RandomWalk
- Feb 2, 2014
I thought they wanted to colocate a MoW facility with the South Salem station.
I know they share car width, but do they share loading heights?hello, had an idea for a blue-orange line junction at state
i wanted to understand the doability of this junction before i spend time exploring possible service patterns so i came to you all
heres my very basic mockup of how the junction could theoretically work
"cyan" is the name of a theoretical new service that comes from beyond aquarium and goes past chinatown, it would use the orange line's inbound platforms and the blue line's outbound
there is a crossover just east of the blue line platforms
They're off by 3 inches - but that's within the range of adjustable air ballasts. (Which the current fleets are not equipped with - they require a visit to the shops.)I know they share car width, but do they share loading heights?
This is incredible. Puts my small attempt at mapping all streetcars to shame lol.Not sure where to put this, but here is a map of every rail line and trolleybus in Boston ever, based on maps by Alexandra Rapp.
Blue is rapid transit, Gray is non electrified mainline rail, dark green is electrified mainline rail, light green is trolleybuses, pink is streetcar tunnels, red is surface streetcars, and yellow is horsecar lines that were never electrified.
The loop is actually under the CAT there if I recall correctly, you'd need to use the 'hook' that comes out on Essex St. But assuming you do that I believe it would actually work.My understanding of the Silver Line Piers Transitway is that the out-of-service loop is somewhere between E and Beach Streets under Atlantic Avenue. The pitch is to replace that loop - with a portal to the surface that "lands" right at Kneeland.
Good timing, since I've been reading up on the original Phase 3 proposal, but the loop is actually over the CAT.The loop is actually under the CAT there if I recall correctly, you'd need to use the 'hook' that comes out on Essex St. But assuming you do that I believe it would actually work.
Thanks! I guess this goes to show that I might be feasible to actually make the hard turn and pop up just at South St and Essex St. I know the east side interceptor is somewhere along South St but perhaps with the bus tunnel aka Transit way being relatively shallow, it might be possible to get up to grade fast enough and not chase the grade into the interceptor.Good timing, since I've been reading up on the original Phase 3 proposal, but the loop is actually over the CAT.
(While I'm here, anyone have a good idea of where I can track down a copy of that 2009 FTA funding report?)Never mind, I found it but it's not as useful as I thought.
So, fun fact: per Wikipedia the general service pattern you're proposing got a full workup by the then Secretary of Transportation in 2006, after the federal grant application for phase 3 got pulled. The general routing would have used the Essex leg, built a transfer to Park and DTX using what is now the Winter St concourse probably via Lincoln & Summer, and northbound used Kneeland and Surface. I imagine that would still probably remain the best routing today.Thanks! I guess this goes to show that I might be feasible to actually make the hard turn and pop up just at South St and Essex St. I know the east side interceptor is somewhere along South St but perhaps with the bus tunnel aka Transit way being relatively shallow, it might be possible to get up to grade fast enough and not chase the grade into the interceptor.
I like the Oak Square restoration of Green Line service. I like the Blue Line extensions to Charles and Salem. I can get behind the D-E interlining. I like that there is rapid transit to Mattapan. The rest of it is highly questionable, though.This is honestly so much of a crackpot idea that I'm not sure where it belongs, it's originally somewhat based on a bad idea from someone who is extremely anti-Green Line on Reddit. I present to you GLRC but Blue Line:
A new flying Y junction would connect the Blue Line to the Tremont St subway, taking over the outer tracks through Boylston and through a new Washington St subway, continuing down to Mattapan. Is this a good idea? Probably not. Is it interesting? Definitely yes.
Those are really just side notes. The Blue Line to Boylston is the main idea, and you're absolutely right that it's highly questionable. A less questionable version might be something like doing GLRC but sending the Arborway branch up through Longwood/Fenway, then using high floor vehicles on Huntington/GLX/D branches, but that leaves you stuck with high floor vehicles on a Washington St route which could be fine or even preferable for the first section to Nubian but less great once you're paralleling the Fairmount Line and more frequent stops are better.I like the Oak Square restoration of Green Line service. I like the Blue Line extensions to Charles and Salem. I can get behind the D-E interlining. I like that there is rapid transit to Mattapan. The rest of it is highly questionable, though.
I'm guessing the road bridge grades over the Cape Cod Canal might be too steep for rail, but that would need to be verified. My vote would be to just build a high level fixed span rail bridge. The approaches would be long to accommodate rail grade maximums, but c'est la vie.So what if we don't do that, and build a rail connection over one of the road bridges instead?
Right, silly FRA rules strike again. Yeah at that point just build a rail bridge over the current lift bridge.My vote would be to just build a high level fixed span rail bridge. The approaches would be long to accommodate rail grade maximums, but c'est la vie.
Rail Grade Maximums are not exactly just "silly FRA rules". They also reflect real world physics. Steel on steel is not known for its great traction and stopping resistance on grades.Right, silly FRA rules strike again. Yeah at that point just build a rail bridge over the current lift bridge.
