Fall River/New Bedford Commuter Rail (South Coast Rail)
Is this the end of the line, or will it extend further south into downtown?
This will be the end of the line.
State Pier at State Pier Maritime Terminal (the former steamship wharf) was a potential station site, in addition to the station pictured (New Bedford Station, originally called Whale’s Tooth in the planning process). By 2010, only the Whale's Tooth site was selected for inclusion.
Why are these single track platforms? I get that the current planned schedule doesn't remotely involve bi-directional traffic, but I would hope that eventually we'd see enough trains to have gone with island platforms.
The bestest most optimistic scenario of :30 Regional Rail on a restored double-track Stoughton Line (assuming they can solve for the single-track swamp trestle pinch point the Army Corps stuck them with) is only going to provide for hourly service on the branches at most. So you'll probably never need more than what's there right now. At most an extra passing siding, but probably not double-track platforms.
Also, at least for New Bedford, doesn't the proximity to the layover reduce the need to turn trains in place at the platform?
I thought this coincided with improvements to the old colony line ? I guess not ?
Nope! Not yet. The mainline between Braintree and South Station has some serious limitations with single-track on a large portion of it. It might have been the MAPC or maybe MassDot, but there was a recent survey asking about "the next big transit project" that Mass should be planning for. I wrote in the survey the Old Colony main line should be double-tracked from Braintree to South Station to allow for reasonable service to Fall River/New Bedford. I think there have been various studies along with some reconstruction ideas of I-93, but nothing serious that I've seen other than a few "planning" ideas. It's crazy to me. Kingston, Greenbush, Fall River, and New Bedford are all branches that merge on a single track on much of way from Braintree to South Station. Throw in a Plymouth branch, and you have FIVE branches merging into a single track. No other rail lines in the MBTA Commuter Rail system have that bottleneck.
Isn't there also another "throat" issue with space allocation for the double tracking versus I-93 lanes that has MassDOT tied up in knots?
In general the alignment is quite narrow, and finding space for an extra track in many sections would be... difficult.
My preferred solution would probably be:
  1. Plymouth or Kingston, pick 1. (I vote for service into downtown Plymouth, or at least closer to it. A ~2mi extension to Lothrop St would be very easy.)
  2. SCR Phase 2 for faster service to New Bedford/Fall River.
  3. Consolidate the RL at JFK/UMass to allow for 2 CR platforms. As part of this the split point would be moved to Savin Hill, freeing up room for full double track along the Dorchester segment.
  4. Double track between Braintree and Quincy Adams, there's room for it already. This leaves a 3 mile stretch single tracked.
  5. Close Quincy Center CR to increase average speed along the single-track section
  6. Add a passing loop at Quincy Center by cutting into Freedom 'Park'
That leaves 3 branches, Greenbush, Plymouth, and Middleborough/Lakeville. (Although with SCR maybe the line should be cut back to Bridgewater? That's a different question for another time.) The lack of recovery from the pandemic and the generally low ridership probably don't warrant <30min headways on Greenbush, but an extension to Plymouth would likely boost ridership on that branch, and MB/L ridership has actually exceed pre-pandemic ridership. We'll allow 15 minute headways on both of these lines. It seems like this is just barely possible with the previously mentioned measures and these headways.
Kingston has been a great big TOD failure with the carpocalyptic big-box proliferation surrounding it, the intentional access disconnection from the adjacent country club residential, and Kingston Collection being a textbook dying suburban mall. Cordage Park, itself a TOD failure for years because of stalled development, is at least starting to get its act together on mixed-use density, and Downtown Plymouth is very walkable. I think the T needs to have an exit strategy in mind for the Kingston sand pit in the next 20 years, because the dev winds are blowing away from it and towards Plymouth. They can keep the Kingston Branch for the layover yard, but a new mainline station (closer to Downtown Kingston anyway) with all schedules running to Downtown Plymouth should be the goal.
I diagrammed out how to do it in this post. Includes treating the area between Southampton Yard and Columbia Jct., and compacting Columbia Jct. YMMV on whether a 2-track Red mainline through Savin Hill with a split down on the Clayton St. approach is doable. Just beware that no traffic modeling has been done for that, so it might unduly fuck with overall RL resiliency. My MS Paint drawings preserve the Columbia split and 4-track JFK station (there's plenty of room to turn the CR platform into an island by reshaping the inner busway and freeing up the Old Colony Ave. pavement in a reconfig of Columbia rotary).
