Jersey City is literally RIGHT NEXT TO MANHATTAN. Therefore it's part of New York right?
No you can't. Those aren't literally RIGHT NEXT TO EACH OTHER with no clear break in the skyline. Those are separated by miles of suburbia.
So by that logic, Los Angeles is actually multiple cities because literally the city consist of several business centers with their own skyline separated by low density neighborhoods.
Can we get back to the future skyline?
Los Angeles is 503 square miles. If you added Cambridge to Boston it comes to 55 square miles. You are doing a better job of making MY point than making YOUR point. From a "voting perspective" it's semantics that the inner suburbs chose not to be incorporated. From a skyline perspective, it's literally indistinguishable where Cambridge ends and Boston begins from a whole host of angles. (except the middle of the river)
So you agree that LA is actually multiple cities?
LA is actually technically the "densest" city in the entire country so it's tough to argue that.
DZH, what's the population of Boston?
I guess the following cities must all be bigger than Boston:
Phoenix
San Antonio
San Diego
Austin
Jacksonville
Indianapolis
Columbus
El Paso
Memphis
That is quite the excellent system you are using there. It's too bad this is a SKYLINE thread and it's too bad that the SKYLINES of Boston and Cambridge are literally one skyline. Next time I'm in one of the above cities I'll be sure to note how much bigger it is than Boston because KentXie doesn't think having apples to apples area comparisons should make any sort of difference.
Answer the question instead of deflecting please.
That being said, you should consider a career as a goaltender the way you are deflecting these questions.
The population of Boston proper is approximately 640k but it has an arbitrarily small boundary compared to other US cities due to suburban resistance. In terms of actual urban area/skyline, Cambridge clearly IS Boston. It's all on the same subway. Go visit Jacksonville and tell me how it stacks up.
Good call, it's also semantics.
http://la.curbed.com/2012/3/26/1038...e-most-densely-populated-urban-area-in-the-us
That statistic uses Boston, Worcester, Providence, Manchester, and all points in-between to count the urbanized area.
