Fall River/New Bedford Commuter Rail (South Coast Rail)
MassCoastal reactivation to the state line is set so Gold Medal Bakery, a big longstanding customer, can switch back to its home rail siding for the first time in 25 years instead of trucking down the street from rail dropoffs at the Port. Also some new customer taking up residence at the pier across from Gold Medal...ship-to-rail road salt I think. The holdup is that MC is getting "donationware" rail hardware surplus from other T projects, so they're not on any clock. Restoration will cross Mt. Hope Ave. to the gas tank farm at the literal state line for a locomotive runaround track.
For that reason no one can really shiv a trail in there as earth-salt move because it's "active". It's only possible if RIDOT is explicitly planning a rail-with-trail redesign, as P&W can be used as the proxy to instantly shut anything down.
Any chance on a source for that Fall River reactivation news? This Oct. 2019 Draft Design on the Tiverton Mount Hope Bay Greenway (PDF Warning, large) specifically notes that:
The City of Fall River recently pursued funds to rehabilitate the rail corridor in the city for freight use, however that effort was not successful. No funds or defined project scope have yet materialized.
Edit: in so far as I can tell, it wasn't awarded any funding in the 2012-17 IRAP rounds, or the 2018 or 2019 rounds. But, apparently Fall River also used CPC funds to hire a engineering firm to design a trail option, which appears to assign low priority to rail accomodations, even if they will eventually have no choice.
At least the RIDOT Tiverton design does however make it very clear that the preferred build alternative is rail with trail, with the trail diverging onto either low volume surface streets or onto a new alignment (CRMC greenway buffer). At any rate, this report encapsulates the environmentals of any future restoration of this segment, and as far as I can tell it's good news for future restoration. The bridges and their super and sub structures appear to be in reasonable shape from a cursory inspection. They do call out deteriorated drainage structures, which would need replaced as part of the shared use path and/or rail service; I suppose rail can sneak through early action on bike paths too. They're well into the public engagement stage at this point.
Press Herald has extensively covered the MassWorks grant saga. The first two tries were based on 3 customers: (1) GM, (2) a sludge transload at the sewage plant at state line end-of-track for transport to an incinerator facility, and (3) the road salt transload biz setting up on the pier up the street from GM. State thought their asking price was too high for too-fuzzy carload numbers, as they didn't have well-refined numbers for the pier transload or sludge pickups. City's trying again as now the pier owner is negotiating for wind turbine assembly rail-to-ship (similar to what Port of New London is using its rail-enabled docks for a L.I. Sound wind farm deployment), and they drew conclusion from the last rejection that the state wants them to diversify the top-line biz prospects a bit more before they commit the bottom-line resources.
2015, Borden & Remington award. That's the Port siding Gold Medal currently shares. The grant expanded storage in those tight confines so GM could go to primary railcar bulk-flour deliveries and trim its long-distance trucking shares. That's the impetus for corporate's self-reinvestment in the home siding, where they'll be able to have automated machinery empty it direct into the factory. Knocking their carload count permanently up was the prerequisite for that, so they've been in negotiation ever since the '15 award while Mass Coastal flogged the real estate at the (then-derelict) pier and City worked the sewer plant sludge angle to give it critical mass.
Right now the plan sans another MassWorks or other grant win is to accumulate small bits of funding and "donationware" hardware to build it piecemeal with no set end timetable. The salt pier (already in operation for truck off Middle St.) would be reached first 3300 ft. from end of rehabbed Port track, and not require any grade crossings to get to. GM would be second, another 4500 ft. and 3 private grade crossings. Sewer plant would be last at 2500 more feet and 1 public grade crossing at Mt. Hope Ave. Winning the grant would simply let them do it all in one shot like they want to instead of staggering it way out on installments.
That same design does however make it very clear that the preferred build alternative is rail with trail, with the trail diverging onto either low volume surface streets or onto a new alignment (CRMC greenway buffer). At any rate, this report encapsulates the environmentals of any future restoration of this segment, and as far as I can tell it's good news for future restoration. The bridges and their super and sub structures appear to be in reasonable shape from a cursory inspection, They do call out deteriorated drainage structures, which would need replaced as part of the shared use path and/or rail service; I suppose rail can sneak through early action on bike paths too. They're well into the public engagement stage at this point.
