Re: Fairmont Line Upgrade
Sure looks like the GO logo on the front of the artist rendering when the order was first announced:
http://www.metro-magazine.com/news/story/2011/04/metrolinx-taps-sumitomo-for-dmus.aspx
Metrolinx and GO have been merged since 2009. The separate airport service division is a matter of branding, its going to be the same GO maintenance facilities and crews that maintain the DMU's when it starts.
UPearson Express is
not GO Transit. GO is a division of Metrolinx; UP Express is a division of Metrolinx. They are separate Metrolinx-subservient entities with their own management. Like MassHighway, Massport, and the T are separate subservient subdivisions of the DOT, except in Canada it's under a crown corporation instead of a state agency. GO is the mercenary operator and equipment maintainer in the same way that Amtrak runs Shore Line East and Metro North shops maintein them, but GO has no management oversight over UP Express and GO takes a reimbursed check from them for every finger they lift. Which is why it's turning into a boondoggle...there's no accountability because it's pretty much just provincial pols' little plaything. But I could easily see GO having to absorb them in 8 years to clean up the toxic corruption and take all the losses on the electric conversion.
And that's not an accurate rendering of the vehicle livery. It's a manufacturer sample. This is the official branding and paint job:
http://en.wikipedia.org/wiki/File:Toronto_ARL.jpg.
Doesn't seem that different than the idea of branding Fairmount line service as "Indigo Line", and using unique equipment and fare structures, even though it would be operated and maintained as part of the commuter rail system.
No. Because the labor contracts bind it hard to the CR system. SEPTA tried to do this in the 80's by "transitizing" its Regional Rail to scrape the RR unions off its books. It abandoned all its diesel routes and went on this quixotic management quest to reinvent ops on their electric lines. As if it were BRT-esque hybrid of a subway line with FRA-compliant vehicles. They lost over 50% of their ridership over a 5-year span because of the corrosive effects of crippling labor strikes and talent drain sending their customer service to worst-in-nation levels. And the whole pointless civil war distracted them from doing barest system maintenance, creating a backlog that forced further shrinkage of the system that they are still in a bind trying to recover from 3 decades later. It took 28 years for ridership to recover back to 1979 levels, and there is still a movement to take the Regional Rail away from SEPTA and let the state DOT run it because some managers are still pushing bad "transitization" ideas that keep the system permanently treading water.
That will never ever ever ever ever happen here. You can paint it on a spider map however you want (and they chose "Indigo" for a reason...you don't have to repaint the Purple Line), but it will always be run by the commuter rail for the commuter rail interoperable with the commuter rail. And it would be silly not to because Fairmount's going to become the load-bearing line in the future for more of the Franklin schedule and all of the would-be Foxboro schedule, because the NEC can't handle it. You cannot have "uniqueness" on that line putting it in conflict with the way the other ones are run. Nor can you template the "Indigo" model to other lines when every possible application (Allston-Riverside, Reading, Waltham, Needham) shares routes with a regular CR line. The closest you are going to get is if Zone 1A gets synced by happenstance with the subway fare or some future "Zone 0" layer gets added as a shiv for direct subway card compatibility.
Now, for fare collection and staffing reform...that
is an issue universal to the CR. The whole damn system--fares, parking, everything--should be Charlied. Every coach should have a tap surface for OPTO capability and every conductor a hand scanner. They should try to reform the union requirements for 1 conductor per 2 cars (although going all bi-level does bring the labor costs down a little bit). All of that. But across the commuter rail, not some special niche here.
Equipment is the same. DMU's don't wash today because today's makes are so unique, so much more expensive per unit than regular CR equipment, so much harder to maintain than push-pull or EMU's (requiring specialized parts and expertise), and as Matthew noted so asphyxiated by FRA insanity that the weight nullifies most of the performance difference vs. push-pull. They are nowhere near as good a mode as they should be, nowhere near above-and-beyond a 2-4 car push-pull set fronted by a zippier accelerating HSP-46 (if they took the care to assemble Fairmount trainsets more carefully). And the cost, performance, and cost recovery over life of the car order is inferior to electrifying the damn thing and going pool service with Providence and RIDOT.
