themissinglink
- Jan 13, 2018
Oooh nice. Where did you pull the muni boundary map from?
I took a snip of google maps and traced the town boundaries into the map.
What software did you use for the whole thing?I took a snip of google maps and traced the town boundaries into the map.
I used paint.net to create them. I'll post more here when I'm done with them.What software did you use for the whole thing?
Very cool! What program did you use to make that?
If Red Line is going to go to 128 (it should) then Burlington is a better terminal. Splitting the Red Line one more time is BAD. Blue Line along Pike is needlessly redundant. Both of these are best served with Regional Rail. Not totally sure the Orange Line can sustain a branch to Everett but I haven't looked at ridership OD data to know if it would be ok.
Setting aside questions of ridership and headway impact, what is the ROW for an Orange Line Everett branch? Clearly it starts off following the Eastern Route, branching just before Assembly, but where does it go once past the casino? There's no ROW there, other than the one that goes to Chelsea. Do we tunnel somewhere? An El on Broadway? It's not clear to me that there's an easy build through that area, even though the population density would clearly support rapid transit.
The state's name-drop of this project didn't even get into that level of specificity, so throw salt accordingly.Almost certainly you'd need to tunnel under Broadway / Rt 99. That seems unavoidable.
Could the Indian railways WAP-5 work in the United States?
Some maps I made with varying degrees of realism
While people are critical of another southern fork of Red, I appreciate your filling the existing rapid transit service gap in the area between the Orange and Red lines, and the Fairmount ROW would seem to make a lot of sense to utilize. Is there a particular reason why (i.e.) an EMU Fairmount out of the South Station surface lots appears to be the consensus, vs. taking over the ROW as a Red branch?Some maps I made with varying degrees of realism
Correct. It's the last freight route into Port of South Boston from the major classification yard in Framingham ever since the SW Corridor tunnel build put the NEC off-limits, so rights were guaranteed to Conrail (and successor CSX) in perpetuity.It's my understanding that there cannot be a mode change along that corridor because it's the alternate freight line into Boston, and there is not enough room in the RoW to lay parallel tracks.