It's not "preferred"...it's mandatory. The Tiverton study can coach rail-with-trail in whatever language it wants, but it became a federally active line again when Mass Coastal--at MassDOT's agreement--sent out 30-day reactivation notices to abutters some 3 years ago to get their parked boats off the ROW...then sent the brush-cutter through to make sure the tow trucks could get in to haul away any scofflaws on Mt. Hope. Federally-speaking it's already paper-active because the primary rights-holder has stated the intent to operate again. And thus the only legally permissible way of making a trail is designing it for a shared-use active ROW. There are no "choices" in the matter, no matter how the study words it. So while it's good that the study is bullish on the feasibility...we have to be explicit here. There is no alternative except trail with clearance separation from presumed-active rail...no functional wiggle room whatsoever when it comes to turning shovels out of that study. Those are simply the federal preemption privileges of being the incumbent active rights-holder. MC can take as many years as they want to actually do the restoration on the installment plan, because this isn't a move that has to be adjudicated at all through the Surface Transportation Board with any public comment or holding-hands with other parties. It's strictly a 1-on-1 open file at the FRA...that they can either keep open by perpetually filing 30-day activation notices, or finalize by calling for an FRA inspection of their restored track to be blessed with go-ahead to operate. And if MC needs an assist asserting itself...P&W also has overhead rights from East Junction, Attleboro to Fall River and the state line for accessing its extant Newport rights described in previous post and can tag-team a support filing for protection of its own route.
And unlike the Cape lines where MC is on a 10-year open-bid rights renewal from the state because Conrail voluntarily sunset its ancestral preemption when it sold out in 1982, the South Coast lines were a filet dispersal from CSX in 2008: ownership direct-conveyed to MassDOT, rights direct-conveyed to MC. Meaning MC is the incumbent inheritor of all 150+ years of vestigial rights dating from CSX, Conrail, Penn Central, NYNH&H, and Old Colony. The state can't terminate them here because it wants a trail only without going in front of the federal STB and trying to prove gross negligence. That's an utter nonstarter when MC is clearly trying like hell to grow new biz on the OOS section, and has succeeded very well at growing new business on the active line. It's either that or overpay them a giant wad to GTFO and retire their rights voluntarily...but there's zero way the state can justify a one-time buyout vs. the years of revenue passed up (or get that past the local Legislative bloc who are gung-ho for this restoration).
So...rail-with-trail supervised by the line-owning states at no operating demerit (e.g. no time-of-day restrictions on freight ops so the walkers/bikers can frolic off-footprint or anything like that) is the only build Alternative permissible. Anything other than that given lip service in the Tiverton study is a nonstarter, and window-dressing to give abutters the warm-and-fuzzies that they have more options than they actually do. A reactivation from OOS is a completely different and entirely more closed process than reactivation out of landbanking. Given that reactivation plans are already in motion to the MA state line and can take as long as they bloody feel like it to get moving, it needs to be underscored just how limited--nay, virtually singular--the trail choices are. It isn't a negotiation; it's take-it-or-leave-it with the side room available. Tiverton legally isn't any different with the RIDOT/P&W trump card, just not as immediately constricting because 30-day notices haven't been filed on that side of the border yet. I suppose some not-smart planning entity could build a "trail-in-rail's-envelope" a little clearance-carelessly and get away with it for some years there...but they're S.O.L. and out a lot of sunk-cost trail landscaping wherever clearances foul if P&W ever does file FRA notice so I also can't picture any RIDOT-supervised trail job risking getting sloppy. If this is to be a real risk-measured thing, it's going to cost the going rate of a full clearance separation on the ROW property lines. Cut corners won't be allowed period in MA where the reactivation process has already started...and would simply be ill-advised in RI.
It's been awhile since anyone has posted actual project updates so I'll give it a go, they have a weekly email newsletter and post updates on their site: https://www.mass.gov/info-details/south-coast-rail-construction-activity
The big news is the early action bridges and culverts are all finishing up/done, demolition is done, and construction is starting on the Fall River branch with clearing and retaining walls. The Construction for the New Bedford branch (and Middleboro) got the Notice to Proceed last month, predicted turnover date for the whole thing is August 2023.