The biggest CR systems in the country are not going to budge on this until there's that sea change. It is too big an anvil on their sprawling fleets to support what's now a novelty mode. All 13 North American CR systems (yes, including GO Transit-proper) that have more than 15,000 daily boardings have no immediate plans to buy DMU's. 6 of those systems already juggle more than 1 type of mode: diesel push-pull, EMU's, electric push-pull, or dual-mode push-pull (all 4 of 'em in NJ Transit's case). 2 more systems (GO and Caltrain) are set to introduce new EMU's to their currently all-diesel systems within 3-10 years. 2 more (SEPTA and Mexico City Ferrocarrill Suburbano) already are 100% electric. And 2 more (MBTA and L.A. Metrolink) have electrification study decisions to make within 7-10 years on their currently all-diesel systems due to shared HSR track commitments with the NEC and California HSR. Plus Amtrak has a well-publicized aversion to running Frankenstein vehicles when it's contracted for CR ops; the T's ham-fisted GP40 loco purchase/oddball-retrofit was one of the last straws before they left town one finger in the air.
Where exactly does not-mature niche technology fit into the mix with these guys? They have way way more pressing and consequential purchase decisions to make with all they have to oversee.
Nippon-Sharyo also has a lot of experience building EMU's. Designing a DMU body shell so it can be converted to an EMU at a later date would not be beyond their expertise.
EMU ≠ DMU. Stripping out the diesel guts and replacing with electric guts is de facto buying a new car. They are completely different animals. Yes, you can recycle the shell and the interior livery. Maybe even the wheel traction motors if the initial purchase is some super-premium $$$ component akin to ALP-45DP loco's dual-mode motors. But the steel and fiberglass frame is the
least expensive part of the car. And the weight distribution is going to be very different with the fuel weight removed. DMU fuel tanks are oddly spread to balance out the car weight. Remove them and the weight distribution gets weird and the car is unlikely to ride as well (swaying, herky-jerky starts/stops, potentially more serious out-of-whack issues that would limit their max speed). That's why UP Express's plan to convert the Nippon Sharyo's is so insane. They will be below-average quality Frankenstein EMU's at a time when GO Transit is buying battle-tested generics. It is not worth their while to preserve the shell when the shell is cheap. They're better off just buying new EMU's. Which is going to look really silly when they have to dump their incredibly expensive DMU's for a huge loss when they're still close to new.
The MBTA seems very serious about buying a small fleet of DMU's for the Fairmount Line, don't be surprised if they start a procurement process for them at some point in the next year or two.
The T is
not considering DMU's today. At all. There is no evidence of that. No chatter. Nothing. It has 75 more bi-levels on its Rotem option order it has to pay for in a constrained funding environment, and is obligated by Amtrak as an NEC improvements partner to study their post-2020 electric options. Just because the Fairmount studies modeled "generic DMU's" performance doesn't mean they are moving in that direction or that it's go-time for planning that. "Generic DMU" doesn't exist in this country yet. The T cannot do waivered units because there is no time separation from freight traffic. And the compliant units are what they are: too heavy, too complicated, too expensive. They have to model for "generic DMU" because the glass-half-full view says we're only elimination of a few silly paper barriers away from being able to import them en masse. Therefore they have to do due diligence on the schedule modeling so that option is on the table if the availability of "generic DMU" ever comes like it has in Europe. Glass-half-empty view, however, says the regs are not going to change before end of this decade, that the current batch of FRA-compliants are not falling in price nearly fast enough, and that the SPRINTER's/SMART's/eBART's/UP Expresses of the world fucking up their rollouts time and again with rank incompetence is doing the vehicles no favors at opening up the market. At the timetable where a cost-effective DMU option is likely to start looking attractive for an agency like the T, they will already be spending bucks buying Providence Line electrics and will have had enough time to do their Fairmount electrification study and make a go/no-go decision. 2020 or beyond before it's realistic. On that timetable, why are we holding out for the great white DMU hope? Start the prelim electrification study.
