SeamusMcFly
- Apr 3, 2008
I posted this information a ways back in this thread, but I don't remember exactly.
The rendering I just looked at will probably bother a couple people in one regard. A large amount of louvers facing Seaport Blvd. Massive louvers at the mid level mech. space. and smaller at the upper level (penthouse) mech. space.
Building "A"
3 levels below grade (-32'-0".)
261'-0" to top of penthouse. (above grade)
4 distinct Retail spaces on the ground floor with minimal lobby. (Not too shabby.)The loading dock entrance is facing the courthouse, so probably best place for it.
The garage entrance is on the north facing the other vertex building, so suppose the other would be opposite (although I would think a shared garage with a single entrance could have worked maybe better) which is again probably in the best place.
As for the structure, it looks like there will be a 5' voide between the water protectiong piles and the foundation water (I assume for dewatering). The drawings refer to the lowest level as slab on grade. This is a mat slab that appears to vary from 54" - 60" thick, with piles (that look like footings to me). Whether that answer Whigh question I'm not sure.
It looks like what I assumed earlier, a shell and core set to get going, with Vertex fitout drawings to follow.
The CD's tell me otherwise unfortunately.
Building "B" shows a separate entrance it's garage, and for whatever reason it also faces north instead of sharing the same road.
Looks like 3 retail spaces on ground level (2 future restaurant and one future daycare.)
Also, unfortunately, a larger lobby on this one.
It does appear that the garage connects below grade between the 2 parcels. But, still with multiple entrances.
Looks like this one tops out at 268'-6", so fairly identical.