Oh and a pretty good presentation summarizing what's happened so far with some photos: https://cdn.mbta.com/sites/default/...fmcb-11-south-coast-rail-quarterly-update.pdf
95% of the work is a pre-requisite for the full build project anyway. Only the Middleboro secondary portion is extra
Unless I'm misunderstanding you, it seems it would have been a better idea to do phase 2 before phase 1? Yeah, they don't serve the actual south coast until the very end of the project, but at least they build the hardest part first and don't overwhelm the single-tracked segment shared with three other lines?
That needs an estimated extra 2 billion that they just don't have. Especially with the current economic situation I wouldn't expect phase 2 anytime soon unless there's a sudden influx of federal grant money. It really came down to what they can afford to do, not what's best. That, and the myraid of complaints about wetlands and abutters in the phase 2 route.
And honestly, if we're going to spend an extra 2 billion on commuter rail, I can think of better places to put it
Phase 2 is never going to happen as currently planned. $2 billion for 15 miles of reactivated track, with almost zero new intermediate ridership, through a density crater, with 24 new grade crossings, through three towns that don't want it and specifically don't want grade crossings, for marginal improvement to South Coast service? Not a chance.
The proper solution has been staring us in the face since 1995: the Attleboro bypass.
Just 2.5 miles of new rail ROW, entirely along an existing and nearly flat power line ROW. Only two new grade crossings, both of which would be easy to bridge. The rest is just upgrades of active freight rail; of the 17 crossings, half are easy eliminations. (You could probably trench through Taunton to eliminate the rest and still save a lot of money.) Two new stations: Norton (wherever the town wants it), and Taunton at the bus terminal next to downtown. Improvements on the NEC would be relatively modest - probably an Amtrak/freight passing track at Mansfield, siding at Sharon, and the long-desired triple-track from Readville to 128. A much easier sell to the towns - Attleboro could probably be convinced because the SCR trains serving Sharon and Mansfield would allow some faster expresses. (Two fewer station stops versus the Stoughton route, and no single-track swamp trestle, means your schedules aren't as constrained.)
Attleboro bypass was *violently* opposed by Town of Norton. And Taunton had (way more legit/substantive) major issues with that routing engaging all 15 (!) grade crossings in town on the Middleboro Secondary on a double-barrel commuter schedule...with steep traffic demerits where they cluster one crossing every 2/10ths mile through 2 miles of dead-center downtown. That was the very first of the DEIR Alts. eliminated, way before the Army Corps FEIR broke the Stoughton Line with that single-track trestle insanity through the swamp + skip-stoppage requirements. The M'boro Alternative is a service shit sandwich, but don't automatically assume the Attleboro Alt. looks the least bit rosy by comparison. It had a multitude of hard-to-overcome problems.
A *properly* constructed Stoughton Alt. is still king of the heap on ridership. And only hits 2 of the 15 Taunton crossings on the Middleboro Secondary while avoiding all of the most-problematic dead-center Downtown ones that the Attleboro Alt. was forced to engage. The 4 other Taunton crossings exclusive to the Stoughton Line were all minor and well out of Downtown. Hands-down Stoughton was a faster and far less-invasive route through Taunton because of the polar-opposite crossing disparity to the Attleboro Alt. The only thing that has to be done is challenge the Bush Admin. Army Corp's bullshit trestle requirement for the old double-track embankment through Hock Swamp...which (per lengthier other explainers) is challengeable because a Clinton Admin. Army Corps did not object to the Greenbush Line's far more environmentally sensitive DT embankment through Scituate's marshlands making the sum total difference between the 2 restoration projects arbitrary politics. The Corps' kingmaker arbitariness was significantly defanged in the Obama Admin. over fishy calls exactly like this, so the DEIR is ripe for a re-try if anyone cares enough to press a case (which Baker/Pollack have made clear they never will, but maybe some subsequent regime can be talked into). Lose the trestle and $1B immediately comes off the project cost while mending all the skip-stop breakage on the mainline. Someone just has to give enough shits to try for it.
