Equilibria
- May 6, 2007
Trying to parse the functional differences between Davems and Equilibrias diagrams.
Equib - If you eliminate SFR through the area, where does Storrow pick up again? At the University exit, or down at Chatlesgate?
I'm not really eliminating Storrow. It would still be limited access from the intersection with SFR on. SFR bends through the site and would meet Storrow at right angles instead of the flowing transition that exists now - it's an attempt to disconnect Storrow from the rest of the river roads (which are even worse places for traffic to flow than Storrow is) and ease the predominant movements in the area.
The primary differences between my concept and Davem's (which is excellent and using much better software than I've got) are these:
1) Dave is targeting an eventual removal of Storrow Drive or a downgrade in concert with the Riverbank Subway. His prior design actually cut Storrow off completely and made the highway interchange between I-90 and SFR only, while this one leaves the SFR/Storrow connection for the time being but cuts the connection to I-90.
I'm coming from the perspective that while Storrow might eventually be downgraded, it will still have a necessary function as a distributor of traffic to the Back Bay, Beacon Hill, Kendall Square, and North Station. In fact, replacing its many ramps with at-grade intersections and adding additional connections will only make it more important as THE freeway access for large portions of Central Boston. Hence, I prioritized the same-direction links between I-90 and Storrow while Davem removed them entirely.
Also, I believe that the A/B rebuild WILL happen by 2020. The Riverbank Subway and Storrow downgrade are dream projects on this board, but unlikely to occur in reality beyond the removal of the Bowker Overpass. Likewise, no plans exist for F-Line's additional urban exits for the Pike, though I support them. Cutting links to Storrow at this point will only frustrate drivers from the west for a decade or more because functional removal of Storrow requires additional Pike exits to work.
2) Davem is pushing future development toward Allston, capitalizing on the existing neighborhoods and infrastructure and attempting to build connections between Beacon Park and BU. I used MassDOT's future alignment, which meant that the development would be pushed toward the river and Harvard. Both of these are good approaches. I think Dave's plan is better suited to the neighborhood, while mine is better suited to Harvard, which benefits if its version of Kendall is closer to Harvard Square.
3) Davem is focused on replicating the current interchange's ease of flow between major roads, meaning that he took up more space for ramps. I tried to constrain the highway to a diamond-like interchange and slip ramps to Storrow to maximize urban fabric and buildable land. Again, no clear better policy.
I'm a little concerned that by cutting off Storrow from the neighborhood (only access from SFR) Dave's robbing is new development of key connectivity to the Back Bay and Downtown. I ran Storrow straight through into Harvard to attempt to enhance connections through the site along the Charles. While it's nice that Dave made an attempt to build street access to BU, the opportunities for that will always be limited until the rail is decked, while the chance to build viable connections from "Harvard's Kendall" to the Back Bay is there as soon as the highway is moved.
Also, I realize that Dave probably assumes the MBTA won't want the yard he includes and that that land will become parkland, but I'm dubious about putting all of the parkland on the far side of highways. I'd rather hold the highway back toward the existing (and continuing) boundary of the railroad to keep the resulting neighborhood from becoming an island in a sea of freeway.
4) Dave put the Turnpike in a cutting. That's the right idea. MassDOT will never do it, because keeping I-90 operating through construction would require a Big Dig-like setup of digging under the current viaduct while supporting it temporarily, and that's way too expensive for their taste. Really, the highway would be better off buried under decks all the way past Cambridge St, with ramps surfacing to connect to a new Storrow running along the top the whole way. I planned that out in my head, but I didn't bother to draw it.
A plan which blended the best of these (and the many others possible on this blank slate) would probably need a free connection to I-90 from SFR (which I exclude) as well as one from I-90 to Storrow (which Dave excludes), in the smallest-footprint way possible, set as far back from the river as possible. It's a puzzle.