There's room from East Braintree wye to Braintree Station if the Route 3 overpass were widened. Then the stub track of the freight yard can become the second main.
It's much tougher north of there. You'd have to nuke/rebuild the 1980 track underpass of the Red Line and associated incline because that most definitely is only single-track width. Probably also straighten the alignment so it's not such a speed restriction (it's laid out the way it is because of the switch to the now-defunct West Quincy Industrial Track freight spur). Quincy Adams Station itself also is going to be an incredibly tight squeeze. If it's true DT width (and I don't know if it is), it's got zero safety buffer from the foundations. It's noteworthy that TransitMatters left south-tip-of-Quincy Center to East Braintree Jct. as single track, given the difficulty involved. They said that :30 Regional Rail on all 3 branches would be safely doable with that stretch left single-track, and since they didn't try any crazy-high speed limit games on the mainline like they did on the branches that probably ends up holding up to scrutiny. Finishing Quincy Center-East Braintree Jct. may be something you defer till later when :15 Urban Rail service to Brockton is desired. Plain old :30 Regional Rail probably doesn't need it.
Bad idea. You want Regional Rail stopping at major bus hubs. It's multimodal Viagra. QC itself can be double-tracked without undue expense by digging out the gravel embankment the current platform abuts, re-capping the Burgin Parkway kiss-and-ride, and punching regularly-spaced holes in the retaining wall from the current platform to reach the other side of the doubled-up island. Freedom Park and Wollaston were likewise left alone by TransitMatters (again...absent the speed-limit insanity on the main vs. the branches, so their traffic modeling is more likely to hold up to scrutiny), with the QC platforms acting as the timing mechanism for treating that 1.4 mi. of single-track to the north. You might need some DT here for :15 Urban Rail to Brockton, but :30-:30-:30 on the branches can probably live without.
Greenbush would do a lot better on ridership if it had the frequencies, and Regional Rail is supposed to be a region-wide transformative service tier so it shouldn't be a game of playing favorites with who gets the spoils. It's one thing if immovable infrastructure constraints force something like Needham looking from the sidelines on :30 frequencies; it's quite another if the killshot double-tracking for unlocking :30 frequencies on all the OC branches leads one to put finger on the scale for somebody's branch while punishing somebody else's branch.
If there's anywhere past-128 meriting :15 frequencies it's Brockton. Gateway city of 90K, large RTA bus system centered on the CR station, adjacent third-track siding for a layover yard, island-platformed downtown stop enabling easy turnbacks. Plymouth Line doesn't have a node of that kind of heft, nor the density of bus connections at any of its stops. So only one of the branches really checks off the utilization boxes for bringing Urban Rail :15 frequencies past Braintree. Do whatever additional Quincy double-tracking segments enable that, cull half the runs at Brockton, leave :30 service continuing to Campello, Bridgewater, Middleboro, Wareham, and Buzzards Bay.
As you know, Transit Matters proposed extending to Plymouth Center. Cordage Park is getting some nice development as you mentioned. Untold Brewery of Scituate just opened a new large taproom there. https://www.untoldbrewing.com/plymouth
I think Quincy Center is quite popular among Old Colony train branches. The MBTA publishes a South Station - Braintree Shuttle schedule that shows how many trains stop at QC throughout the day. It's fairly impressive.
I would settle for 1-hour headways. There are many larger gaps over an hour in the current schedule.
End of the line for South Coast Rail: MBTA to talk project's final stages at meeting​
“FALL RIVER — It's nearly boarding time.
The South Coast Rail team has invited the public to a community meeting to discuss the project, which is wrapping up construction. The meeting will be held on Wednesday, April 10, at 6 p.m. at Morton Middle School.
Here’s what to expect and how to take part:
Who will be at the South Coast Rail meeting?​
Representatives from the Massachusetts Bay Transportation Authority will be on hand to deliver information about Fall River’s new commuter rail line to Boston.
What will the MBTA be talking about?​
When will the first South Coast Rail train finally roll out of the station? How much will a ticket cost? What's the South Coast Rail train schedule? Will it run on weekends?​
The MBTA has not yet answered any of these questions publicly — more information may be available at the April 10 meeting, or ask them yourself during the question-and-answer period.
How do I take part in the meeting?​
The meeting, in Morton’s auditorium at 1135 N. Main St., is free and open to the public.”
https://www.southcoasttoday.com/sto...7BYuJrdUBWnrpvLMtvBswADl4#lunv1gsc1o4l5qgfiuf
Does anyone have information about what was said during the meeting?