If you can get twin-bill :30 RUR schedules down to Taunton Depot on (1) a Stoughton Line mended from the DEIR's intentional breakage, and (2) with due attention paid to NEC capacity Readville-Canton Jct.--which no other South Coast-related study ever considered within-scope to its own demerit--then you can ensure hourlies to each of the endpoints that will actually hit paydirt on ridership. But pretty much nothing else at these sad 90-minute or worse intervals--including the DEIR-sabotaged single-tracked Stoughton Alt.--will accomplish that. Attleboro Alt. included, because more NEC running south of Canton is going to net something sub-hourly on branch frequencies...and that's probably the paydirt threshold that must be upheld.
This would be a fantastic project if actual hourlies to the cities were ever in the cards. We've just had everything less than and except that threshold shoved down our throats instead, and this shell game where the clearly bullshit FEIR by an Army Corps that got reined in afterwards for submitting too many bullshit FEIR's gets treated as some sacrosanct immovable object instead of a challenge ripe for a fight. This is the end result.
It never had to be this unacceptable. It was an explicit choice somebody made to spend to pornography on unusable service levels. Never forget that they willingly chose utter frequency brokenness and shit service integration that rather than choosing to fight for anything remotely taut, frequent, or coordinated with last-mile feeders. Chose this.
Brings back memories of the Norton Gang (CCATS)! Battled them in the New Bedford Standard-Times for a while until one of them went over the edge!
The grade crossing issue also eliminates the Mansfield bypass route that TransitMatters (I think) was proposing.
No...that was Ari O. solo in a blog post. Same difference...A'boro Bypass was a flat power line ROW about 2-1/4 miles north of Attleboro Station addressing the wrong-way direction of Attleboro Jct. (only accessible from the south). Ari's M'field Bypass was the non-landbanked former 1955-abandoned connecting leg of today's Framingham Secondary to Taunton (paved over as Old Colony Rd. in Mansfield from the junction, intact from there to the Taunton Industrial Track as power line ROW). He simply plunked a new NEC junction 1-3/4 miles south of the original that forks off right after the 495 + School St. overpasses to skip the Downtown Mansfield blockage and turns ESE on 495's shoulder to the airport to meet up with the old ROW. They're almost literally the same distance, literally same travel time, literally the same construction cost and relative complications (considerably more wetlands EIS'ing for Attleboro vs. considerably more Norton NIMBY's and grade crossings for Mansfield), literally the same intolerably bad Downtown Taunton grade crossing cluster, and literally the same unanswered questions about NEC capacity south of Canton Jct. being up-to-snuff for running it amid 125-165 MPH Amtrak meets in max-speed territory.
Why Ari presented it as a "new" idea was a head-scratcher given that it re-traced all the well-trodden ground that got rejected in the DEIR for the Attleboro Alt. a decade prior. But he never really kept stanning for it after that one post so you can probably write it off as an idle of-its-moment thinking exercise and no more.
About the only thing Mansfield would've done better than Attleboro is put the Norton stop much nearer to Norton Center @ the 495/MA 123 exit a few blocks away from Wheaton College...better than the Middleboro Secondary which would've slotted it in the middle of nowhere by S. Worcester St. But that's kind of a moot argument because the Norton NIMBY's don't want anything to do with the train to begin with. And given that in-town transit shares are virtually zero and lots of folks on the western parts of the 123 corridor through town closer drives to Attleboro Station and its extremely more frequent service to begin with, most in that tiny town wouldn't opt for the local stop even if given the choice.
BTW...to show how dizzyingly bad the Taunton crossing clusterfuck would've been, here's the locations in question.
Attleboro Alt. (DEIR studied/rejected) only (west to east, Middleboro Secondary)
  • Harvey St. (minor....1.25 mi. from Woodward St., Norton / 3475 ft. to Crane Ave. S)
  • Crane Ave. S (minor...3475 ft. from Harvey St. / 4800 ft. to Fremont St.)
