What part of the system is designed for the headways you want it to have is so hard to grasp about this?
Want trains that can inch behind each other? Program the system to enforce a pause outside the occupied platform, then give the operator cart blanche to inch in as close as they need to capped at no more than 5 MPH. In other words...exactly what the employee handbook says they should be doing today. They can bump, but it's below the speed threshold that'll cause car damage or cause multiple injuries onboard. This Boylston crash was clocked at 2 to 2-1/2 times faster. Speed is the problem here, not proximity. Light rail is fundamentally different from heavy rail or RR's in that there's a lot more leeway on proximity. Different modes for different purposes.
There are well-designed PTC systems and there are poorly-designed PTC systems. But the one truism is that they have to be "designed" to task. That hasn't been done here yet, so neither the utopian nor the dystopian projections fit. It'll do whatever the traffic engineers tell it to do. And, yes, when it's designed with gaping flaws (hint: SEPTA's CBTC will be the most oft-cited on the FAIL end of the scale...but that's a whole other post) you get garbage-in/garbage-out. It's a good/bad engineering sliding scale, not a question of good/bad tech.
What's not clear is if the T even wants to get far enough to let the engineers tell them. If they're indicting the tech this early in the game, that's a decent leading indicator that the leadership isn't interested in solving--much less contemplating--a problem and are just fishing for narrative-fitting ammo.
Ah, I see the last couple pages where you were kinda sorta beginning to entertain the notion of this being a complex issue that didn't fit a neat and tidy political narrative just kind of went out the window there, and you're back to doubling-down on talking points. At least you're being honest with yourself now.
The MassDOT board does not agree with you, BTW, since they copped in the article to being afraid of sanctions for not closing up the safety hole.
Because Paris put in a system that allows 85 second headways, which is an order better than any other state of the art system in the US...
....and thats still less than what you can do on the green line today. So yes, a downgrade.
Best youll find in north america, btw is 90 seconds in mexico City. I dont believe any signalling system in the US does better than every 3 minutes, although please correct me on that.
Lincoln tunnel, we're talking vehicle capacity for signals, not passengers. 700 vehicles.
And the Lincoln tunnel handles over 30,000 in the peak hour, as the buses carry on average 45 passengers each. So 50% more than what the green line is doing....
Find me a signalling system that lets the green line what it does today, that is, have a train enter the station simultaneously as another departs, like a bus can do. No signalling system will let two green line trains park inches apart in park st and load simultaneously.
This is silly.
We had two crashes within a few years of each other. It's called a statistical anomaly. Nothing's changed in the system that I know of that would make it the beginning of a trend. The Green Line's been running for a long time without PTC, and it will continue to run for a long time without PTC. Yeah, someone died. He was texting while driving a fucking train. They cracked down and it's unlikely to happen again. $700m is a ton of money that could be better spent elsewhere. The cost benefit isn't even close.
