoed, but it's worth brainstorming.
Then it never hits Lexington until X decades later when they start getting jealous. That's why I'd treat this as 2 completely separate extensions. Heights being Red's equivalent of Blue-Lynn and Lexington being Red's equivalent of Blue-Salem. Pretend the second one doesn't even exist until service at the first is mature and there's some reality-based reference point to speak from. Lexington might still hate it, but they can say so without the complete (and largely useless) abstraction of trying to imagine what rapid transit even is. Alewife is 6-1/2 miles from Lexington Center. Arlington Heights is 3. One Lexingtonites will bus or bike to in large numbers; one is just too far away pushing through too much traffic. It's not real enough a concept to have a rational discussion. So don't until it becomes a real concept at Heights.I agree, but there's just no f-ing way Lexington would ever be enticed to allow above-ground, heavy rail up their gut just to improve connectivity between Boston and Hanscom/Burlington Mall. Lexington is a much different place in 2015 than it was in the 80s.
This would be the way to get it to Heights. But Lexington won't let the Great Meadows be touched. Plus it would have to go back underground around the Brown Homestead through the Center. North of the Center, the ROW is very closely abutted by fairly recent residential, McMansion construction. No way they're letting trains on <12 minute headways barrel through to Hanscom/Burlington a few dozen feet from their million dollar homes. Unless it stays underground from Woburn St until at least Revere St, and then probably again underground from Bedford St to 128....
The 1945 plan never even tried to go to 128. It drew the line at Heights. It was only when Hanscom was declining as a military installation and the state started getting TOD ideas that they really sold themselves on the idea of taking it all the way there. So...2 separate projects for 2 separate needs pretty much is how the planning broke down.
If simply plunking parking sinks at 128 is the goal then you can take care of the NW quadrant by doing the GLX Union Branch to Waltham + Fitchburg relocation to the Central Mass ROW, and GLX Medford Branch extension to Anderson...possibly with a swap-over to HRT. That one was on the '45 expansion plan, except for the Woburn Branch ROW no longer being available. Those fingers will set up all the fast-transferring 128 shuttle buses to the office parks, Hanscom, and Burlington that anyone would ever need since their demand is so heavily skewed to M-F 9-5. If it's going to take $2B to do this extension, maybe that's $1B saved and $1B better-allocated to a two-for-one build strung together at the termini by "Suburban Ring BRT". Reconceptualize the transit strategy out there if force-feeding this extension past Heights just gets too unrealistic.