Mansfield Alt. (spawn-of-Ari O.) only (northwest to southeast, restored ROW + Taunton Industrial Track)
Attleboro Alt. & Mansfield Alt. shared (west to east, Middleboro Secondary)
<<begin Downtown cluster>>
  • Danforth St. (3200 ft. from W. Britannia / 2300 ft. to MA 140)
  • ¹MA 140 (BAD angle!...2300 ft. from Danforth / 840 ft. to Oak St.)
  • ¹Oak St. (840 ft. from MA 140 / 1250 ft. to Porter St.)
  • ¹*Porter St. (1250 ft. from Oak St. / 305 ft. to Cohannet St.)
  • *Cohannet St. (lousy angle...305 ft. from Porter St. / 275 ft. to US 44)
  • ²*US 44/Winthrop St. ("Center of Universe #1" crossing...275 ft. from Cohannet St. / 725 ft. to Harrison Ave.)
  • ²Harrison Ave. (725 ft. from US 44 / 860 ft. to MA 138)
  • ²ªMA 138/Somerset Ave. ("Center of Universe #2" crossing...860 ft. from Harrison Ave. / 400 ft. to Weir St.)
  • ªWeir St. (lousy angle @ intersection...400 ft. to MA 138 / 2415 ft. to Ingell St.)
<<end Downtown cluster>>
*6-car train physically blocks all crossings in group at once
¹gate timings block all streets in group at once
²gate timings block all streets in group at once
ª6-car train physically blocks all crossings in group at once
Stoughton Alt. (FEIR-endorsed) only (north to south, Dean St. Industrial Track a.k.a. Stoughton Line)
  • E. Britannia St. (minor...1 mi. from King Phillip St., Raynham / 1575 ft. to Thrasher St.)
  • Thrasher St. (minor...1575 ft. from E. Britannia St. / 2560 ft. to Winter St.)
  • Winter St. (current Mass Coastal end-of-track...2560 ft. from Thrasher St. / 2575 ft. to US 44)
  • US 44/Dean St. (Taunton Depot station stop w/DTMF queue dump...2575 ft. from Winter St. / 1.1 mi. to Ingell St.)
Attleboro Alt./Mansfield Alt. + Stoughton Alt. shared (west to east, Middleboro Secondary)
  • Ingell St. (triple-crossing w/Mass Coastal yard...2730 ft. to Hart St.)
  • Hart St. (2730 ft. from Ingell St. / 2.3 mi. to Cotley St., Berkley)
Middleboro Phase I shit sandwich only (east to west, Middleboro Secondary)
  • Old Colony Ave. (2.7 mi. from N. Precinct St., Lakeville / 3725 ft. to Middleboro Ave.)
  • Middleboro Ave. (3725 ft. from Old Colony Ave. / 4880 ft. to MA 140)
  • MA 140/County St. (BAD, abuts MA 24 interchange...4880 ft. from Middleboro Ave. / 1.6 mi. to Cotley St., Berkley)
TOTALS in Taunton
  1. Mansfield Alt. -- 16 (!) Taunton crossings (bad ones: all 9 Downtown + 1 industrial park): driveway + Myles Standish + Prince Henry + Fremont + W. Britannia + Danforth + 140 + Oak + Porter + Cohannet + 44/Winthrop + Harrison + 138 + Weir + Ingell + Hart
  2. Attleboro Alt. -- 15 (!) Taunton crossings (bad ones: all 9 Downtown): Harvey + Crane S + Fremont + W. Britannia + Danforth + 140 + Oak + Porter + Cohannet + 44/Winthrop + Harrison + 138 + Weir + Ingell + Hart
  3. Stoughton Alt. -- 6 Taunton crossings (bad ones: none): E. Britannia + Thrasher + Winter + 44/Dean + Ingell + Hart
  4. Middleboro Alt. -- 3 Taunton crossings (bad ones: MA 140 @ MA 24): Old Colony + M'boro + 140@24
It's safe to say there has never anywhere in MA been a crossing traffic management quagmire anywhere close to the magnitude of the Attleboro/Mansfield Alts. in Downtown Taunton for crossings simultaneously blocked by passing trains. This is the sort of thing you may see on some LIRR branchlines running short/zippy EMU sets...but never on 6-car long-haul schedules. There were very substantive reasons why the west trajectory through Taunton got turfed so early on in the DEIR evaluations. The Norton NIMBY's got outsized publicity, but are a mere footnote to what kind of carpocalypse Taunton would have to encounter all day/every day running that route. This route is fine for the summer weekender Amtrak Cape Codder revival or maybe some sparse RIDOT Providence-Newport commuter extras running express around the horn, but has completely/totally inappropriate traffic demerits for any form of regular service.
