Excellent info, thanks! Follow up if you don’t mind, since I definitely phrased my question not exactly as I meant to (but I still got some good info): What other projects would have higher priority than improving the Boston-Springfield route (regardless of who runs it)? More or less, at what point would we reach “well, we’ve built out everything else?”
That's an unanswerable question, because we have to walk and chew gum at the same time to solve all the region's transit needs. Many projects need to advance simultaneously covering a wide spread of audiences.
The Inland Route is definitely the most important intercity project in New England. The reason for that is it's the main capital expense enabling an array of route combos anchored around Springfield Hub. The NNEIRI study details more of this, but you can piece a very robust array of route configurations together like tinker toys.
- "Standard" Inland Shuttle: New Haven-Springfield + Springfield-Boston. One-seat.
- "Standard" Vermonter/future-Montrealer: Washington-New Haven-Springfield + Springfield-St. Albans/Montreal. One-seat.
- "Standard" Springfield NE Regional: Washington-New Haven-Springfield.
- Boston-Montreal (new) route: Boston-Springfield piece of standard Inland + Springfield-Montreal piece of standard Montrealer. One-seat.
- standard Montrealer meets opposite-direction standard Inland: an Inland slot to/from Boston gets timed to meet the daily Montrealer round-trip, allowing gain of additional BOS-MTL slot via two-seat w/cross-ticketing. Schedule for this second two-seater slot would be ideally spaced near-opposite end of the day from the direct train to offer up beneficial schedule flex for riders.
- Boston-Montreal meets Springfield Regional: the daily BOS-MTL round-trip hits a timed transfer with either an Inland or a full-blown Regional offering Vermonter/Montrealer patrons a second daily round-trip via two-seat w/cross ticketing. Likewise, spaced near-opposite end of day from the regular direct train to max the schedule flex.
- New York-Portland: otherwise regular Inland slot originates in NY, diverts over Grand Junction Branch to North Station, reverses direction to follow standard Downeaster route. Tiny margins for NY-POR patronage are supported by the passengers riding it as a more-or-less standard Inland or more-or-less standard Downeaster.
The "tinker toys" routes are all very low-cost to operate because their margins are hidden inside of the much bigger mainline Inland patronage, but that's how we end up getting more Vermonter/Montrealer (de facto) slots and Boston-Montreal slots out of it. As well as things on NNEPRA's bucket list like that NY-POR train that wouldn't be able to exist without having its margins well-embedded inside other routes. Everything ends up greater than sum of its parts.
You can branch off from there once things get better-established, such as engaging the B&A westbound to the Berkshires and Albany or seeing if there's more to tap in VT or CT. Real Boston-Albany service would no-doubt see itself getting established by doing these matchups of somebody's one-seater vs. somebody's timed transfer in order to give its starter schedule at least a couple decent options each direction on opposite ends of the day. Ditto if MassDOT has aims of tying in the Berkshires. And, yes, the commuter rail coattails are major if Springfield becomes a large Amtrak transfer hub. That's a big stimulus for Hartford Line growth and could influence the makeup (independent ops vs. run-thru w/ Hartford Line) of the eventual Knowledge Corridor CR service.
