Teban54
- Nov 13, 2021
Bumping this up because people in r/transit were discussing the Miami Metromover APM recently. While some people claimed the original intention was to help drivers into the city with their last-mile travels -- and I won't be surprised if many people still use it for that purpose -- this thoughtful comment from a Florida resident adds a whole lot of details:It's apparently my week for "Crazy Transit Pitches, Unusual Modes Edition."
The Miami Metromover is one of the few, if not the only, successful APMs deployed within a city core. Miami's heavy rail system, Metrorail, has two stations in downtown, but there are somewhat on the periphery. Metromover connects to Metrorail's Government Center station, and circulates through a few bidirectional loops through downtown, essentially solving the last mile problem, and extending the reach of public transit comfortably throughout all of downtown. Stations are located about 700-1000 feet apart in downtown, with branch lines that extend north and south over divisive highways and a river, with somewhat longer distances between stops.
A rapid transit system that serves the periphery of the employment hub, with distributed destinations that are a little far to walk to from the station? Sound familiar?
The Longwood Automated People Mover, or LAPM:
- Metromover's ridership is a "healthy split" between CBD commuters and downtown residents. This is because a lot of skyscrapers in downtown Miami are actually residential.
- A lot of developments -- residential or not -- around Metromover were actually done way after the system opened in 1986. The follow-up comment cited an example of high-rises built between 2014 and 2022. However, I suspect some of the buildings already existed in 1986.
- Yes, Metromover is very convenient. Transferring to it from the HRT Metrorail usually saves you a few minutes compared to walking (thanks to a seamless transfer), even if your destination is within the 10-min walkshed; not to mention walking in Florida heat.
- Each of the three routes runs in about 5-min frequencies, but combined, there are trains every 90 seconds or so. Two-car trains are used quite often.
- The use of rubber tires not only allows the system to fit into narrow streets, tight turns and steep grades, but also makes the system very quiet, reducing the noise impacts on buildings that are immediately adjacent to tracks.
So where does this leave us in terms of applying this to a hypothetical Longwood APM?
- (+) People do use the APM for destinations that are within a 10-min walk from rapid transit stations. This also supports my own analysis of Metromover's ridership (quoted below), which suggests that many APM stations that are reasonably close to HRT stations still experience good ridership.
- (+) Weather protection is indeed a factor in the success of the APM. This applies to Boston too, but in the reverse direction -- for us, it will be helpful during winter.
- (+) The mode choice of rubber-tire APM does have its advantages that may apply to LMA. Narrower tracks are easier to fit into LMA's narrow streets, reduced noise will be helpful for the seas of buildings, and steeper grades help overcome footbridges.
- (-) However, developments (transit-oriented or not) play a key role in Metromover's ridership. In contrast, the core LMA area is already very densely developed, and short of aggressive eminent domain, I don't see much space available around the APM.
- (+) But there's another way to look at it: A "Longwood" APM that extends outside of LMA core can possibly find room for TOD. In particular, if the APM extends east to Ruggles and even further along Melnea Cass, not only does it connect to BMC, but it passes by this stretch of Melnea Cass whose current landscape seems ripe for future development. Especially when LMA is hard to expand, this may create a chain of medical facilities all the way between LMA and BMC. While conventional rapid transit can make the trip faster, it will likely not have enough stops. (Such an extension will also likely be needed for a maintenance facility.)
- (-) Metromover's ridership doesn't seem too heavily peak-oriented due to heavy residential development within downtown. While LMA does have some apartment buildings, most of the demand for the APM will come from hospital workers (and to a lesser extend patients), and thus will be much more peak-focused than Metromover.
- Note that an LMA APM may also draw some demand from employees parking at some garages that are further away from hospital buildings (especially when some hospitals have converted their own parking to patients-only).
- (-) When Metromover was built in the 1980s, downtown Miami was far less dense than it is today, so they likely encountered much fewer political issues with running next to buildings than to be expected in LMA. The newer buildings in downtown Miami were built with the expectation of rails running right next to them. That will not be the case in LMA, so it may be much more politically challenging to build.
Overall, I'm still not convinced that APM is the right choice for LMA, especially compared to an elevated LRT or busway -- if an APM can be built, these two probably can, for the most part. But APM does have some advantages going for it.
I will sketch up some ideas for all three modes later.
Looks like Miami's Metromover runs every 90 seconds during rush hours. With that kind of frequency and 4 minutes on the ride, a rider will expect to take 5.5 minutes for both the wait and the ride, plus maybe 0.5 minutes for getting upstairs and downstairs from the stations. That (6 mins) still beats the 10-min walk, and offers much greater physical comfort and weather protection, which can be important for encouraging mode shift (as The EGE argued before in the context of LMA).
Ridership on Miami's Metromover and relationship with walking distance
I wanted to look at whether walking distance affects ridership of stations on their system, e.g. one may guess that stations that are closer to the HRT may have lower ridership. So I took a look:
The inner loop stations are colored by their walking distance to Government Center (transfer to HRT Metrorail). Stops that are closer have a lighter shade.
HRT weekday ridership numbers are: Government Center 6,896, Brickell 5,158, Historic Overtown 1,749 (station to the north without APM transfer).
While we'll need some more local knowledge of downtown Miami to make better conclusions, from this alone, I don't think stations that are close to HRT necessarily have low demands for APM. Sure, Bayfront Park (16 min walk) has the highest ridership except HRT transfer stations, but 3 of the 5 stations that are 9 min away also have pretty good ridership above 1K. (The other two, Third St and Knight Center, have their walkshed cut in half.) And while Brightline transfer may account for Wilkie D. Ferguson, I doubt that fully accounts for the station's impressive ridership - despite being a 5-min walk away from two HRT stations.
Note that there's a big discrepancy between Metromover's ridership (22,286) and that of the two HRT stations (12,054). which suggests at least half of the people taking the Metromover do not use it to transfer to HRT. Even accounting for Brightline doesn't account for the discrepancy. I suspect they may be going to parking garages.
Overall, this seems to suggest that even places that are "only" 9-min walk away from rapid transit may still have demand for APMs. However, I'm uncertain about its applicability to Boston and LMA, especially given the ridership discrepancy between APM and the HRT stations.