The single bad one on the Middleboro Alt. isn't outsized-bad because of its singularity and the fact that frequencies are and will forever be unusable shit via that trajectory. It's more emblematic of how un-serious the M'boro Alt. is in the first place that uselessly sparse service might leave behind a giant offramp backup a couple times a day as a local 'perk'. Overall the utilization isn't high enough to matter.
Stoughton Alt. clearly pegs it. The only heavy-traffic road, Dean St., is the station stop where DTMF signals will time-bomb the gates during station stops for expedited queue dumps making it a non-issue. Pretty much thru-and-thru from Stoughton this one has the most sanely balanced crossing roster of any. Even where they come in clusters, like Downtown Easton, it doesn't *really* cluster because it's mostly hitting quiet side streets on the grid.
A 5,000' long embankment eliminates 8 downtown Taunton grade crossings. Sounds worthwhile to eliminate so many crossings in such a short distance, especially for 1) better routing, 2) better station placement, and 3) direct GATRA hub transfer.
So...introduce more cost bloat on a routing also weighed down by:
  • inferior ridership due to the Norton intermediate's poor draw
  • unsolved traffic management concerns with the south-of-Canton section of NEC that's tied for the highest speed differential in the Western Hemisphere for cleanly staging local vs. intercity meets, likely preventing the co-mingled branch service from ever achieving useful enough frequency threshold
  • still-unballparked EIS costs for the virgin ROW (A'boro or M'field Alts.) because the Alt. was eliminated from consideration so early on that those costs were not tallied. That's miles of wetlands we have not yet done deep analysis on, with high potential for cost blowouts.
  • violent NIMBY opposition from a town that must be engaged on any of the Alts., whose transit shares are so poor that they won't return in utilization what they take in aggravation
You only solved ONE problem with the routing by backing up the money truck for Taunton separation. ^These^ might not be as individually fatal, but collectively? They already caused a project scoring fatality for this Alt. more than a decade ago. Busting your budget on the Taunton separation megaproject doesn't fish it out of the reject pile. And that's assuming Taunton even wants a Chinese wall erected across Downtown for its troubles on this endemically service-poor Alt. They already overwhelmingly back the Stoughton Alt. with station at the traditional Dean St. site over this...so good luck convincing them their crossings *have* to be used enough with the Alts. switch to require all that invasive construction and visual impactors in the first place. Jesus, for all this effort to rehabilitate this Alt. to half-cripple we could friggin' separate Framingham at a world's better good for the money. Perspective!
So why is that an easier planning effort? You could challenge the fraudulent FEIR trestle requirement under a chastened latter-era Army Corps, instantly lop $1B off the Stoughton Alt.'s cost, and bring full double-tracking back to mend that Alt.'s only fatal flaw arbitrarily keeping it from delivering the necessary service. Stoughton is so over-the-moon better for hitting the only service target worth a damn for this whole project that it requires considerable suspension of reality to pretend that pouring more good resources down the bad Attleboro/Mansfield or Middleboro black holes is somehow par-acceptable alternative to just doing it fucking right once and for all. That old FEIR isn't sacrosanct. It's dated enough by this point that Phase II...if it ever gets a serious push by some future Admin...would need a refresh anyway. Which engages the newer politically defanged Army Corps all the same and puts the BS trestle tankapalooza under new evaluation. Just because it's part/parcel of Baker/Pollack's rope-a-dope to let Phase II's future prospects die on the vine of garbage Middleboro-fed service killing all the growth potential doesn't mean we have to nod approvingly with our hands folded. Challenge that flawed piece of FEIR paper like it's the only thing that matters for delivering real service, and force the issue by depriving the tankapaloozers-in-chief of all their excuses for not doing Phase II right.
