Delvin4519
- Oct 8, 2022
So, yes, I do agree with this in principle, and I think it's probably one of the best responses towards answering @kdmc's questions so far.
There are definitely cases where Regional Rail can be a solution to urban transit needs (say within 128), though. Most of these are cases where running frequent mainline rail as a "quasi-rapid transit corridor" (credits to you for the term) almost achieves what proper rapid transit does, but at a fraction of the cost:
The difference between them and Braintree is that for all of them, parallel rapid transit for the same purpose is unlikely to happen anytime soon (though I'd definitely welcome a BLX to Auburndale), but RL Braintree branch already exists today. In some sense, these are best compromises, while Braintree is not. This also extends to GLX, OL, etc.
- Fairmount Line, obviously and beaten to death
- Framingham/Worcester Line: Up to Auburndale/128, with infills at West Station, Newton Corner, and possibly others that people are currently discussing
- Fitchburg Line: Up to Waltham
- Waltham itself is already a major node, plus Waverly has good transit share as well
- Newburyport/Rockport Line: Up to Salem and Beverly
- I included it here not as a replacement for BLX, but for a few reasons. (1) The Grand Junction part of the route is unique, and even though a parallel rapid transit service can be implemented, they'll likely have different alignments and serve different needs. (2) Rapid transit to Salem is currently far-fetched, and to Beverly is virtually unheard of, yet they have extremely high demand as #2 and #3 highest-ridership commuter rail stations.
Somehow my Allston-Brighton I-90 corridor map got mentioned here. Anyhow, moving the thread here since it's more suited to this purpose.
For one thing, somewhat amusingly, the 64 already made the detour back in 1998, way before Boston Landing was even proposed: (Source: NETransit history page)
The "new supermarket" in the red box was apparently the predecessor of Boston Landing and its developments. Note that the green segment in 2020 did not affect service to Boston Landing, did not add to the detour, and was likely just for convenience.
For another, Boston Landing is more than just a station. Just look at satellite view:
On the other hand, I do agree with your and F-Line's subsequent comments that ideally the station sites could have been much better (even though Everett St, which Boston Landing borders, has a much better walkshed than Market St). But at the same time, it also seems that both West Station's and Boston Landing's sites were chosen primarily for TOD. Boston Landing indeed realized the TOD potential in a way that other sites might not have, and West Station's proposed location also seems much better for that purpose than Cambridge St. That these two stations ended up with worse connectivity with existing services may simply show that the factors into station placement are often in conflict, and there are always tradeoffs to be made.
The ROW within Newton Corner would have an issue of how many stops are needed to adequtely serve the entire corridor.
The Boston Landing and the proposed Beacon Yard stations have poor connectivity to existing bus routes, although they are located in areas that may be easier for TOD. Lansdowne is halfway between Kenmore and the D's Fenway station, but it's utility is limited without NSRL and low frequency/connections (see the GL operator's comments).
If stops are added along all potential nodes for demand within the corridor, without removing existing stations, it would result in a total of 10 stations in between Newton Corner and South Station, with some stops quite close to one another, especially around Allston. At this point, I'd be going full "god mode sandbox" and not "crazy transit pitch".
Origin Station | Destination Station | Walk time (minutes) | Comments | Connections at Origin Station |
Newton Corner | West Brighton/Charles River Loop | 29 min | 33 if the station is located on Parsons St. instead of Brooks St. | 57/553/554/556/558 - Newton Corner |
West Brighton/Charles River Loop | Brighton Depot | 23 min | 16 if using Parsons St. location. | 64 - Oak Sq |
Brighton Depot | Boston Landing | 14 min | Quite close stop spacing, especially for RUR, and quite tucked in if it were a god mode sandbox HRT line. | 64/86 - Brighton Depot |
Boston Landing | Allston Depot | 11 min | Stop spacing is too close. However, it Boston Landing were skipped, it would be a 25 minute walk to get to Brighton Depot from Allston Depot, meaning the Boston Landing TOD would have poor connectivity with a 13 minute walk to get to either station. | 64 Boston Landing - lengthy detour (not useful) |
Allston Depot | Beacon Yards/West Station | 13 min | Better connections with the 66 and 64 bus. | 66/64 - Allston Depot |
Beacon Yards/West Station | Cottage Farm/BU West/BU Bridge | 9 - 11 min | Excessively close stop spacing for RUR and probably HRT too. May be better if the station is shifted ever so slightly east to balance the distance to BU Bridge. The area around the BU Bridge is in the throat, so space is probably too tight for a station, bridge, railway junction, and highway. | no bus connections |
Cottage Farm/BU West/BU Bridge | Lansdowne | 20 min | Seems reasonable, most of BU is covered by one of the two's walksheds. | 47/57 - BU West, Grand Junction Railway to Cambridge (railway junction) |
Lansdowne | Hynes Convention Center/Mass Ave. (I-90-B&A station) | 17 min | I'm going full "god mode sandbox" here. For a "Green Line relief valve", I much prefer a routing to Back Bay station, as Storrow Drive, while Storrow's ROW could be repurposed, the walkshed of Storrow just sucks with half of it being water, plus Back Bay provides connections from west to south. | 60/65/8/19 - Lansdowne, 6 minute walk to Kenmore Station or GL D Branch (Fenway) |
Hynes Convention Center/Mass Ave. (I-90-B&A station) | Back Bay Station | 16 min | "Green Line relief valve" (ditto) | 1/GL B/C/D - Hynes Convention Center, |
Back Bay Station | South Cove (Washington St.) | 16 min | Mostly to provide service to Chinatown and South End, and a more direct connection to the Silver Line and points south from the west. Primarily rationale and my ideal "god mode sandbox's Green Line relief valve". | OL, Commuter Rail, Amtrak - Back Bay Station |
South Cove (Washington St.) | South Station | 19 min | Overlaps with SL4 | SL4/SL5/9 - South Cove & Herald St. & Washington St. |
If all of the stops are used as actual stops (with about 1.65 - 2 mins per stop), Such a trip from Newton Corner to South Station would take about 19 - 22 minutes. A trip from Newton Corner to Back Bay would take 16 - 17 minutes, a transfer to OL to continue downtown, would be 29 minutes (7 mi/11.3 km) from Newton Corner including transfer time at Back Bay. Such a travel time and trip length would be more suitable for LRT or HRT, and such stop spacing could allow for a reduction of bus routes in the area, as most of the utlity of the bus routes would be covered by such line, but RUR would not suffice.
So my thoughts are, how many stops are needed between Newton Corner and South Station, and what would be appropiate travel times to Back Bay, South Station, and DTX, from Newton Corner?