Are we going to keep pretending that's never ever ever in a billion years substantively revisitable in any way/shape/form while we simultaneously keep pitching with straight face ever more desperate tactical nuclear strikes at the other broken-by-design Alts.? Come-fucking-on...the world doesn't work that way, and this project for damn sure isn't going to net a meaningful service target if we don't take the arbitrary straightjacket off and get real. Hourly service to each Fall River and New Bedford: where is it sourced from? Damn sure not from hitting the already-crippled routings harder in desperation.
Just a FYI - About 35 cars worth of rail came into Framingham this past weekend in two groups. All billed to Assonet, Ma. I suspect this is rail for the under construction layover yard at Weaver's Cove in Fall River. As for being billed to Assonet, the cars will probably be stored/staged at the former Weyerhauser site near between High Street and Copicut Road.
^Info on Weaver's Cove layover. It's the bulldozed blocks abutting North Main, opposite the gas tank farm on the riverbank.
Work on Fall River Secondary Main Line
Delivery of Railroad Ties to Campanelli Drive in Freetown
Over the duration of this project the contractor will be installing new track along the South Coast Rail corridor. Construction of this track involves the delivery of new railroad ties to the project construction lay-down yard on Campanelli Drive in Freetown. These ties, commonly used throughout the nation’s entire rail system, can produce an odor, and the contractor will be taking steps to mitigate any impacts to the community.
Deliveries are expected to begin this week and will continue every few weeks until early 2021.
General Activities
This week and next, the contractor will continue with hydrant line installations, access road construction, tree clearing, erosion control, delivery and moving of materials, equipment mobilization, and survey work occurring along the Fall River Secondary Line right-of-way.
Stating next week, the contractor will receive (via rail cars) sections of rail to be utilized along the Fall River Secondary Line right-of-way. Deliveries are scheduled to commence next Tuesday, December 15 in the Adams Lane area of Berkley and advance south to Fall River through the end of the year.
Location of Work:
Freetown Station site, 161 South Main Street, Assonet
Fall River Depot site, 825 Davol Street, Fall River
Fall River Secondary Line railroad right-of-way between Adams Lane in Berkley and Fall River Depot
Dates/Hours of Work:
Current week: Monday, December 7 through Friday, December 11, 7:00 AM to 3:30 PM
Next week: Monday, December 14 through Friday, December 18, 7:00 AM to 3:30 PM
Retaining Wall Construction
The contractor will continue the installation of steel sheeting for retaining walls in the railroad right-of-way south of Adams Lane in Berkley to the Assonet River in Lakeville.
Current week: Monday, December 7 through Saturday, December 12, 7:00 AM to 7:00 PM
Next week: Monday, December 14 through Saturday, December 18, 7:00 AM to 7:00 PM
FWIW...Weaver's Cove tank farm was the proposed site of an LNG unloading facility bankrolled by Hess. Violently opposed by the locals and carpet-bombed by local ordinance blockers, until Hess withdrew the proposal about 8 years ago. That LNG saga was basically 'the' local story in the City for the balance of the 2000's decade. Hess has since floated a couple lesser fuel transload proposals for the site in the years since that have similarly gotten shouted down at the talk stage. The near 20-year duration of these various sagas explains in large part why the layover yard parcel abutting North Main has not been redevved for any other purpose, including simple infill of housing on the barren west side of the street to match the east side's residential density and heal the curious gaps spanning the few lonely homes that do occupy that bombed-out 3 blocks spanning Haskell & Sidney Streets. That was all "Hiroshimaville" during the LNG saga.
Going back on Historic Aerials it doesn't look like anything has ever been on that side of the road in the last 80 years, which is a head-scratcher since the tank farm never got all the way to the road and nothing else explains the conspicuousness of the cavity vs. its across-street surroundings. At any rate, pretty ripe place for idling trains as a result. The lead tracks into the yard may serendipitously jump-start a new attempt at industrial redev (fuel or otherwise) for the tank farm, since the loading dock there is gigantic and could serve as a breeder for all kinds of ship-to-rail Port functions. This--and New Bedford's layover inside the existing underutilized Mass Coastal freight yard in Downtown--are arguably a couple of the project-related developments that could be said to have some multimodal efficiencies given the easy-layup freight coattails at both yard sites.
